151
Re: JD340 v.1.4
Hi J.A Romanov
No, This is not happening after an update. I got the issue with the downloaded initial version. I downloaded the latest version 1.4  thinking that it would have fixed the problem.
JJC
celma972 wrote:
Dear All, I am unable to use that plane JD340 V1.4 properly. XPlane 11 crashes when loading I am getting that message into the log.txt :
D Light plugin by JARDesign Ver.280321
Loaded: /Users/jjc/Library/Application Support/Steam/steamapps/common/X-Plane 11/Aircraft/Extra Aircraft/340_JARDesign/plugins/CustomLight/mac.xpl (jardesign.3d_lt_editor).
[JD340 INFO]: Starting X-Plane SASL plugin v3.13.1+c1f025b [Commercial Edition]
[JD340 INFO]: JD340 | Aircraft | Start Full
[JD340 INFO]: Loading cursors...
Loaded: /Users/jjc/Library/Application Support/Steam/steamapps/common/X-Plane 11/Aircraft/Extra Aircraft/340_JARDesign/plugins/SASL/64/mac.xpl (1-sim JD340).
Loaded: /Users/jjc/Library/Application Support/Steam/steamapps/common/X-Plane 11/Aircraft/Extra Aircraft/340_JARDesign/plugins/diagnost/mac.xpl (jardesign.jd345diagnostic).
FMGS: 0 : Ver.r76-271021 Oct 28 2021
FMGS: 0 : PluginPath=/Users/jjc/Library/Application Support/Steam/steamapps/common/X-Plane 11/Aircraft/Extra Aircraft/340_JARDesign/plugins/fmgs/
FMGS: 0 : AircraftPath=/Users/jjc/Library/Application Support/Steam/steamapps/common/X-Plane 11/Aircraft/Extra Aircraft/340_JARDesign/
FMGS: 0 : FMGS plugin will try to disable some plugins to avoid plugin conflicts:
FMGS: 0 : Hardware device VID:1103PID:1031 TCA Q-Eng 1&2 was NOT found
--=={This application has crashed because of the plugin: fmgs/mac.xpl}==--
Renaming the mac.xpl file. Plane is loading fine but some buttons are not working, FMS is black..
If this happen after using instant update - please call me Skype j.a.romanov. - we will check this issue online.
152
Re: JD340 v.1.4
celma972 wrote:
Hi J.A Romanov
JD320/330 should work well under Catalina/BigSur. Please redownload JD320/330 and reinstall it from:
Next, please follow this instruction:
http://jardesign.org/forum/viewtopic.ph … 793#p31793
If no luck - you can contact me via skype j.a.romanov for direct help - we will check this issue online. You may call anytime when my skype label is green.
153
Re: JD340 v.1.4
Good morning Sir.
Do you intend to make a co-pilot for the Toliss A340-600? I am waiting for it. Thank you.
154
Re: JD340 v.1.4
recommendations for improving feechures in airbus A340 model:
bugs identified during flights:
-hovering sounds during the flight and after landing (wind)
-fps drops by 30-40% after installation of all systems
-it is unclear and inconvenient how to load fuel and payload.
recommendations to future updates:
-make a detailed payload sheet - fuel & passengers;
-API Vulcan/metal fps compatible textures(external/internal) in dds format;
-plausible colors of metal surfaces
-improved reflections of mirror surfaces without degradation of fps. Especially in night modes;
-Realization of passengers and staff on board;
-Realization of visible luggage in the luggage compartment in accordance with the loading list.
155
Re: JD340 v.1.4
+recommendations to future updates:
-Heat trace of the APU - make a visible trace;
-And, of course, the sounds. Make more realistic sounds of APU, Engines.
Thanks, I hope for understanding.
156
Re: JD340 v.1.4
jptoma wrote:
Good morning Sir.
We can do if Toliss will prefer. Only way - use Toliss support and ask them to prepare aircraft to make it copilot-compatible.
157
Re: JD340 v.1.4
Thank you!
Is included pdf manual really unclear how to add payload?
What did you mean as "after installation of all systems" (cause aircraft have no option for "all"/"not all" systems installation)?
Wind sound is just an X-Plane feature - you may change volume via X-Plane Settings.
158
Re: JD340 v.1.4
159
Re: JD340 v.1.4
X-Plane 10?
160
Re: JD340 v.1.4
Frame rate compared to JD330?
I have the JD330 and I love it!
Is the frame rate of the A340-500 similar to the A330-200 or do I have to expect much lower frame rates?
Thanks for an answer!
161
Re: JD340 v.1.4
Make dating stress-free and enjoyable with the best casual dating experience.
Not against spontaneous decisions, one night only
Living Women
Exemplary casual Dating
162
Re: JD340 v.1.4
Anyone have any issues with the A340 running under Rosetta on a M-series (M1/M2/M3/M4) Mac?
