Re: XP12.00 JD330 (beta)
VOZ102 wrote:
tmainka82 wrote:
On longhaul flight it twice happened that suddenly both engine shut off and were not able to restart with the normal procedure.
Same for me after about 10 hours flying:
9:39:41.434 P/GVA: Actual sim speed = 2.2, reported is 1, rounding to 1
9:39:58.082 P/GVA: Actual sim speed = 1.9, reported is 1, rounding to 1
9:40:02.445 P/GVA: Actual sim speed = 1.9, reported is 1, rounding to 1
[JD330 INFO]: [LUA]: AP diseng. (AOA protection reason)
[JD330 INFO]: [LUA]: "module"    Play2d=ap_disc/0/0
FAILURE DETECT: L3_AUTO FLT AP OFF
PLAY SOUND: Ap1
PLAY SOUND: APDisconectOnFcu
[JD330 INFO]: [LUA]: >>> zulu 5:43:29
[JD330 INFO]: [LUA]:     baro alt=35959 / rad alt=36393
[JD330 INFO]: [LUA]:     air spd=153 / gnd spd=242 / mach=0.5
[JD330 INFO]: [LUA]:     GW=173165 / FOB=8190 / CG=31
[JD330 INFO]: [LUA]: thr  mode = A.FLOOR
[JD330 INFO]: [LUA]: >>> zulu 5:43:36
[JD330 INFO]: [LUA]:     baro alt=36065 / rad alt=36490
[JD330 INFO]: [LUA]:     air spd=152 / gnd spd=230 / mach=0.48
[JD330 INFO]: [LUA]: thr  mode =  TOGALK
[JD330 INFO]: [LUA]: >>> zulu 5:43:41
[JD330 INFO]: [LUA]:     baro alt=35947 / rad alt=36346
[JD330 INFO]: [LUA]:     air spd=143 / gnd spd=230 / mach=0.48
Thanks for this part of Log!
Is it may be some joystick axis/button assigned to mixture or ignition?
Hallo, same for me. I think the cause may be a new update of XP12. Did a lot of flights with the A330 on XP12 before w/o any issues like this:
PLAY SOUND: Ap1
PLAY SOUND: APDisconectOnFcu1
[JD330 INFO]: [LUA]: >>> zulu 11:31:29
[JD330 INFO]: [LUA]:     baro alt=3004 / rad alt=3083
[JD330 INFO]: [LUA]:     air spd=106 / gnd spd=123 / mach=0.18
[JD330 INFO]: [LUA]:     GW=154111 / FOB=8236 / CG=30
PLAY SOUND: lvrClb
PLAY SOUND: lvrClb
FAILURE DETECT: L2_ENG A/THR LIMITED
[JD330 INFO]: [LUA]: >>> zulu 11:31:33
[JD330 INFO]: [LUA]:     baro alt=2911 / rad alt=2988
[JD330 INFO]: [LUA]:     air spd=109 / gnd spd=124 / mach=0.18
[JD330 INFO]: [LUA]:     GW=154108 / FOB=8232 / CG=30
PLAY SOUND: sc
PLAY SOUND: lvrIdle
PLAY SOUND: lvrIdle
[JD330 INFO]: [LUA]: >>> zulu 11:31:39
[JD330 INFO]: [LUA]:     baro alt=2697 / rad alt=2772
[JD330 INFO]: [LUA]:     air spd=124 / gnd spd=145 / mach=0.21
[JD330 INFO]: [LUA]:     GW=154092 / FOB=8216 / CG=30
I don't have any buttons assigned to mixture or ignition. Just gear and flaps. Will check the a340 whether this occurs on that plane, too.
Thanks for the effort, keep up the good work, best regards,
Alexander
Alexander
Ok, thanks for this info!
53
Loading stop when are loading world
if crash not happen - need just wait more
55 (edited by MapleFly 2023-02-19 22:26:05)
Hi. Hoping you can shed some light on this.
1. The flight time is short by about half. I've attached a screenshot comparing with the default A330.
2. The plane is constantly recalculating its positing, meaning it constantly jumps off course and then goes into a holding bank. I've attached two screenshots, just a few seconds apart to show this (see the chrono).
I'd disabled all other plugins, other than better-pushback. Unfortunately, it's unflyable right now.
The log shows:
log.txt for X-Plane 12.04b2 (build 120401 Intel 64-bit, Vulkan 773363346067e29c8009841bde95a8d1b6d1022d)
Compiled on Feb 16 2023 10:56:56
X-Plane Started on Sun Feb 19 16:00:44 2023
0:53:57.298 I/RWX: WEATHER UPDATE at zulu-time 1676843130
0:56:26.780 E/ATC: Aircraft p=0 (A330) was at -1.651877854 51.610950499 but predicted to be at -3.817481191 51.898905465 (82.265228 nm away) in 30.000000 seconds
3. I'm also seeing this spamming the log file:
CheckErrorOAL(8) info: UpdateListener
Sound3d:OAL_error = No such error code
Sound3d:OAL_error = 40961
1.You may follow MCDU prediction and not care about build-in X-Plane calculation.
2.Not sure in details situation you describe. If this happen constantly and you sure that everything that you do - right, please contact me skype j.a.romanov - we will do flight together and will see what happen wrong.
Using the correct version but I've found two faults. One being the APU exhaust not showing any emission/heat blur whilst active, and the other is the speed brakes not deploying upon landing even though armed. The speed brakes are also not activating using a button bind, though they will retract with the button.
58 (edited by carvalhokiko 2023-03-06 19:11:47)
stateless_01 wrote:
On First loading - this is normal, aircraft may convert navdata to "fast loaded" format. It may take half minute to minutes for some computers.
Hello and thanks for answer,
i waited as long as 15-20 minutes on several tries, it does not load.
You may call me skype j.a.romanov directly - we will try to find a reason
This is also happening to me, I just bought the plane. Any sugestion?
59
I may check this via skype, for sure.
Is it possible that JD hasn't yet released an updated version that fixes the bug of seeing the managed speed increased to 180kt on short final? I reported the issue with a video running year 2022 and again here January 2023? Am I the only one having this problem?
61 (edited by FloJoe 2023-03-23 18:23:42)
For some reason XP12 freezes when loading the A330. I can see the JarDesign Logo in the background and then it stops.
EDIT: Found the fix, delete the VR optimised.acf and the disable plugins.txt
Logfile:
0:02:37.522 I/FCG: Starting new flight in Aircraft/Airliners/JD330XP1200/a330.acf at Ramp N6
0:02:37.522 D/STM: Transitioning from state state_QuickFlightWizard to state_NormalLoading
WebFMC: Plane unloaded: 0
0:02:37.522 I/ACF: Loading airplane number 0 with Aircraft/Airliners/JD330XP1200/a330.acf
[BetterPushback-v0.52]: Dataref 'sim/weather/runway_friction' has been replaced. Please use the new name.
WebFMC: Plane loaded: 0
WebFMC: WebFMC main loop enabled
X-Camera: Scenic Flyer not found
Fetching plugins for B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins
[330/win.xpl]: Dataref 'sim/weather/temperature_ambient_c' has been replaced. Please use the new name.
[330/win.xpl]: Dataref 'sim/weather/precipitation_on_aircraft_ratio' has been replaced. Please use the new name.
Loaded: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins/330/win.xpl (jardesign.a330).
[330va/win.xpl]: Dataref 'sim/weather/temperature_ambient_c' has been replaced. Please use the new name.
[330va/win.xpl]: Dataref 'sim/weather/precipitation_on_aircraft_ratio' has been replaced. Please use the new name.
Loaded font: sys20 0 0
Loaded font: sys28 0 0
Loaded font: sys18 0 0
Loaded font: sys22 0 0
Loaded font: efb22 0 0
UUID:1bf26bc5-d893-4827-b1ec-412a1fbf7fa1
Loaded: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins/330va/win.xpl (jardesign.va).
3D Light plugin by JARDesign Ver.280321
Loaded: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins/CustomLight/win.xpl (jardesign.3d_lt).
[JD330 INFO]: Starting X-Plane SASL plugin v3.2.7+0b9658f [Commercial Edition]
[JD330 INFO]: JD330 | Aircraft | Start Full
Loaded: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins/SASL/64/win.xpl (1-sim JD330).
Loaded: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins/diagnost/win.xpl (jardesign.a330diagnostic).
FMGS: 0 : Ver.r79-051221 Oct 29 2022
FMGS: 0 : PluginPath=B:\X-Plane 12\Aircraft\Airliners\JD330XP1200\plugins\fmgs\
FMGS: 0 : AircraftPath=B:\X-Plane 12\Aircraft\Airliners\JD330XP1200\
FMGS: 0 : FMGS plugin will try to disable some plugins to avoid plugin conflicts:
FMGS: 0 : Marginal.GroundTraffic.LJLJ_Ljubliana was disabled by FMGS plugin to avoid plugin conflict.
FMGS: 0 : Marginal.GroundTraffic.EGHI_A_Southampton_Orbx was disabled by FMGS plugin to avoid plugin conflict.
FMGS: 0 : Marginal.GroundTraffic.EDDN Nuremberg 2 was disabled by FMGS plugin to avoid plugin conflict.
FMGS: 0 : CUSTOM DATAREF (int) ERROR (already exist): jd/fo/kill
FMGS: 0 : Hardware device VID:1103PID:1031 TCA Q-Eng 1&2 was NOT found
Loaded: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins/fmgs/win.xpl (jardesign.fmgs).
[JD330 INFO]: Enabling...
[JD330 INFO]: Sound output device: OpenAL Soft
[JD330 INFO]: Sound input device: OpenAL Soft on Kopfhörermikrofon (Logitech H570e Stereo)
[JD330 INFO]: Initializing...
[JD330 INFO]: Path to module: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/modules/main.key
[JD330 INFO]: Loading module...
[JD330 INFO]: [LUA]: loading    module
[JD330 INFO]: [LUA]: "module"    SASL components loading...
[JD330 INFO]: [LUA]: loading    first
[JD330 INFO]: [LUA]: loading    text
[JD330 INFO]: [LUA]: "text"    Plate info: JD330-12.0.3
[JD330 INFO]: [LUA]: loading    drf2tbl
[JD330 INFO]: [LUA]: loading    light
[JD330 INFO]: [LUA]: loading    animation
[JD330 INFO]: [LUA]: loading    reload
[JD330 INFO]: [LUA]: loading    draw_test
[JD330 INFO]: [LUA]: loading    pfdcalc
[JD330 INFO]: [LUA]: loading    fadec
[JD330 INFO]: [LUA]: loading    ap
[JD330 INFO]: [LUA]: loading    menu
[JD330 INFO]: [LUA]: loading    sound_sys1
[JD330 INFO]: [LUA]: loading    sound_fo
[JD330 INFO]: [LUA]: loading    sound_st
[JD330 INFO]: [LUA]: loading    sound_sys2
[JD330 INFO]: [LUA]: loading    icerain
[JD330 INFO]: [LUA]: loading    radio
[JD330 INFO]: [LUA]: loading    phase
[JD330 INFO]: [LUA]: loading    view
[JD330 INFO]: [LUA]: loading    hotstart
[JD330 INFO]: [LUA]: loading    textureLit
[JD330 INFO]: [LUA]: loading    switchLit
[JD330 INFO]: [LUA]: loading    prf_appr
[JD330 INFO]: [LUA]: loading    radiopanel
[JD330 INFO]: [LUA]: loading    gpws
[JD330 INFO]: [LUA]: loading    tcas
[JD330 INFO]: [LUA]: loading    pfddraw
[JD330 INFO]: [LUA]: loading    isis
[JD330 INFO]: [LUA]: loading    counter
[JD330 INFO]: [LUA]: loading    sys_elec
[JD330 INFO]: [LUA]: loading    sys_hyd
[JD330 INFO]: [LUA]: loading    sys_bld
[JD330 (SASL)]: Dataref 'sim/weather/temperature_ambient_c' has been replaced. Please use the new name.
[JD330 INFO]: [LUA]: loading    sys_cond
[JD330 INFO]: [LUA]: loading    sys_drs
[JD330 INFO]: [LUA]: loading    sys_oxy
[JD330 INFO]: [LUA]: loading    sys_press
[JD330 INFO]: [LUA]: loading    sys_whl
[JD330 (SASL)]: Dataref 'sim/weather/runway_friction' has been replaced. Please use the new name.
[JD330 INFO]: [LUA]: loading    sys_fctl
[JD330 INFO]: [LUA]: loading    sys_fuel
[JD330 INFO]: [LUA]: loading    sys_eng
[JD330 INFO]: [LUA]: loading    sys_eng_sys
[JD330 INFO]: [LUA]: loading    sys_flaps
[JD330 INFO]: [LUA]: loading    gnd_tow
[JD330 INFO]: [LUA]: loading    clickable
[JD330 INFO]: [LUA]: loading    bbox
[JD330 INFO]: [LUA]: loading    audio
[JD330 INFO]: [LUA]: loading    pax_text
[JD330 INFO]: [LUA]: loading    cab_text
[JD330 INFO]: [LUA]: loading    mech_text
[JD330 INFO]: [LUA]: loading    last
[JD330 INFO]: [LUA]: loading    diagnost
[JD330 INFO]: Loading cursors...
[JD330 INFO]: Module loaded
0:02:37.522 D/ATC: (): ClearForReuse
0:02:37.522 I/ATC: Created aircraft 0000020D8971A750 as p=0 ()
[SAM]: Dataref 'sim/weather/wind_direction_degt' has been replaced. Please use the new name.
[SAM]: Dataref 'sim/weather/wind_speed_kt' has been replaced. Please use the new name.
[SAM]: Dataref 'sim/weather/barometer_sealevel_inhg' has been replaced. Please use the new name.
0:02:37.522 I/OVR: Reading VR conf file: Aircraft/Airliners/JD330XP1200/a330_vrconfig.txt
0:02:37.522 W/VRCONFIG: Could not find vr config file: Aircraft/Airliners/JD330XP1200/a330_vrconfig.txt
0:02:37.522 W/VRCONFIG: VR Config data file for Aircraft/Airliners/JD330XP1200/a330_vrconfig.txt is not valid!
0:02:37.522 W/MANIPS: Could not find vr config file: Aircraft/Airliners/JD330XP1200/a330_vrconfig.txt
0:02:37.522 W/MANIPS: VR Manips file for Aircraft/Airliners/JD330XP1200/a330_vrconfig.txt is not valid!
[JD330 INFO]: [LUA]: "reload"    Load Prefs from B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/modules/Custom Module/save_pref.txt
[JD330 INFO]: [LUA]: "reload"    JD330 version 412
[JD330 WARN]: [STACK]:| VQbKaJHFIi : DataRefsHandler::luaFetchDataRef: can't find dataref <jd/diagnost/reco>
[JD330 WARN]: [STACK]:| [string "4dac56b511b076a/data/init/initProperties"]:269 in function <globalPropertyi>
[JD330 WARN]: [STACK]:| [string "sound_fo"]:160 in function <update>
[JD330 WARN]: [STACK]:| [string "4dac56b511b076a/data/init/initProcessing"]:58 in function <updateComponent>
[JD330 WARN]: [STACK]:| [string "4dac56b511b076a/data/init/initProcessing"]:68 in function <updateAll>
[JD330 WARN]: [STACK]:| [string ".../initMain.secured"]:0 in function <update>
[JD330 WARN]: [STACK]:| ...
[JD330 INFO]: [LUA]: "sound_fo"    Copilot plugin not detected
[JD330 INFO]: [LUA]: >>> zulu 13:42:36
[JD330 INFO]: [LUA]:     baro alt=1069 / rad alt=1
[JD330 INFO]: [LUA]:     air spd=0 / gnd spd=0 / mach=0
[JD330 INFO]: [LUA]:     GW=143338 / FOB=54592 / CG=0
[JD330 INFO]: [LUA]: active wpt = 0
[JARDesign FMGS plugin]: Dataref 'sim/weather/temperature_ambient_c' has been replaced. Please use the new name.
FMGS: 0 : Cant Find Dataref: jd/weather/radar/on
FMGS: 0 : Cant Find Dataref: jd/ghd/execute
FMGS: 0 : Cant Find Dataref: jd/ghd/drfcontrol
FMGS: 0 : Cant Find Dataref: jd/ghd/select_00
FMGS: 0 : Cant Find Dataref: jd/ghd/select_01
FMGS: 0 : Cant Find Dataref: jd/ghd/select_02
FMGS: 0 : Cant Find Dataref: jd/ghd/select_03
FMGS: 0 : Cant Find Dataref: jd/ghd/select_04
FMGS: 0 : Cant Find Dataref: jd/ghd/select_05
FMGS: 0 : Cant Find Dataref: jd/ghd/select_06
FMGS: 0 : Cant Find Dataref: jd/ghd/select_07
FMGS: 0 : Cant Find Dataref: jd/ghd/select_08
FMGS: 0 : Cant Find Dataref: jd/ghd/select_09
FMGS: 0 : Cant Find Dataref: jd/ghd/select_10
FMGS: 0 : Cant Find Dataref: jd/ghd/select_11
FMGS: 0 : Cant Find Dataref: jd/ghd/select_12
FMGS: 0 : Cant Find Dataref: jd/ghd/select_13
FMGS: 0 : Cant Find Dataref: jd/ghd/select_14
FMGS: 0 : Cant Find Dataref: jd/ghd/select_15
FMGS: 0 : Cant Find Dataref: jd/ghd/select_16
FMGS: 0 : Cant Find Dataref: jd/ghd/select_17
FMGS: 0 : Cant Find Dataref: jd/ghd/select_18
FMGS: 0 : Cant Find Dataref: jd/ghd/select_19
FMGS: 0 : Cant Find Dataref: jd/ghd/select_20
FMGS: 0 : Cant Find Dataref: jd/ghd/select_21
FMGS: 0 : Cant Find Dataref: jd/ghd/select_22
FMGS: 0 : Cant Find Dataref: jd/ghd/select_23
FMGS: 0 : Cant Find Dataref: jd/ghd/select_24
FMGS: 0 : Cant Find Dataref: jd/ghd/select_25
FMGS: 0 : Navdata info:
FMGS: 0 : Provider N
FMGS: 0 : Cycle 2302
FMGS: 0 : Period 23FEB-23MAR
FMGS: 0 : inPath B:\X-Plane 12\/Custom Data/GNS430/navdata/
FMGS: 0 : procPath B:\X-Plane 12\/Custom Data/GNS430/navdata/Proc/
FMGS: 0 : Provider A
FMGS: 0 : Cycle 1410
FMGS: 0 : Period 18SEP-15OCT
FMGS: 0 : inPath B:\X-Plane 12\Aircraft\Airliners\JD330XP1200\plugins/fmgs/navdata/
FMGS: 0 : procPath B:\X-Plane 12\Aircraft\Airliners\JD330XP1200\plugins/fmgs/navdata/Proc/
FMGS: 0 : MessageGreen: Systems Created!
PLAY SOUND: ventLeft
PLAY SOUND: ventRght
PLAY SOUND: TableCloseL
PLAY SOUND: TableCloseR
PLAY SOUND: ParkBrake1
PLAY SOUND: ChangeHPALeft
PLAY SOUND: Prim1
PLAY SOUND: Sec1
PLAY SOUND: ADR1
PLAY SOUND: ADR3
PLAY SOUND: ADR2
PLAY SOUND: IR1
PLAY SOUND: IR3
PLAY SOUND: IR2
PLAY SOUND: lvrIdle
PLAY SOUND: lvrIdle
PLAY SOUND: nlgUp
PLAY SOUND: ei_base_clr
PLAY SOUND: ei_base_fan
PLAY SOUND: ei_hist_cl
PLAY SOUND: ei_hist_dr
PLAY SOUND: ei_midnoise
PLAY SOUND: e_bass3
PLAY SOUND: e_middo
PLAY SOUND: apu
PLAY SOUND: reverse
PLAY SOUND: ei_base_hi
PLAY SOUND: startBass
PLAY SOUND: startHitone
PLAY SOUND: startMidtone
PLAY SOUND: bassLo
PLAY SOUND: bassHi
PLAY SOUND: bassLo
PLAY SOUND: bassHi
PLAY SOUND: bassHi
PLAY SOUND: hitoneCl
PLAY SOUND: hitoneLo
PLAY SOUND: hitoneHi
PLAY SOUND: midTone
PLAY SOUND: power
PLAY SOUND: back
PLAY SOUND: eFan
PLAY SOUND: e_apueq_all
PLAY SOUND: e_max1_all
PLAY SOUND: e_max2_all
PLAY SOUND: e_taxi_all
PLAY SOUND: bassLo
PLAY SOUND: startSss
PLAY SOUND: bassLo
PLAY SOUND: apu
PLAY SOUND: Flaps0
PLAY SOUND: PbOff
WebFMC: IO thread running
WebFMC: Server version 2.1.0
WebFMC: Determining plane type
WebFMC: acf_ICAO: 'A330', acf_author: 'JARDESIGN (C)', acf_descrip: 'Airbus A330-200 by JARDesign'
WebFMC: Detected JarDesign JD330
WebFMC: Setup start
WebFMC: Setup end
0:03:41.036 I/WIN: Opened window menu bar
FMGS: 0 : Tiller axis No=7
PLAY SOUND: NdMode
PLAY SOUND: NdRange
PLAY SOUND: AdfVor1
PLAY SOUND: AdfVor2
PLAY SOUND: ChangeHPARight
PLAY SOUND: BaroRot
PLAY SOUND: AltChengeLeft
PLAY SOUND: AltRot
PLAY SOUND: Fd
PLAY SOUND: CrewSupply
PLAY SOUND: Sys
PLAY SOUND: Terr
PLAY SOUND: Sys
PLAY SOUND: GSMode
PLAY SOUND: FlapMode
PLAY SOUND: gEngPumpOff1
PLAY SOUND: gElPumpOff1
PLAY SOUND: bEngPumpOff1
PLAY SOUND: bElPumpOff1
PLAY SOUND: yEngPumpOff1
PLAY SOUND: yElPumpOff1
PLAY SOUND: gEngPumpOff2
PLAY SOUND: CtrL
PLAY SOUND: CtrR
PLAY SOUND: StbyL
PLAY SOUND: StbyR
PLAY SOUND: Galley
PLAY SOUND: Commercial
PLAY SOUND: ApuGen
PLAY SOUND: Gen1
PLAY SOUND: Gen2
PLAY SOUND: Pack1
PLAY SOUND: Pack2
PLAY SOUND: HotAir1
PLAY SOUND: HotAir2
PLAY SOUND: Eng1Bleed
PLAY SOUND: Eng2Bleed
PLAY SOUND: PackFlow
PLAY SOUND: XBleedSel
PLAY SOUND: ElevSel
PLAY SOUND: ValvSel
PLAY SOUND: Compass
PLAY SOUND: Ctl
PLAY SOUND: Prim2
PLAY SOUND: Sec2
PLAY SOUND: Prim3
PLAY SOUND: TurbDamp
PLAY SOUND: Lever
PLAY SOUND: PushKnob
PLAY SOUND: ASkid
PLAY SOUND: StartTime
PLAY SOUND: MapLeft
PLAY SOUND: MapRight
PLAY SOUND: Console
PLAY SOUND: Vhf1
PLAY SOUND: Vhf2
PLAY SOUND: Int
PLAY SOUND: Cab
PLAY SOUND: Mkr
PLAY SOUND: Pa
PLAY SOUND: IntRad
PLAY SOUND: AbvBlv
PLAY SOUND: TcasCodeSel
PLAY SOUND: FwdBtn
PLAY SOUND: AftBtn
PLAY SOUND: BlkBtn
PLAY SOUND: HotAir
PLAY SOUND: PreselBtn
PLAY SOUND: CoolingSel
PLAY SOUND: nlgDn
PLAY SOUND: Runway
PLAY SOUND: Roll
PLAY SOUND: LgDown
[JD330 INFO]: [LUA]: lat  wait = NAV
PLAY SOUND: faa_02_drsclose
PLAY SOUND: OptPb
0:04:06.694 I/TEX: Target scale moved to 16.000000
PLAY SOUND: PbOn
0:04:06.756 I/ATC: Removing parking 'New Ramp Start 3' at XEDSC - can't taxi to runway 27.
0:04:06.756 I/ATC: Removing parking 'New Ramp Start 3' at XEDSC - can't taxi to runway 09.
LTED: 1 : isDrfConnectDone == 0
LTED: 1 : Bright Dataref for light 0: sim/custom/xap/light/ovh_cent
LTED: 1 : PwrOn Dataref for light 0: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 0: non
LTED: 1 : Bright Dataref for light 1: sim/custom/xap/light/ovh_cent
LTED: 1 : PwrOn Dataref for light 1: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 1: non
LTED: 1 : Bright Dataref for light 2: sim/custom/xap/light/ovh_left
LTED: 1 : PwrOn Dataref for light 2: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 2: non
LTED: 1 : Bright Dataref for light 3: sim/custom/xap/light/ovh_left
LTED: 1 : PwrOn Dataref for light 3: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 3: non
LTED: 1 : Bright Dataref for light 4: sim/custom/xap/light/ovh_rght
LTED: 1 : PwrOn Dataref for light 4: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 4: non
LTED: 1 : Bright Dataref for light 5: sim/custom/xap/light/ovh_left
LTED: 1 : PwrOn Dataref for light 5: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 5: non
LTED: 1 : Bright Dataref for light 6: sim/custom/xap/light/pan_flood
LTED: 1 : PwrOn Dataref for light 6: sim/custom/xap/elec/dcess
LTED: 1 : Hide Dataref for light 6: non
LTED: 1 : Bright Dataref for light 7: sim/custom/xap/light/pan_flood
LTED: 1 : PwrOn Dataref for light 7: sim/custom/xap/elec/dcess
LTED: 1 : Hide Dataref for light 7: non
LTED: 1 : Bright Dataref for light 8: sim/custom/xap/light/pan_flood
LTED: 1 : PwrOn Dataref for light 8: sim/custom/xap/elec/dcess
LTED: 1 : Hide Dataref for light 8: non
LTED: 1 : Bright Dataref for light 9: sim/custom/xap/light/pan_flood
LTED: 1 : PwrOn Dataref for light 9: sim/custom/xap/elec/dcess
LTED: 1 : Hide Dataref for light 9: non
LTED: 1 : Bright Dataref for light 10: sim/custom/xap/light/map_left
LTED: 1 : PwrOn Dataref for light 10: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 10: non
LTED: 1 : Bright Dataref for light 11: sim/custom/xap/light/map_rght
LTED: 1 : PwrOn Dataref for light 11: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 11: non
LTED: 1 : Bright Dataref for light 12: sim/custom/xap/light/console
LTED: 1 : PwrOn Dataref for light 12: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 12: non
LTED: 1 : Bright Dataref for light 13: sim/custom/xap/light/console
LTED: 1 : PwrOn Dataref for light 13: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 13: non
LTED: 1 : Bright Dataref for light 14: sim/custom/xap/light/console
LTED: 1 : PwrOn Dataref for light 14: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 14: non
LTED: 1 : Bright Dataref for light 15: sim/custom/xap/light/console
LTED: 1 : PwrOn Dataref for light 15: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 15: non
LTED: 1 : Bright Dataref for light 16: sim/custom/xap/light/console
LTED: 1 : PwrOn Dataref for light 16: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 16: non
LTED: 1 : Bright Dataref for light 17: sim/custom/xap/light/console
LTED: 1 : PwrOn Dataref for light 17: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 17: non
LTED: 1 : Bright Dataref for light 18: sim/custom/xap/light/dome_out
LTED: 1 : PwrOn Dataref for light 18: non
LTED: 1 : Hide Dataref for light 18: non
LTED: 1 : Bright Dataref for light 19: sim/custom/xap/light/dome_out
LTED: 1 : PwrOn Dataref for light 19: non
LTED: 1 : Hide Dataref for light 19: non
LTED: 1 : Bright Dataref for light 20: sim/custom/xap/lght_upd
LTED: 1 : PwrOn Dataref for light 20: sim/custom/xap/elec/acess
LTED: 1 : Hide Dataref for light 20: non
LTED: 1 : Bright Dataref for light 21: sim/custom/xap/lght_dnd
LTED: 1 : PwrOn Dataref for light 21: sim/custom/xap/elec/ac1
LTED: 1 : Hide Dataref for light 21: non
LTED: 1 : Bright Dataref for light 22: sim/custom/xap/lght_dnd
LTED: 1 : PwrOn Dataref for light 22: sim/custom/xap/elec/ac1
LTED: 1 : Hide Dataref for light 22: non
LTED: 1 : Bright Dataref for light 23: sim/custom/xap/light/compass
LTED: 1 : PwrOn Dataref for light 23: sim/custom/xap/elec/dcess
LTED: 1 : Hide Dataref for light 23: non
LTED: 1 : Bright Dataref for light 24: sim/custom/xap/lght_pfd
LTED: 1 : PwrOn Dataref for light 24: sim/custom/xap/elec/acess
LTED: 1 : Hide Dataref for light 24: non
LTED: 1 : Bright Dataref for light 25: sim/custom/xap/lght_pfd
LTED: 1 : PwrOn Dataref for light 25: sim/custom/xap/elec/acess
LTED: 1 : Hide Dataref for light 25: non
LTED: 1 : Bright Dataref for light 26: sim/custom/xap/lght_nd
LTED: 1 : PwrOn Dataref for light 26: sim/custom/xap/elec/acess_shed
LTED: 1 : Hide Dataref for light 26: non
LTED: 1 : Bright Dataref for light 27: sim/custom/xap/lght_nd
LTED: 1 : PwrOn Dataref for light 27: sim/custom/xap/elec/acess_shed
LTED: 1 : Hide Dataref for light 27: non
LTED: 1 : Bright Dataref for light 28: non
LTED: 1 : PwrOn Dataref for light 28: non
LTED: 1 : Hide Dataref for light 28: non
LTED: 1 : Bright Dataref for light 29: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 29: non
LTED: 1 : Hide Dataref for light 29: non
LTED: 1 : Bright Dataref for light 30: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 30: non
LTED: 1 : Hide Dataref for light 30: non
LTED: 1 : Bright Dataref for light 31: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 31: non
LTED: 1 : Hide Dataref for light 31: non
LTED: 1 : Bright Dataref for light 32: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 32: non
LTED: 1 : Hide Dataref for light 32: non
LTED: 1 : Bright Dataref for light 33: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 33: non
LTED: 1 : Hide Dataref for light 33: non
LTED: 1 : Bright Dataref for light 34: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 34: non
LTED: 1 : Hide Dataref for light 34: non
LTED: 1 : Bright Dataref for light 35: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 35: non
LTED: 1 : Hide Dataref for light 35: non
LTED: 1 : Bright Dataref for light 36: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 36: non
LTED: 1 : Hide Dataref for light 36: non
LTED: 1 : Bright Dataref for light 37: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 37: non
LTED: 1 : Hide Dataref for light 37: non
LTED: 1 : Bright Dataref for light 38: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 38: non
LTED: 1 : Hide Dataref for light 38: non
LTED: 1 : Bright Dataref for light 39: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 39: non
LTED: 1 : Hide Dataref for light 39: non
LTED: 1 : Bright Dataref for light 40: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 40: non
LTED: 1 : Hide Dataref for light 40: non
LTED: 1 : Bright Dataref for light 41: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 41: non
LTED: 1 : Hide Dataref for light 41: non
LTED: 1 : Bright Dataref for light 42: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 42: non
LTED: 1 : Hide Dataref for light 42: non
LTED: 1 : Bright Dataref for light 43: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 43: non
LTED: 1 : Hide Dataref for light 43: non
LTED: 1 : Bright Dataref for light 44: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 44: non
LTED: 1 : Hide Dataref for light 44: non
LTED: 1 : Bright Dataref for light 45: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 45: non
LTED: 1 : Hide Dataref for light 45: non
LTED: 1 : Bright Dataref for light 46: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 46: non
LTED: 1 : Hide Dataref for light 46: non
LTED: 1 : Bright Dataref for light 47: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 47: non
LTED: 1 : Hide Dataref for light 47: non
LTED: 1 : Bright Dataref for light 48: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 48: non
LTED: 1 : Hide Dataref for light 48: non
LTED: 1 : Bright Dataref for light 49: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 49: non
LTED: 1 : Hide Dataref for light 49: non
LTED: 1 : Bright Dataref for light 50: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 50: non
LTED: 1 : Hide Dataref for light 50: non
LTED: 1 : Bright Dataref for light 51: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 51: non
LTED: 1 : Hide Dataref for light 51: non
LTED: 1 : Bright Dataref for light 52: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 52: non
LTED: 1 : Hide Dataref for light 52: non
LTED: 1 : Bright Dataref for light 53: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 53: non
LTED: 1 : Hide Dataref for light 53: non
LTED: 1 : Bright Dataref for light 54: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 54: non
LTED: 1 : Hide Dataref for light 54: non
LTED: 1 : Bright Dataref for light 55: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 55: non
LTED: 1 : Hide Dataref for light 55: non
LTED: 1 : Bright Dataref for light 56: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 56: non
LTED: 1 : Hide Dataref for light 56: non
LTED: 1 : Bright Dataref for light 57: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 57: non
LTED: 1 : Hide Dataref for light 57: non
LTED: 1 : Bright Dataref for light 58: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 58: non
LTED: 1 : Hide Dataref for light 58: non
LTED: 1 : Bright Dataref for light 59: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 59: non
LTED: 1 : Hide Dataref for light 59: non
LTED: 1 : Bright Dataref for light 60: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 60: non
LTED: 1 : Hide Dataref for light 60: non
Please redownload and reinstall aircraft - may be some file was lost or broken. If no luck - you may contact me via skype j.a.romanov for direct help.
you guys are too complicated.....
64 (edited by rjarret 2023-04-27 14:11:06)
I love the 330. Tried it in XP12 for first time. 3 issues:
1. Wheels seem almost translucid - like nothing in the middle of the wheel (see attached photo)
2. Ground Handling dont show up. I call them both trought the FMC and the GH Menu but loader and staris never show up
3. On the FMC I cant delete ALT restrictions. If a SID has a restriction and then I am cleared to climb unrestricted I cant delete nor modify the restrictons on the FPLAN page
Using latest 12.0.3 and latest stable XP12
Are you use GHD for XP12 also, please?
Yes I am. For all other aicrafts works fine.
67
the best way in this case - call me via skype j.a.romanov
we will check this things online
68 (edited by rjarret 2023-10-03 20:40:48)
This hapens on the tires. XP12 latest stable!
http://jardesign.org/forum/img/m/10585/t/p1hbrk6pcnblk13q11a3p10ln8e14.png
hello
with last version 1.03
i dont  see The cab windshield is cloudy
cordially
After the JARDesign A330 V12.1.1 update, the logo light does not work, please return the light on vertical stabilizer.
