For some reason XP12 freezes when loading the A330. I can see the JarDesign Logo in the background and then it stops.
EDIT: Found the fix, delete the VR optimised.acf and the disable plugins.txt
Logfile:
0:02:37.522 I/FCG: Starting new flight in Aircraft/Airliners/JD330XP1200/a330.acf at Ramp N6
0:02:37.522 D/STM: Transitioning from state state_QuickFlightWizard to state_NormalLoading
WebFMC: Plane unloaded: 0
0:02:37.522 I/ACF: Loading airplane number 0 with Aircraft/Airliners/JD330XP1200/a330.acf
[BetterPushback-v0.52]: Dataref 'sim/weather/runway_friction' has been replaced. Please use the new name.
WebFMC: Plane loaded: 0
WebFMC: WebFMC main loop enabled
X-Camera: Scenic Flyer not found
Fetching plugins for B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins
[330/win.xpl]: Dataref 'sim/weather/temperature_ambient_c' has been replaced. Please use the new name.
[330/win.xpl]: Dataref 'sim/weather/precipitation_on_aircraft_ratio' has been replaced. Please use the new name.
Loaded: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins/330/win.xpl (jardesign.a330).
[330va/win.xpl]: Dataref 'sim/weather/temperature_ambient_c' has been replaced. Please use the new name.
[330va/win.xpl]: Dataref 'sim/weather/precipitation_on_aircraft_ratio' has been replaced. Please use the new name.
Loaded font: sys20 0 0
Loaded font: sys28 0 0
Loaded font: sys18 0 0
Loaded font: sys22 0 0
Loaded font: efb22 0 0
UUID:1bf26bc5-d893-4827-b1ec-412a1fbf7fa1
Loaded: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins/330va/win.xpl (jardesign.va).
3D Light plugin by JARDesign Ver.280321
Loaded: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins/CustomLight/win.xpl (jardesign.3d_lt).
[JD330 INFO]: Starting X-Plane SASL plugin v3.2.7+0b9658f [Commercial Edition]
[JD330 INFO]: JD330 | Aircraft | Start Full
Loaded: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins/SASL/64/win.xpl (1-sim JD330).
Loaded: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins/diagnost/win.xpl (jardesign.a330diagnostic).
FMGS: 0 : Ver.r79-051221 Oct 29 2022
FMGS: 0 : PluginPath=B:\X-Plane 12\Aircraft\Airliners\JD330XP1200\plugins\fmgs\
FMGS: 0 : AircraftPath=B:\X-Plane 12\Aircraft\Airliners\JD330XP1200\
FMGS: 0 : FMGS plugin will try to disable some plugins to avoid plugin conflicts:
FMGS: 0 : Marginal.GroundTraffic.LJLJ_Ljubliana was disabled by FMGS plugin to avoid plugin conflict.
FMGS: 0 : Marginal.GroundTraffic.EGHI_A_Southampton_Orbx was disabled by FMGS plugin to avoid plugin conflict.
FMGS: 0 : Marginal.GroundTraffic.EDDN Nuremberg 2 was disabled by FMGS plugin to avoid plugin conflict.
FMGS: 0 : CUSTOM DATAREF (int) ERROR (already exist): jd/fo/kill
FMGS: 0 : Hardware device VID:1103PID:1031 TCA Q-Eng 1&2 was NOT found
Loaded: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/plugins/fmgs/win.xpl (jardesign.fmgs).
[JD330 INFO]: Enabling...
[JD330 INFO]: Sound output device: OpenAL Soft
[JD330 INFO]: Sound input device: OpenAL Soft on Kopfhörermikrofon (Logitech H570e Stereo)
[JD330 INFO]: Initializing...
[JD330 INFO]: Path to module: B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/modules/main.key
[JD330 INFO]: Loading module...
[JD330 INFO]: [LUA]: loading module
[JD330 INFO]: [LUA]: "module" SASL components loading...
[JD330 INFO]: [LUA]: loading first
[JD330 INFO]: [LUA]: loading text
[JD330 INFO]: [LUA]: "text" Plate info: JD330-12.0.3
[JD330 INFO]: [LUA]: loading drf2tbl
[JD330 INFO]: [LUA]: loading light
[JD330 INFO]: [LUA]: loading animation
[JD330 INFO]: [LUA]: loading reload
[JD330 INFO]: [LUA]: loading draw_test
[JD330 INFO]: [LUA]: loading pfdcalc
[JD330 INFO]: [LUA]: loading fadec
[JD330 INFO]: [LUA]: loading ap
[JD330 INFO]: [LUA]: loading menu
[JD330 INFO]: [LUA]: loading sound_sys1
[JD330 INFO]: [LUA]: loading sound_fo
[JD330 INFO]: [LUA]: loading sound_st
[JD330 INFO]: [LUA]: loading sound_sys2
[JD330 INFO]: [LUA]: loading icerain
[JD330 INFO]: [LUA]: loading radio
[JD330 INFO]: [LUA]: loading phase
[JD330 INFO]: [LUA]: loading view
[JD330 INFO]: [LUA]: loading hotstart
[JD330 INFO]: [LUA]: loading textureLit
[JD330 INFO]: [LUA]: loading switchLit
[JD330 INFO]: [LUA]: loading prf_appr
[JD330 INFO]: [LUA]: loading radiopanel
[JD330 INFO]: [LUA]: loading gpws
[JD330 INFO]: [LUA]: loading tcas
[JD330 INFO]: [LUA]: loading pfddraw
[JD330 INFO]: [LUA]: loading isis
[JD330 INFO]: [LUA]: loading counter
[JD330 INFO]: [LUA]: loading sys_elec
[JD330 INFO]: [LUA]: loading sys_hyd
[JD330 INFO]: [LUA]: loading sys_bld
[JD330 (SASL)]: Dataref 'sim/weather/temperature_ambient_c' has been replaced. Please use the new name.
[JD330 INFO]: [LUA]: loading sys_cond
[JD330 INFO]: [LUA]: loading sys_drs
[JD330 INFO]: [LUA]: loading sys_oxy
[JD330 INFO]: [LUA]: loading sys_press
[JD330 INFO]: [LUA]: loading sys_whl
[JD330 (SASL)]: Dataref 'sim/weather/runway_friction' has been replaced. Please use the new name.
[JD330 INFO]: [LUA]: loading sys_fctl
[JD330 INFO]: [LUA]: loading sys_fuel
[JD330 INFO]: [LUA]: loading sys_eng
[JD330 INFO]: [LUA]: loading sys_eng_sys
[JD330 INFO]: [LUA]: loading sys_flaps
[JD330 INFO]: [LUA]: loading gnd_tow
[JD330 INFO]: [LUA]: loading clickable
[JD330 INFO]: [LUA]: loading bbox
[JD330 INFO]: [LUA]: loading audio
[JD330 INFO]: [LUA]: loading pax_text
[JD330 INFO]: [LUA]: loading cab_text
[JD330 INFO]: [LUA]: loading mech_text
[JD330 INFO]: [LUA]: loading last
[JD330 INFO]: [LUA]: loading diagnost
[JD330 INFO]: Loading cursors...
[JD330 INFO]: Module loaded
0:02:37.522 D/ATC: (): ClearForReuse
0:02:37.522 I/ATC: Created aircraft 0000020D8971A750 as p=0 ()
[SAM]: Dataref 'sim/weather/wind_direction_degt' has been replaced. Please use the new name.
[SAM]: Dataref 'sim/weather/wind_speed_kt' has been replaced. Please use the new name.
[SAM]: Dataref 'sim/weather/barometer_sealevel_inhg' has been replaced. Please use the new name.
0:02:37.522 I/OVR: Reading VR conf file: Aircraft/Airliners/JD330XP1200/a330_vrconfig.txt
0:02:37.522 W/VRCONFIG: Could not find vr config file: Aircraft/Airliners/JD330XP1200/a330_vrconfig.txt
0:02:37.522 W/VRCONFIG: VR Config data file for Aircraft/Airliners/JD330XP1200/a330_vrconfig.txt is not valid!
0:02:37.522 W/MANIPS: Could not find vr config file: Aircraft/Airliners/JD330XP1200/a330_vrconfig.txt
0:02:37.522 W/MANIPS: VR Manips file for Aircraft/Airliners/JD330XP1200/a330_vrconfig.txt is not valid!
[JD330 INFO]: [LUA]: "reload" Load Prefs from B:\X-Plane 12/Aircraft/Airliners/JD330XP1200/modules/Custom Module/save_pref.txt
[JD330 INFO]: [LUA]: "reload" JD330 version 412
[JD330 WARN]: [STACK]:| VQbKaJHFIi : DataRefsHandler::luaFetchDataRef: can't find dataref <jd/diagnost/reco>
[JD330 WARN]: [STACK]:| [string "4dac56b511b076a/data/init/initProperties"]:269 in function <globalPropertyi>
[JD330 WARN]: [STACK]:| [string "sound_fo"]:160 in function <update>
[JD330 WARN]: [STACK]:| [string "4dac56b511b076a/data/init/initProcessing"]:58 in function <updateComponent>
[JD330 WARN]: [STACK]:| [string "4dac56b511b076a/data/init/initProcessing"]:68 in function <updateAll>
[JD330 WARN]: [STACK]:| [string ".../initMain.secured"]:0 in function <update>
[JD330 WARN]: [STACK]:| ...
[JD330 INFO]: [LUA]: "sound_fo" Copilot plugin not detected
[JD330 INFO]: [LUA]: >>> zulu 13:42:36
[JD330 INFO]: [LUA]: baro alt=1069 / rad alt=1
[JD330 INFO]: [LUA]: air spd=0 / gnd spd=0 / mach=0
[JD330 INFO]: [LUA]: GW=143338 / FOB=54592 / CG=0
[JD330 INFO]: [LUA]: active wpt = 0
[JARDesign FMGS plugin]: Dataref 'sim/weather/temperature_ambient_c' has been replaced. Please use the new name.
FMGS: 0 : Cant Find Dataref: jd/weather/radar/on
FMGS: 0 : Cant Find Dataref: jd/ghd/execute
FMGS: 0 : Cant Find Dataref: jd/ghd/drfcontrol
FMGS: 0 : Cant Find Dataref: jd/ghd/select_00
FMGS: 0 : Cant Find Dataref: jd/ghd/select_01
FMGS: 0 : Cant Find Dataref: jd/ghd/select_02
FMGS: 0 : Cant Find Dataref: jd/ghd/select_03
FMGS: 0 : Cant Find Dataref: jd/ghd/select_04
FMGS: 0 : Cant Find Dataref: jd/ghd/select_05
FMGS: 0 : Cant Find Dataref: jd/ghd/select_06
FMGS: 0 : Cant Find Dataref: jd/ghd/select_07
FMGS: 0 : Cant Find Dataref: jd/ghd/select_08
FMGS: 0 : Cant Find Dataref: jd/ghd/select_09
FMGS: 0 : Cant Find Dataref: jd/ghd/select_10
FMGS: 0 : Cant Find Dataref: jd/ghd/select_11
FMGS: 0 : Cant Find Dataref: jd/ghd/select_12
FMGS: 0 : Cant Find Dataref: jd/ghd/select_13
FMGS: 0 : Cant Find Dataref: jd/ghd/select_14
FMGS: 0 : Cant Find Dataref: jd/ghd/select_15
FMGS: 0 : Cant Find Dataref: jd/ghd/select_16
FMGS: 0 : Cant Find Dataref: jd/ghd/select_17
FMGS: 0 : Cant Find Dataref: jd/ghd/select_18
FMGS: 0 : Cant Find Dataref: jd/ghd/select_19
FMGS: 0 : Cant Find Dataref: jd/ghd/select_20
FMGS: 0 : Cant Find Dataref: jd/ghd/select_21
FMGS: 0 : Cant Find Dataref: jd/ghd/select_22
FMGS: 0 : Cant Find Dataref: jd/ghd/select_23
FMGS: 0 : Cant Find Dataref: jd/ghd/select_24
FMGS: 0 : Cant Find Dataref: jd/ghd/select_25
FMGS: 0 : Navdata info:
FMGS: 0 : Provider N
FMGS: 0 : Cycle 2302
FMGS: 0 : Period 23FEB-23MAR
FMGS: 0 : inPath B:\X-Plane 12\/Custom Data/GNS430/navdata/
FMGS: 0 : procPath B:\X-Plane 12\/Custom Data/GNS430/navdata/Proc/
FMGS: 0 : Provider A
FMGS: 0 : Cycle 1410
FMGS: 0 : Period 18SEP-15OCT
FMGS: 0 : inPath B:\X-Plane 12\Aircraft\Airliners\JD330XP1200\plugins/fmgs/navdata/
FMGS: 0 : procPath B:\X-Plane 12\Aircraft\Airliners\JD330XP1200\plugins/fmgs/navdata/Proc/
FMGS: 0 : MessageGreen: Systems Created!
PLAY SOUND: ventLeft
PLAY SOUND: ventRght
PLAY SOUND: TableCloseL
PLAY SOUND: TableCloseR
PLAY SOUND: ParkBrake1
PLAY SOUND: ChangeHPALeft
PLAY SOUND: Prim1
PLAY SOUND: Sec1
PLAY SOUND: ADR1
PLAY SOUND: ADR3
PLAY SOUND: ADR2
PLAY SOUND: IR1
PLAY SOUND: IR3
PLAY SOUND: IR2
PLAY SOUND: lvrIdle
PLAY SOUND: lvrIdle
PLAY SOUND: nlgUp
PLAY SOUND: ei_base_clr
PLAY SOUND: ei_base_fan
PLAY SOUND: ei_hist_cl
PLAY SOUND: ei_hist_dr
PLAY SOUND: ei_midnoise
PLAY SOUND: e_bass3
PLAY SOUND: e_middo
PLAY SOUND: apu
PLAY SOUND: reverse
PLAY SOUND: ei_base_hi
PLAY SOUND: startBass
PLAY SOUND: startHitone
PLAY SOUND: startMidtone
PLAY SOUND: bassLo
PLAY SOUND: bassHi
PLAY SOUND: bassLo
PLAY SOUND: bassHi
PLAY SOUND: bassHi
PLAY SOUND: hitoneCl
PLAY SOUND: hitoneLo
PLAY SOUND: hitoneHi
PLAY SOUND: midTone
PLAY SOUND: power
PLAY SOUND: back
PLAY SOUND: eFan
PLAY SOUND: e_apueq_all
PLAY SOUND: e_max1_all
PLAY SOUND: e_max2_all
PLAY SOUND: e_taxi_all
PLAY SOUND: bassLo
PLAY SOUND: startSss
PLAY SOUND: bassLo
PLAY SOUND: apu
PLAY SOUND: Flaps0
PLAY SOUND: PbOff
WebFMC: IO thread running
WebFMC: Server version 2.1.0
WebFMC: Determining plane type
WebFMC: acf_ICAO: 'A330', acf_author: 'JARDESIGN (C)', acf_descrip: 'Airbus A330-200 by JARDesign'
WebFMC: Detected JarDesign JD330
WebFMC: Setup start
WebFMC: Setup end
0:03:41.036 I/WIN: Opened window menu bar
FMGS: 0 : Tiller axis No=7
PLAY SOUND: NdMode
PLAY SOUND: NdRange
PLAY SOUND: AdfVor1
PLAY SOUND: AdfVor2
PLAY SOUND: ChangeHPARight
PLAY SOUND: BaroRot
PLAY SOUND: AltChengeLeft
PLAY SOUND: AltRot
PLAY SOUND: Fd
PLAY SOUND: CrewSupply
PLAY SOUND: Sys
PLAY SOUND: Terr
PLAY SOUND: Sys
PLAY SOUND: GSMode
PLAY SOUND: FlapMode
PLAY SOUND: gEngPumpOff1
PLAY SOUND: gElPumpOff1
PLAY SOUND: bEngPumpOff1
PLAY SOUND: bElPumpOff1
PLAY SOUND: yEngPumpOff1
PLAY SOUND: yElPumpOff1
PLAY SOUND: gEngPumpOff2
PLAY SOUND: CtrL
PLAY SOUND: CtrR
PLAY SOUND: StbyL
PLAY SOUND: StbyR
PLAY SOUND: Galley
PLAY SOUND: Commercial
PLAY SOUND: ApuGen
PLAY SOUND: Gen1
PLAY SOUND: Gen2
PLAY SOUND: Pack1
PLAY SOUND: Pack2
PLAY SOUND: HotAir1
PLAY SOUND: HotAir2
PLAY SOUND: Eng1Bleed
PLAY SOUND: Eng2Bleed
PLAY SOUND: PackFlow
PLAY SOUND: XBleedSel
PLAY SOUND: ElevSel
PLAY SOUND: ValvSel
PLAY SOUND: Compass
PLAY SOUND: Ctl
PLAY SOUND: Prim2
PLAY SOUND: Sec2
PLAY SOUND: Prim3
PLAY SOUND: TurbDamp
PLAY SOUND: Lever
PLAY SOUND: PushKnob
PLAY SOUND: ASkid
PLAY SOUND: StartTime
PLAY SOUND: MapLeft
PLAY SOUND: MapRight
PLAY SOUND: Console
PLAY SOUND: Vhf1
PLAY SOUND: Vhf2
PLAY SOUND: Int
PLAY SOUND: Cab
PLAY SOUND: Mkr
PLAY SOUND: Pa
PLAY SOUND: IntRad
PLAY SOUND: AbvBlv
PLAY SOUND: TcasCodeSel
PLAY SOUND: FwdBtn
PLAY SOUND: AftBtn
PLAY SOUND: BlkBtn
PLAY SOUND: HotAir
PLAY SOUND: PreselBtn
PLAY SOUND: CoolingSel
PLAY SOUND: nlgDn
PLAY SOUND: Runway
PLAY SOUND: Roll
PLAY SOUND: LgDown
[JD330 INFO]: [LUA]: lat wait = NAV
PLAY SOUND: faa_02_drsclose
PLAY SOUND: OptPb
0:04:06.694 I/TEX: Target scale moved to 16.000000
PLAY SOUND: PbOn
0:04:06.756 I/ATC: Removing parking 'New Ramp Start 3' at XEDSC - can't taxi to runway 27.
0:04:06.756 I/ATC: Removing parking 'New Ramp Start 3' at XEDSC - can't taxi to runway 09.
LTED: 1 : isDrfConnectDone == 0
LTED: 1 : Bright Dataref for light 0: sim/custom/xap/light/ovh_cent
LTED: 1 : PwrOn Dataref for light 0: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 0: non
LTED: 1 : Bright Dataref for light 1: sim/custom/xap/light/ovh_cent
LTED: 1 : PwrOn Dataref for light 1: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 1: non
LTED: 1 : Bright Dataref for light 2: sim/custom/xap/light/ovh_left
LTED: 1 : PwrOn Dataref for light 2: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 2: non
LTED: 1 : Bright Dataref for light 3: sim/custom/xap/light/ovh_left
LTED: 1 : PwrOn Dataref for light 3: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 3: non
LTED: 1 : Bright Dataref for light 4: sim/custom/xap/light/ovh_rght
LTED: 1 : PwrOn Dataref for light 4: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 4: non
LTED: 1 : Bright Dataref for light 5: sim/custom/xap/light/ovh_left
LTED: 1 : PwrOn Dataref for light 5: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 5: non
LTED: 1 : Bright Dataref for light 6: sim/custom/xap/light/pan_flood
LTED: 1 : PwrOn Dataref for light 6: sim/custom/xap/elec/dcess
LTED: 1 : Hide Dataref for light 6: non
LTED: 1 : Bright Dataref for light 7: sim/custom/xap/light/pan_flood
LTED: 1 : PwrOn Dataref for light 7: sim/custom/xap/elec/dcess
LTED: 1 : Hide Dataref for light 7: non
LTED: 1 : Bright Dataref for light 8: sim/custom/xap/light/pan_flood
LTED: 1 : PwrOn Dataref for light 8: sim/custom/xap/elec/dcess
LTED: 1 : Hide Dataref for light 8: non
LTED: 1 : Bright Dataref for light 9: sim/custom/xap/light/pan_flood
LTED: 1 : PwrOn Dataref for light 9: sim/custom/xap/elec/dcess
LTED: 1 : Hide Dataref for light 9: non
LTED: 1 : Bright Dataref for light 10: sim/custom/xap/light/map_left
LTED: 1 : PwrOn Dataref for light 10: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 10: non
LTED: 1 : Bright Dataref for light 11: sim/custom/xap/light/map_rght
LTED: 1 : PwrOn Dataref for light 11: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 11: non
LTED: 1 : Bright Dataref for light 12: sim/custom/xap/light/console
LTED: 1 : PwrOn Dataref for light 12: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 12: non
LTED: 1 : Bright Dataref for light 13: sim/custom/xap/light/console
LTED: 1 : PwrOn Dataref for light 13: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 13: non
LTED: 1 : Bright Dataref for light 14: sim/custom/xap/light/console
LTED: 1 : PwrOn Dataref for light 14: sim/custom/xap/elec/dc1
LTED: 1 : Hide Dataref for light 14: non
LTED: 1 : Bright Dataref for light 15: sim/custom/xap/light/console
LTED: 1 : PwrOn Dataref for light 15: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 15: non
LTED: 1 : Bright Dataref for light 16: sim/custom/xap/light/console
LTED: 1 : PwrOn Dataref for light 16: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 16: non
LTED: 1 : Bright Dataref for light 17: sim/custom/xap/light/console
LTED: 1 : PwrOn Dataref for light 17: sim/custom/xap/elec/dc2
LTED: 1 : Hide Dataref for light 17: non
LTED: 1 : Bright Dataref for light 18: sim/custom/xap/light/dome_out
LTED: 1 : PwrOn Dataref for light 18: non
LTED: 1 : Hide Dataref for light 18: non
LTED: 1 : Bright Dataref for light 19: sim/custom/xap/light/dome_out
LTED: 1 : PwrOn Dataref for light 19: non
LTED: 1 : Hide Dataref for light 19: non
LTED: 1 : Bright Dataref for light 20: sim/custom/xap/lght_upd
LTED: 1 : PwrOn Dataref for light 20: sim/custom/xap/elec/acess
LTED: 1 : Hide Dataref for light 20: non
LTED: 1 : Bright Dataref for light 21: sim/custom/xap/lght_dnd
LTED: 1 : PwrOn Dataref for light 21: sim/custom/xap/elec/ac1
LTED: 1 : Hide Dataref for light 21: non
LTED: 1 : Bright Dataref for light 22: sim/custom/xap/lght_dnd
LTED: 1 : PwrOn Dataref for light 22: sim/custom/xap/elec/ac1
LTED: 1 : Hide Dataref for light 22: non
LTED: 1 : Bright Dataref for light 23: sim/custom/xap/light/compass
LTED: 1 : PwrOn Dataref for light 23: sim/custom/xap/elec/dcess
LTED: 1 : Hide Dataref for light 23: non
LTED: 1 : Bright Dataref for light 24: sim/custom/xap/lght_pfd
LTED: 1 : PwrOn Dataref for light 24: sim/custom/xap/elec/acess
LTED: 1 : Hide Dataref for light 24: non
LTED: 1 : Bright Dataref for light 25: sim/custom/xap/lght_pfd
LTED: 1 : PwrOn Dataref for light 25: sim/custom/xap/elec/acess
LTED: 1 : Hide Dataref for light 25: non
LTED: 1 : Bright Dataref for light 26: sim/custom/xap/lght_nd
LTED: 1 : PwrOn Dataref for light 26: sim/custom/xap/elec/acess_shed
LTED: 1 : Hide Dataref for light 26: non
LTED: 1 : Bright Dataref for light 27: sim/custom/xap/lght_nd
LTED: 1 : PwrOn Dataref for light 27: sim/custom/xap/elec/acess_shed
LTED: 1 : Hide Dataref for light 27: non
LTED: 1 : Bright Dataref for light 28: non
LTED: 1 : PwrOn Dataref for light 28: non
LTED: 1 : Hide Dataref for light 28: non
LTED: 1 : Bright Dataref for light 29: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 29: non
LTED: 1 : Hide Dataref for light 29: non
LTED: 1 : Bright Dataref for light 30: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 30: non
LTED: 1 : Hide Dataref for light 30: non
LTED: 1 : Bright Dataref for light 31: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 31: non
LTED: 1 : Hide Dataref for light 31: non
LTED: 1 : Bright Dataref for light 32: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 32: non
LTED: 1 : Hide Dataref for light 32: non
LTED: 1 : Bright Dataref for light 33: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 33: non
LTED: 1 : Hide Dataref for light 33: non
LTED: 1 : Bright Dataref for light 34: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 34: non
LTED: 1 : Hide Dataref for light 34: non
LTED: 1 : Bright Dataref for light 35: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 35: non
LTED: 1 : Hide Dataref for light 35: non
LTED: 1 : Bright Dataref for light 36: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 36: non
LTED: 1 : Hide Dataref for light 36: non
LTED: 1 : Bright Dataref for light 37: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 37: non
LTED: 1 : Hide Dataref for light 37: non
LTED: 1 : Bright Dataref for light 38: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 38: non
LTED: 1 : Hide Dataref for light 38: non
LTED: 1 : Bright Dataref for light 39: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 39: non
LTED: 1 : Hide Dataref for light 39: non
LTED: 1 : Bright Dataref for light 40: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 40: non
LTED: 1 : Hide Dataref for light 40: non
LTED: 1 : Bright Dataref for light 41: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 41: non
LTED: 1 : Hide Dataref for light 41: non
LTED: 1 : Bright Dataref for light 42: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 42: non
LTED: 1 : Hide Dataref for light 42: non
LTED: 1 : Bright Dataref for light 43: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 43: non
LTED: 1 : Hide Dataref for light 43: non
LTED: 1 : Bright Dataref for light 44: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 44: non
LTED: 1 : Hide Dataref for light 44: non
LTED: 1 : Bright Dataref for light 45: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 45: non
LTED: 1 : Hide Dataref for light 45: non
LTED: 1 : Bright Dataref for light 46: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 46: non
LTED: 1 : Hide Dataref for light 46: non
LTED: 1 : Bright Dataref for light 47: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 47: non
LTED: 1 : Hide Dataref for light 47: non
LTED: 1 : Bright Dataref for light 48: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 48: non
LTED: 1 : Hide Dataref for light 48: non
LTED: 1 : Bright Dataref for light 49: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 49: non
LTED: 1 : Hide Dataref for light 49: non
LTED: 1 : Bright Dataref for light 50: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 50: non
LTED: 1 : Hide Dataref for light 50: non
LTED: 1 : Bright Dataref for light 51: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 51: non
LTED: 1 : Hide Dataref for light 51: non
LTED: 1 : Bright Dataref for light 52: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 52: non
LTED: 1 : Hide Dataref for light 52: non
LTED: 1 : Bright Dataref for light 53: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 53: non
LTED: 1 : Hide Dataref for light 53: non
LTED: 1 : Bright Dataref for light 54: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 54: non
LTED: 1 : Hide Dataref for light 54: non
LTED: 1 : Bright Dataref for light 55: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 55: non
LTED: 1 : Hide Dataref for light 55: non
LTED: 1 : Bright Dataref for light 56: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 56: non
LTED: 1 : Hide Dataref for light 56: non
LTED: 1 : Bright Dataref for light 57: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 57: non
LTED: 1 : Hide Dataref for light 57: non
LTED: 1 : Bright Dataref for light 58: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 58: non
LTED: 1 : Hide Dataref for light 58: non
LTED: 1 : Bright Dataref for light 59: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 59: non
LTED: 1 : Hide Dataref for light 59: non
LTED: 1 : Bright Dataref for light 60: jd/light/cabin
LTED: 1 : PwrOn Dataref for light 60: non
LTED: 1 : Hide Dataref for light 60: non
