Topic: XP12.00 JD330 (beta)
http://jardesign.org/forum/img/m/22/t/p1ggpdd70dbi01p6q1ilk1ehpjn43.png
JD330 for X-Plane 12.00b
(so, on this stage, this is beta aircraft for beta simulator)
What new:
v.12.0.1 (beta 1)
+ XP12 compatible
+ flight model reworked
+ load&weight system reworked
+ lights reworked
+ sounds reworked
..and so on to make aircraft compatible with XP12
v.12.0.2
+Aprot and Amax calculation fixed
v.12.0.3
+flightmodel improved
+textures improved
Download link for Actual XP12 version:
http://www.jardesign.org/downloads/A330 … 021122.zip
For macOS Catalina / BigSur users - please follow instruction:
Download link to updated Ground Handling plugin to be well-compatible with XP12.00
(no registration/serial need to use with JD330)
http://jardesign.org/forum/viewtopic.php?id=18947
  - be sure, that you use X-Plane 12.00
  - copy unziped "JD330XP1200" folder to ..\X-Plane 12\Aircraft\ folder
  - start X-Plane 12 and open a330, activation window is going to show up
  - enter your serial key (you may use exist serial from "JD330 for X-Plane 11"), click NEXT and after a successful activation reopen aircraft via X-Plane menu
(create it if need)
Thank you!!!!
Re: XP12.00 JD330 (beta)
reserved
reserved
4 (edited by stateless_01 2022-10-31 16:41:40)
i have downloaded the new version vor XP12. Everytime I try to load a new flight with the JD330, XP freezes after minutes of the loading screen at "preparing world".
I have tried it with the standard c172, toliss a319, at the same airport - no errors. Issue is reproducable.
The log.txt is attached.
edit:
I attached a second log of another try.
edit:
On First loading - this is normal, aircraft may convert navdata to "fast loaded" format. It may take half minute to minutes for some computers.
Unstable operation of the autopilot in different modes in different ways, in climbing, on a cruise, descent and landing.
it shows up very well on a cruise, we fly smoothly, but we see it to the right, then to the left.
p.s. I will try to attach a short video, 20 seconds, with PFD and MFD
PS There is no video to add, I will try through a third-party resource.
thank you in advance
https://disk.yandex.ru/i/3UwCUcZob9xn5A
beta 2 just posted
Alfa protection and alfa max calculation (and drawing on PFD) fixed
Johnny_3volta wrote:
Thanks for this video! What weather conditions was? Low or hi turbulense? Permanent wind or intensive direction change?
9 (edited by stateless_01 2022-11-01 08:24:20)
edit:
Hello and thanks for answer,
i waited as long as 15-20 minutes on several tries, it does not load.
edit:
You may call me skype j.a.romanov directly - we will try to find a reason
Thank you! I will be home around 19-20h00 zulu tonight. Would that suit you?
You may just send me message before call
v.12.0.3
+textures improved
14 (edited by rafalec 2022-11-02 14:30:34)
v.12.0.3
+textures improved
Thank you mister Romanov for this XP12 update , excellent job
maybe im missing something but i cant control the pitch trim
You need just enter THS position on preflight stage to MCDU PERF page (in fact - click on it with empty scratchpad to automatic calculation). All other THS moving will happen in auto mode during flight.
17 (edited by dima_gurec 2022-11-04 16:19:22)
Hi.Can you please tell me if Blue Sky Star sounds are compatible?How should I install BBS sounds now???
Look like you need contact BSS support for this. Some BSS sounds will not work cause X-Plane datarefs was changed. I think some changes in BSS pack need.
Tell me please, and in the future it is planned to adapt the model completely under XP 12? What would be a beautiful effect of drops on the windows, and what would the plane itself get wet?
raindrops effect already included into actual version
Hello..
Thank you in advance for realizing the A330 Jar design for x-plane 12. I have downloaded Aircraft at the link in the description.
After I tried to use it and flew towards cruising, the plane every 3 minutes or so always tilted left and right as if blown by the wind. Even though I have used real weather and manually. However, always shake left and right every 4-5 minutes.
How could it happen like this? Is my A330 not up to date? How to update to v.12.0.3? I hope there is a solution to this problem.
Thank you, Best regards
humblepilot.official wrote:
Hello..
Know about this issue and will finetune 330 flightmodel with XP12 release, cause XP12 flightmodel may be changed during beta-test process too.
Well. I'm really looking forward to that. Hopefully the latest update will come out soon to be better.. Thank you
I'm flying to v.12.0.3, I'm flying a long-distance flight, a little more than 6 hours, the tanks are more than half full, the warning is "trim tk xfr".
I don't think it's a mistake.
In version 01, it was unstable to fly, jerked left to right, now version 03, the speed is unstable. Both in "managed" and "selected", the set speed is 260, and the actual speed ranges +/- 5-7 knots, then up, then down.
also, on ecam before, "t.o.config" was marked by itself, automatically, now it is not, and when pressed for a fraction of a second it shows an error about the trimmer, and in the mcdu in the take-off perfomance where the flaps and the trimmer, calculates, in my case, 1/0.1up, the trimmer wheel is in place, does not wind up, and on the ecam the trimmer shows "0"
by the way, tell me!
how to correctly add points with geographical coordinates to the flight plan, for example, over the ocean. The exported plan with simrief with such points gives an error, you have to make it manually, tried to make it in different formats, does not accept DCT as a temporary solution, at 1200nm
