Topic: XP12.00 JD330 (beta)
JD330 for X-Plane 12.00b
(so, on this stage, this is beta aircraft for beta simulator)
What new:
v.12.0.1 (beta 1)
+ XP12 compatible
+ flight model reworked
+ load&weight system reworked
+ lights reworked
+ sounds reworked
..and so on to make aircraft compatible with XP12
v.12.0.2
+Aprot and Amax calculation fixed
v.12.0.3
+flightmodel improved
+textures improved
Download link for Actual XP12 version:
http://www.jardesign.org/downloads/A330 … 021122.zip
For macOS Catalina / BigSur users - please follow instruction:
Download link to updated Ground Handling plugin to be well-compatible with XP12.00
(no registration/serial need to use with JD330)
http://jardesign.org/forum/viewtopic.php?id=18947
- be sure, that you use X-Plane 12.00
- copy unziped "JD330XP1200" folder to ..\X-Plane 12\Aircraft\ folder
- start X-Plane 12 and open a330, activation window is going to show up
- enter your serial key (you may use exist serial from "JD330 for X-Plane 11"), click NEXT and after a successful activation reopen aircraft via X-Plane menu
(create it if need)
Please care about information what you will post here and try to determinate reason if issues happen - sure, he interesting in aircraft test and troubles but want to avoid work with "pilot" issues.
Thank you!!!!
