Topic: GHD v5 for X-Plane 12
Ground Handling actual version for X-Plane 12
http://jardesign.org/forum/img/m/22/t/p1gcp4pir618cj1vat1fmq1rltpat3.jpg
Whats New:
v.150923
+ FF757 sets updated
v.090922
+ X-Plane 12 compatible
+ Sets auto-update add
+ 3D object improved
v.090922
+ Crash with default Cessna-172 fixed
So.. GHD first build for XP12 is ready. Work with default A330 and B737 for free, no registration need. The same with JARDesign aircraft(s). Registred version will work with many popular X-Plane airliners. XP12 version of GHD get new auto-update system for aircraft sets (allow download new or updated set in auto mode), updated 3D objects, improved set Editor. As for now - it already include sets for XP12 versions for default A330 and B737, FF aircraft, Felis 747, Toliss A340. We will add new sets (to out server) for XP12 versions of popular aircraft(s) as soon as we will see updates.
Download link http://jardesign.org/gndserv/download/G … 150923.zip
- Please follow Manual.pdf inside ZIP
- Please not mix with old version
HOW TO USE:
- Please follow Manual inside ZIP
HOW TO UPDATE OLD CUSTOM-MADE .set for Version 5:
- put your old custom .set file to ../X-Plane/Resources/plugins/GndHandling/Sets/Custom
- load aircraft what should work with this .set
- Open Control Widget using Menu->Plugins->GroundHandling->Show Control Widget
- As you see may be all cars have wrong heading
- Click DRIVE ALL and wait until all cars will take place and be solid
- Open X-Plane settings and assign some Keyboard Key to jd/ghd/CommandSetPoint
- Select Menu->Plugins->GroundHandling->Tools->Draw Countur
- put mouse pointer to aircraft nose and use selected Keyboard Key to set first point
- put mouse to next point along aircraft countur and use selected Keyboard Key to set next point
- follow right side of aircraft to draw countur and set last point on the tail aircraft center
- Select Menu->Plugins->GroundHandling->Tools->Save Countur to save it to .set
- Reload aircraft and check result
- Redraw countur if need
If you want post own liveries for GHD, you may use www.simliveries.com
Re: GHD v5 for X-Plane 12
Thank you for the update.
Could you please make a Apple M1 compatible version.
I use X-Plane on MacOS M1 computer without Rosetta.
Thank you.
Best regards.
Pierre (registered GHD user.)
XP12 crashes when I load Phenom 300 airplane (no sets in GHD), Zibo works.
It doesn't work for me.
CTD as soon as default Cessna appeared. I made several attempts and always a crash of Xplane 12.
Everything works normally again when I remove GHD from the directory
Same for me, XP12 crash with this latest version. Have checked the log but did not found related to GHD
Thanks for report. Please update this .xpl files in your GHD folder
Thank you.
Best regards.
I am afraid - it it is not possible right now. I will back to this issue some later, but not sure.
Can't use liveries in v5-XP12? Not showing in the menu...
http://jardesign.org/forum/img/m/30/t/p1gcsnl4jr144q1a4invg1e0s14mr3.jpg
Works like a charm.
It would be great if you could make the behavior of "drive away" and "drive up inhibit" on the state of the parking brake optional. E.g. the standard flow of the A320's cockpit preparation asks for the release of the parking brake and all ground services are gone 8-(.
With not registered version - you can't change liveries.
hotbso wrote:
Works like a charm.
Hmm.. Let me think about this..
13 (edited by flightime56 2022-09-15 23:08:08)
It is registered?  No worries, it is now working... thanks
14 (edited by flightime56 2022-09-16 00:27:13)
I'm still having problems with the liveries? They are showing in the menu, but not changing to a new livery?
I have done a complete re-register of the plugin, the liveries show, but don't work?
Hmm.. this is some thing special - may be I need look on this via Skype. If possible - my Skype j.a.romanov
I don't do skype but moved on to Signal? Sorry Eugeny, anything I can send you?
Another way - just wait - may be one more user will get the same issue and I will check the situation on his computer online.
18 (edited by agonyair 2022-10-14 22:05:31)
http://jardesign.org/forum/img/m/11050/t/p1gfc8es0a10n24iuhmn1qs61qgu3.png@flighttime56, to get the liveries to work first just drive up the units that you want. Then change the liveries. It seems to work for me this way. Good Luck!
19 (edited by c.ozancin 2023-07-09 17:42:49)
I just purchased the GHD for X-Plane 12. I am running on Mac (m2 max) using rosetta. I received receipt with serial number. I try registering using the serial number and my email address and it fails.
Did I wast my money on this?
Update:
Decided to try registering one more time and now it crashes. At this point I am very frustrated. I have removed GHD from my X-Plane install and now everything works as expected.
Update:
Please contact www.support.jardesign.org with your serial key or directly via skype j.a.romanov - we will heck and inform you
any plans for a ARM64 or universal binary ?
Mike
Thank you.
Best regards.
I was just about to ask this as well, as I'm now a Mac Studio M2 Max user, would love native version of this.... any thoughts J.A.Romanov ?
Emma Bentley
Apple Mac Studio M2 Max , 38 Core GPU
HeyHo guys, same. Just bought the product and sadly it doesnt work on my M2 Pro Mac. Not even with rosetta on x64. An update to make it work would be great!
best wishes and happy holidays
When the fuel truck is connected at A330, the fuel pannel doesn,t come any more. Is it normal on this version.
THKS
KT
Unlock a world of casual fun and excitement with the premier dating site.
Harmony of intimacy, uninhibitedness with mutual consent
Genuine Females
Exemplary casual Dating
