Re: XP11.50 JD330 v.4.4
for some time my A330 didn't work well.
The Flight Director doesn't work and the aircraft is not following the flight plan.
Could you please help ?
Many thanks
Maxime
There is a big chance what it is some special problem on user side, cause most users have not this problem. The reason may be:
1. An affect of some another installed plugin. There is simple solution in this case to check - load Cessna 172, open X-Plane Menu->Plugins->Plugin Admin to disable ALL plugins, next - load JD320/330. If issue gone - one of your plugin conflict with Airbus FMGS.
2. Problem may come from hardware, from your joystick. Please check - if some of your joystick switch assigned to "Avionics OFF/ON" - it should be stay in ON position when you run JD320/330.
3. Something wrong in settings. To check this faster - please find "Output" folder inside your X-Plane folder and rename it to "OutputOld". Next - run X-Plane. In this case X-Plane will create new and clean "Output" folder with clean settings. Please calibrate your joysticks and check JD320/330 autopilot. If issue gone - some settings was a reason.
thank you very much for your answer,
I found the problem, I have to activate the avionics on.
But I don't know where I can activate it.
can you help me?
many thank
Maxime
can you help me?
many thank
Maxime
Hmm.. Look like you need to open your X-Plane settings->Joystick and check is any switch set to Avionics On/Off
Hi. I have had a couple of issues (actually an issue and a question) with the a330 in VR. I posted in the X-Plane forum, but not sure how 'monitored' that is. Hope it's Ok simply to post links here, rather than duplicate? Thanks!
https://forums.x-plane.org/index.php?/f … ems-in-vr/
https://forums.x-plane.org/index.php?/f … nt-2376489
For actual version you may use only 2D loadsheet and it can not be visible in 3D VR. So, no another way, sorry.
About landing gear visible - it hided in internal mode to improve framerate. Sadly, for 3D VR - X-Plane not recognise what mode we are in now and show/hide objects not work correct. If you will delete "hide dataref" in PlaneMaker (Menu->Standard->MiscObjects) for 330_gear.OBJ - no more "hide" effect will appear.
82 (edited by martinlest 2022-07-03 14:34:01)
Great, thank you. My fps (in VR) seems unchanged after the edit..
Would it really not be possible though to get the useful Refuel Gauge currently in the a320 O/H panel into the a330 too.. is that what you are saying (can't see why, if so)? I wasn't referring to the loadsheet...
83
Yes, for actual version - this is not possible.
Ok, maybe for next version... :-)
.. while I am here :-) .. I have had the BSS sound packs for a long time now, but have always noticed that in external view especially there is almost no sound at all.. there is something there but so subliminal as to be almost inaudible, even when you set the BSS plugin slider to 100% for external.
I read that there is a fix for this (??). Anyone know how to make the BSS sounds worth the money I paid for them? (The a320 work better). Thanks.
86 (edited by humblepilot.official 2022-07-12 13:18:02)
Hallo..
Unfortunately after landing,it is not possible to switch off trust reversers.
And trottle also not working.
Using V4.4R2
Thanks before
Доброго времени суток, приобрёл A330, но опять столкнулся с проблемами звуков. Подскажите, где их можно взять, можно ли ссылку?
Заранее спасибо!
88 (edited by jvarela-forum 2022-08-15 07:55:16)
Since I upgraded to MacOS Monterey 12.5 I am unable to load the A330 from JARDesign. The loading stops after loading the aircraft and the scenery. According to the attached log file, the culprit is the JARDesign FMGS plugin, which is crashing X-Plane 11. I am using the latest version of the A330 (4.4r2). I tried to disable all the plugins, including the CEF plugin from Laminar Research, but that did not help. I just updated to the new AIRAC from Navigraph, but I don't know if that is a reason for it.
JD320/330 should work well under Catalina/BigSur/Monteray. Please redownload JD320/330 and reinstall it from:
http://jardesign.org/forum/viewforum.php?id=44
Next, please follow this instruction***:
http://jardesign.org/forum/viewtopic.ph … 793#p31793
*** Or directly this steps:
1. Open MAC OS System Preferences -> Security&Privacy -> Accesibility and check X-Plane already there and X-Plane checkbox is checked.
2. Install aircraft and load aircraft: MAC OS will offer you some choice and every time:
- when you have OPEN option -> click OPEN and next click ALLOW ANYWAY at System Preferences -> Security&Privacy -> General tab
- when you have CANCEL option -> click CANCEL and next click ALLOW ANYWAY at System Preferences -> Security&Privacy -> General tab
3. So, after several clicks aircraft will load. Next use X-Plane menu and select DEVELOPER -> RELOAD AIRCRAFT
4. During second aircraft loading MAC OS will offer you some choice and every time:
5. You will see activation box. Please input your serial key and select activate.
6. Reload aircraft.
If no luck - Seems like it's some sort of special issue. Sure, you can contact me via skype j.a.romanov for direct help - we will check this issue online.
It seems as though the problem was that the metal driver option was turned off. That solved the problem.
Thanks,
João Varela
When I activate the thrust reverse, the navigation screen turns black and the RAT is also activated. When I disable the thrust reverse, everything works okay. After the turn around (without simulator restart) I want to depart again, but the navigation screen turns again black once airborne.. Once landed, it turns on.... Some fix?
Power lost with low airspeed if RAT was activated. Why it was activated in your case? You may open Log.txt file just after this happen and read reason for RAT activation there, please.
just buy xplane 12. Jardesign compatibility?
Actual version is not compatible with XP12 early beta. We work on this.
95
When release the new version?
96
After 2 Weeks no news a330 Xplane 12
Not ready - work on update. Cant guess release data.
98 (edited by alain.bo 2022-10-01 16:33:16)
error
Hello, I have downloaded the JARDesign A330 a few months ago and I am very happy with it...
Since a few days, however, , I often (not always) experience problems with my pitch trim setting, just after take-off. I type in the calculated setting into the MCDU and the pitch trim wheel starts adjusting. After double-checking the calculated value in the load sheet with the actual setting on the F/CTL page I find no discrepancy. However, just after take-off, I receive an error message that the actual setting disagrees with the MCDU data.
If I want to cancel and retract the flaps after reaching s-speed, a master warning alarm is activated.
Of course, I can cancel all the messages a continue flying. But I wonder how this situation can appear in the first place. Is it possible that I oversteer / pull the stick too far back which could cause the problem? Or does somebody else experience this problem as well?
Thanks for your support...
100 (edited by rmakhene 2022-10-23 15:57:51)
I downloaded and updated the latest version of the A330 for X-Plane 12.  I'm experiencing a couple of problems:
1.    I'm unable to start the engines going through the regular engine startup procedure
2.    the MCDU does not work properly. The origin airport always comes up as PPOS, and I am unable to load my route and departure procedures (SIDs).
I have done the same for the engine start procedure and route loading on the old version on X plane 11 and no problems whatsoever.
Any recommendations on how to fix these problems?
