Topic: XP11.50 JD330 v.4.4
http://jardesign.org/forum/img/m/22/t/p1e57cq5ln9odvjslepct41o5h3.png
JD330 for X-Plane 11.50
What new:
v.4.4R1
+ EPR indication improved
+ External lights improved
+ FCU VVI knob rotation fixedd
+ Diagnostic plugin fixed
+ CLB position settings add
+ Updater add
+ Liveries installer add
+ Diagnostic plugin improved
+ .pdf Manual add
Download link for version 4.4r1:
http://jardesign.org/a330/download/inst … 0_4410.zip
Download link for old stable version 4.3r2:
http://jardesign.org/a330/download/inst … 0_4320.zip
For macOS Catalina / BigSur users - please follow instruction:
Download link to updated Ground Handling plugin to be well-compatible with XP11.50
http://jardesign.org/forum/viewtopic.php?id=11824
  - be sure, that you use X-Plane 11.41-11.53
  - copy unziped "JD330XP11" folder to ..\X-Plane 11\Aircraft\ folder
(create it if need)
Thank you!!!!
Re: XP11.50 JD330 v.4.4
reserve
reserve
From Vancouver to Shenzhen
Or Dubai to Mexico City
Will appear
5 (edited by Darko24 2021-11-10 08:46:58)
Load this new version  4.4r1, register and then update as show on screen. MCDU not working, whatever buttons I push no action.
EDIT:
Try to load without Vulkan and then works, go again to Vulkan and now works. Sorry for false alarm.
EDIT:
Ok, please let me know if problem will come.
I just love the JD heavy Airbus, thank you for the continual improvements - may I report a very slight issue with JD330-V4.4B3 ?
I have noticed that if the spoiler lever is touched, for instance armed for takeoff, after the spoiler is disarmed, the aircraft will shake as if the spoilers are slightly extended. I check that the spoiler lever is fully forward and a visual check show they are not deployed, but even if I arm/disarm them again, the aircraft continues to shudder.
If I switch off XPRealistic speedbrake effect, the shuddering stops.
The obvious thing is to switch the effect off, but all other aircraft including other JAR Design Airbus are fine with XPRealistic and their spoilers, so it is as if something in the A330 is not reporting that the spoilers are retracted.
Thank you again.
Fabio
8 (edited by peter69 2021-11-12 04:44:47)
The figures are very different can somebody help me out here i have version JD330-V4.4B3
Peter
Peter
Everything is OK. What, do you see diferrent ?
For example pax figures and payload
Peter
Peter
You must put values as you want to be with sign + or -. Take your choice how many pax do you load ( depend on buying tickets smile ) and how many cargo you have to load, and how many fuel need.  Pilot must know this numbers and pu the numbers in MCDU.
Darko
Love your A330, have tried almost all versions and it keeps getting better.
Also love the copilot Linda add-on! But have a small request: Linda also makes the callout V1, that should be left to the Airbus itself, like it is in real life..
Very nice plane though, keep coming with the updates, Thank You Sir!
Agree about V1 callout
14 (edited by edge33 2021-11-19 16:57:50)
I noticed it crashes the sim when clicking the update button in this screen after a flight plan has been loaded from the mcdu:
http://jardesign.org/forum/img/m/10341/t/p1fksi3m9u8pk1tsr1efcqpa18eg3.png
http://jardesign.org/forum/img/m/12714/t/p1fkst03881tttddvosics2195c3.jpg
Flying across the intercontinental region will be like this
http://jardesign.org/forum/img/m/12714/t/p1fkst2cn71duaegb1c0h1u2p99s3.jpg
Several versions are like this
i release new version v4.4r3
i don't know why i takeoff the a330 shows me pich trm wrong i try many many times
please give me help
wrong like the photo
here is wrong
please give me help
Not good idea to just guess.. That THS takeoff position was set (by pilot) into MCDU Perf Page? And what fact THS position in the moment of FLX to TOGA set?
please give me help
I have same issue with same message on A330 at TO.
Perf are correctly set on corresponding perf page and flaps position is correctly set as well ...
But message appears ...
http://jardesign.org/forum/img/m/9347/t … 21kff3.jpg
Just downloaded v4.4r1 and then updated to b3 after activation.
* IRS alignment times still do not match. PFD displays show info coming from an aligned IRS but the ECAM says it needs 4-5 minutes more to align.
* TakeOff Inhibit message appears during taxi when you apply thrust (or when you start your takeoff roll). It should be visible only after 100kt speed and it is not tied to N1/N2 etc in real aircraft. (In JarA330 it looks like you tied it to N1/N2 readings directly).
* Flight Attendant starts "Seat Belt sign" announcement after take off without any change to seat belts from cockpit. They were turned on before taxi and was on after take off but she announced that they are turned off (around 2000 feet)
Did not tested all the problems reported back with older versions, just wanted to see the latest build sad
And one more thing, red warning message pop-up about my joystick settings and force me to set them to %50.Why ? Maybe I want them at %40 or %20. Does this really necessary ?
Best wishes
And one more thing I noticed with b3
When you set CRZ FL as 33000 at MCDU INIT page, aircraft stops climbing at FL320. But when you set it at MCDU INIT page as FL330 (it will show 330) and aircraft climbs to FL330 wink
Beta version is Earlier version. Release version os more FRESH. If you already install release, you not need downgrade to beta version.
