Topic: XP11.50 JD330 v.4.4
JD330 for X-Plane 11.50
What new:
v.4.4R1
+ EPR indication improved
+ External lights improved
+ FCU VVI knob rotation fixedd
+ Diagnostic plugin fixed
+ CLB position settings add
+ Updater add
+ Liveries installer add
+ Diagnostic plugin improved
+ .pdf Manual add
Download link for version 4.4r1:
http://jardesign.org/a330/download/inst … 0_4410.zip
Download link for old stable version 4.3r2:
http://jardesign.org/a330/download/inst … 0_4320.zip
For macOS Catalina / BigSur users - please follow instruction:
http://jardesign.org/forum/viewtopic.php?pid=31110
Download link to updated CoPilot version:
http://jardesign.org/copilotdownload/JD-CPL-330.zip
Download link to updated Ground Handling plugin to be well-compatible with XP11.50
http://jardesign.org/forum/viewtopic.php?id=11824
- be sure, that you use X-Plane 11.41-11.53
- copy unziped "JD330XP11" folder to ..\X-Plane 11\Aircraft\ folder
- please visit download more fresh version of Ground Handling plugin (use link above). It work with JARDesign 330 without registration (for free). Please note what “Deluxe” version of this plugin (may work with other aircrafts) is payware.
- enter your serial key (use exist serial from "JD330 for X-Plane 11"), click NEXT and after a successful activation reopen aircraft via X-Plane menu
- One of your installed X-Plane plugin (like SeaTraffic) can block activation windows. You can temporary remove your plugins one-by-one and check is activation window appear. Another (faster) way you can use - load Cessna 172, open X-Plane Menu->Plugins->Plugin Admin to disable ALL plugins, next - load JD320/330.
(create it if need)
If you use TCA Quadrant - please open X-Plane Settings -> Joystick and assign command jd - "TCA_MasterSwitch1ON" on your Master Switch 1 ON position. Next - Open MCDU MENU -> SETTINGS -> Page 2 and set ON your TCA option. Next - you can deassign "TCA_MasterSwitch1ON" command if need.
- you may post you opinion about this version, post what you like/unlike
- please attach your log.txt if Crash happen.
Please care about information what you will post here and try to determinate reason if issues happen - sure, he interesting in aircraft test and troubles but want to avoid work with "pilot" issues.
Thank you!!!!
This is FREE update for users who own "JD330 for X-Plane 11" product.
