Topic: JD320 Airliner ver 3.8 WIN/MAC 64 bit (X-Plane 11.50/11.41)
WHAT NEW:
With version 3.8 JD320 get updated PFD, ND and FMGS modules what was created for JD340
JD320 Actual version 3.8 link:
http://jardesign.org/a320/download/inst … 0_3810.zip
JD320 Prev version 3.7 link:
http://jardesign.org/a320/download/inst … 0_3710.zip
Actual CoPilot Download link:
http://jardesign.org/copilotdownload/JD-CPL-320.zip
- Please not mix files with other version.
- be sure, what you use X-Plane 11.41-11.50
- be sure what you set Control Sensivity of your to default values
- be sure what you turn Off X-Plane experimental flight model
- download and unzip pack. Open and read OpenAndReadMe folder
(make sure you don't use nonEnglish symbols in aircraft's installation path)
- start X-Plane 64 bit and open a320, activation window will pop up
- enter your serial key (Regcode) and after a successful activation reopen the aircraft via X-Plane menu
- if you use BSS soundpacks, please note what "Modules/Custom Module/" now is the same as "Custom Avionics/" folder
- One of your installed X-Plane plugin (like SeaTraffic) can block activation windows. You can temporary remove your plugins one-by-one and check is activation window appear. Another (faster) way you can use - load Cessna 172, open X-Plane Menu->Plugins->Plugin Admin to disable ALL plugins, next - load JD320/330.
If you have security issue with MAC OS Catalina - please follow this instruction:
http://jardesign.org/forum/viewtopic.ph … 110#p31110
- “JARDesign 330/330 Native format” and put a new cycle to ../X-PLANE 11/Custom Data/GNS430/navdata/ folder (create it if need)
If you use TCA Quadrant - please open X-Plane Settings -> Joystick and assign command jd - "TCA_MasterSwitch1ON" on your Master Switch 1 ON position. (Please not create special joystick profile for this aircraft). Next - Open MCDU MENU -> SETTINGS -> Page 2 and set ON your TCA option. Next - you can deassign "TCA_MasterSwitch1ON" command if need. Please be sure what you not assign some special profile for TCA Quadrant or just Reset It to Default at Joystick Settings.
Thank you!!!!
