Topic: JD320 Airliner ver 3.8 WIN/MAC 64 bit (X-Plane 11.50/11.41)
http://jardesign.org/forum/img/m/22/t/p1egdfn1fd1hqu3fg74o1qnm1qe83.jpg
WHAT NEW:
With version 3.8 JD320 get updated PFD, ND and FMGS modules what was created for JD340
JD320 Actual version 3.8 link:
http://jardesign.org/a320/download/inst … 0_3810.zip
JD320 Prev version 3.7 link:
http://jardesign.org/a320/download/inst … 0_3710.zip
Actual CoPilot Download link:
http://jardesign.org/copilotdownload/JD-CPL-320.zip
  - Please not mix files with other version.
  - be sure, what you use X-Plane 11.41-11.50
  - be sure what you set Control Sensivity of your to default values
  - be sure what you turn Off X-Plane experimental flight model
  - download and unzip pack. Open and read OpenAndReadMe folder
    (make sure you don't use nonEnglish symbols in aircraft's installation path)
  - start X-Plane 64 bit and open a320, activation window will pop up
  - enter your serial key (Regcode) and after a successful activation reopen the aircraft via X-Plane menu
  - if you use BSS soundpacks, please note what "Modules/Custom Module/" now is the same as "Custom Avionics/" folder
If you have security issue with MAC OS Catalina - please follow this instruction:
http://jardesign.org/forum/viewtopic.ph … 110#p31110
- “JARDesign 330/330 Native format” and put a new cycle to ../X-PLANE 11/Custom Data/GNS430/navdata/ folder (create it if need)
If you use TCA Quadrant - please open X-Plane Settings -> Joystick and assign command jd - "TCA_MasterSwitch1ON" on your Master Switch 1 ON position. (Please not create special joystick profile for this aircraft). Next - Open MCDU MENU -> SETTINGS -> Page 2 and set ON your TCA option. Next - you can deassign "TCA_MasterSwitch1ON" command if need. Please be sure what you not assign some special profile for TCA Quadrant or just Reset It to Default at Joystick Settings.
Thank you!!!!
Re: JD320 Airliner ver 3.8 WIN/MAC 64 bit (X-Plane 11.50/11.41)
Совместимость с XP11.50 не актуальна.
Текущая актуальная версия XP11.51
System: Core i9 11900F ~ 5,2Ghz , 32Gb DDR4 3200MHz, NVidia RTX3070Ti 8Gb, W10Pro. 64 bits, SSD 512Gb, HDD 4Tb
Monitor: Samsung SyncMaster S27A650D (1920x1080)
joystick: TrustMaster T.Flight Xotas X
Sim.: X-plane 11.55r1
After a long time, I was hoping to be able to fly the JAR320 again, loading the latest version right away, but I was unable to perform a single flight in 24 hours. I tried all the variants, with x-life, with the co-pilot and without everything only the pure latest version failed me for a single year. There is always something wrong and the x-plane closes. Therefore, unfortunately, I will still be forced to use the ZIBO 737-800, with which there are no problems.
On the last flight I pressed UPDATE on METAR for the departure airport, the x-plane started processing and then it sent me into the air and crash the plane - frustrating.
По прежнему не работает регулировка света "FLOOD LT". Работает только анимация, но самого света нет!
The flood light control does not work. Only animation works, but no light itself!
Hi Jar, tried to install the 3.7. X-Plane stops during  start by "Preparing World".
Log txt attached. Can you help?
sorry log txt here
I installed version 3.7, but when I enter the serial number, I get an error message.
What should I do
regards
It is already fixed in version which is under development.
Very cool!!!
hello,
the thrustmaster tca quadrant addon didnt work for me 100%. i cant release the parking break, i need to press b on keyboard. and switch parking brake button at the same time.
regards
Good morning. I can't find the serial key, where can I find it?
X-Plane stops during  start by "Preparing World". The n version that doesn't work.
It's the same for the A330. Impossible to fly with a lot of bugs.
If x-plane stucks at preparing world, Start xplane with a clean/Standard Custom scenery folder and load the 320. After activating the A320 you can take your custom scenery back and then the 320 should load Fine again. That worked for me.
After long time I try to fly A320 again wdth his vesrion, but never can land well. When I go to retard every time power go to maximum and my tgrottle lever go to dance. I go back to ZIBO.
Manually tracking the Santorini VOR SNI outbound following the published VOR A RW33 approach (descending 3500’ to 3000’ in VS), the CDI went full scale deflection one side to full scale deflection the other side; the CDI would not stay centred, it kept moving full scale from side to side.
Tracking the inbound leg descending to MDA worked fine, as the CDI stayed centred normally as I tracked the CRS via the heading bug.
For information, I had set SNI on both VOR boxes with beacon outbound and inbound CRS set.
speed brake works badly from the joystick and from the keyboard, they can only be used by operating it with the mouse. Furthermore, when they are retracted, it seems that the sound they produce continues to be heard.
Did you try the Speed brake Setting for axis in the MCDU Menu?
I hadn't tried it. When I selected "off", it worked normally again. Thank you very much for your help.
Hi guys...
I have some issues with this new version.
After the aircraft has rolled over 60kt, the parking break triggers automatically.
Anyone else with this? Some help?
Hi everyone,
I am on Mac 10.4 (Big sur)
Activation window doesn't appear though I am on admin mode and removed my plugins.
Thanks for help
21 (edited by claudioplann 2021-06-17 02:15:30)
Goodnight.
I would like to know if anyone else has a serious problem with the fps of this aircraft.
I put the aircraft in the gate with about 30 fps and already in flight preparation, it drops to 14 to 16 fps. At Cruisin altitude it increases to 21, 22.23 fps and after landing it improves again to 30 fps .....
Anyone else have this problem?
My pc:
Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz   3.40 GHz
NVIDIA GTX1060 6GB
RAM 16,0 GB
after updating to latest version... the issues still persists. born auto tuning doesn't happen in my fmc. hence doesn't come in nd too. even before acceleration altitude the climb mode changes to open climb... there is some serious issue. I dont know when i can fly this smoothly. and the fly by wire still has lots of issues.
Anybody else have issues with this aircraft (and the A330) leveling off and accelerating way too fast, almost unrealistically, after departure during the initial climb?
And then, when you are descending and level off, the throttle goes haywire and it overspeeds by 10-20 knots before settling back down to the indicated airspeed I selected.
This was never an issue but started happening a few updates ago and I don't see anybody else posting anything about this.
i cant activate the new update
Please www.support.jardesign.org with your serial key.
