Re: CoPilot Plugin for JD320 v.260119, 030219, 030819, 231220
I have the same problem only male . perhaps I'm doing wrong could, someone tell me how please. I have the Payware version
JARDesign Group Board → CoPilot for JD320 → CoPilot Plugin for JD320 v.260119, 030219, 030819, 231220
Request:
***Can you (JAR Design) add an action to the 'FLIGHT CONTROL CHECK' - To have Sandy (the co-pilot) turn on the Yellow Hydraulic pump? You cant do the FC Test without it. Thanks!
Comment:
If the co-pilot voice gets stuck in a continuous loop, I have found by saying 'SKIP' or 'Skip This" will get him/her out of the loop. Try it.
Thanks,
Ken L.
Bonjour,
Mon message de Today 22:30:08 a été déformé; je ne sais pas pourquoi.
Je vais essayer de l'écrire encore une fois:
Le copilote (JARDesign A 320) parle en anglais et il faut modifier la reconnaissance vocale Windows (qui est en français).
Est-ce possible de le faire parler en français?
Merci.
Louis.
bonjour, après sur mon avoir installe Copilot sur mon a 320 j'ai un crach mon x-plane 11
"saturation add-ons mémoire pleine"
cordialement
Quelqu'un peut-t-il m'expliquer pourquoi copilot fait planté mon x-plane ?
merci.
does this happen when you press the wrong procedures it (LINDA Keep repeating Ex Before Take off procedure) it´s annoying
how to answer without a microphone for example by checklist?
There is a problem with spoilers, datarefs sim/flightmodel/controls/sbrkrqst! and sim/flightmodel/controls/sbrkrqst are not valid anymore, it can be repaired by replacing them with:
jd/spdbrakes/handle=-1 for armed position
jd/spdbrakes/handle=0 for disarmed position
jd/spdbrakes/handle=1 for half position
jd/spdbrakes/handle=2 for full position
I tried also to change a male copilot for woman in config, but position of model is wrong placed. Anybody know if change of copilot model can be done in JD A320?
Hi!
Unable to reache the serial, because its been remowed.
Hi!
Unable to buy on the site!
Ther is any reason?
Hi!
Ther is any reason?
Please www.support.jardesign.org
Hi!
I still can't buy a serial key.
Hi!
As we still have not decision about JD320 future in XP12 - we cant start update job for it copilot, sorry.
But my game Xplane 11!
Ok, sorry. But what did you mean as "cant buy"?
HI!
Well this!
HI!
Well this!
Yes, sure. No XP12 version for this aircraft still exist. As result - no copilot is exist.
