Topic: CoPilot Plugin for JD320 v.260119, 030219, 030819, 231220
The work of the pilots in a modern airliner involves two people. You know. Of course, before, the voice of the f.o. pilot was present, but he did not do anything and did not execute commands, did not listen to you, did not live with you. I really wanted this to change and I am happy that my friends supported me in this matter.
So, this is CoPilot plugin for JD320.
YouTube Demo: https://youtu.be/n5xrKyweIC4
http://jardesign.org/forum/img/m/22/t/p1d25dpu7f7jaqh41jt81gl71gph3.jpg
features:
+ animated 3d CoPilot model (male, "Sandy")
+ can recognize and execute command
+ can speak
+ can read checklists
+ can operate with Events (flight parameters detection)
+ scripts based (possible to edit/change Procedures/Text/etc)
versions:
260119:
+ basic release
030219:
+ few fixes in scripts
030819
+ updated for JD320 v.3.4
231220
+ bug fix
This is a payware product with price 14.95 USD (VAT not incl.) You can download, install and test the demo version. Demo mode work up to takeoff phase of the flight. If you like the demo version and you want to use the full version - you may purchase serial key using X-Plane Menu -> JD330 -> CoPilot -> Registration and activate it.
INSTALLATION
Download Link:
http://jardesign.org/copilotdownload/JD-CPL-320.zip
Manual:
You will find manual inside your ZIP pack.
Or:
Please visit product page to read Step-By-Step instruction
http://jardesign.org/copilot/
Please post your opinion, issues, troubles, ideas direct to this topic.
Re: CoPilot Plugin for JD320 v.260119, 030219, 030819, 231220
reserved
hi when i install this JD320XP11_333
i can´t activate the key.
Same here. Activation is not possible
May be you have used all your activation possibilities …
This has just happened to me and JAR has just added a few more on my account …
I don't think that is the problem. The "Registration" item doesn't even appear in the 320 plugin menu.
Hello JAR.
I'll find some minor mistake in events command. In events - climb - seat belts copilot say "Seat belts on!" but must say "Seat belts off!".
Registration for me works fine.
THX.
when i enter the key it does'nt go next.
What going wrong exactly?
mat I ask you to contact me via skype j.a.romanov ?
My activation/registration problem was due to the fact that I inadvertently had installed the A330 Co-pilot in the A320. So @iamred, I suggest to delete your current co-pilot installation form the aircraft/plugin folder, download the latest demo again and install that. That worked for me.
version 030219 just published
you may redownload it from http://jardesign.org/a320/download/copi … PL-320.zip
if copilot is already installed, you may just delete old JD320/plugins/copilot_main/custom folder and put new custom folder from ZIP. In this case - no reactivation will need.
where do i buy co-pilot
14 (edited by Vrumugun 2019-02-09 18:10:42)
Just one small question. In the manual it says: "animated 3d CoPilot model (man OR woman, depend of aircraft)".
Can i use the male model only with the A320 and the female model with the A330? Or can i use both models with both airplanes?
15 (edited by Wulfkai 2019-03-09 23:21:54)
hi
first: Love the idea of the co pilot, actually the only reason i bought the JD320, sadly, the copilot for my experience keeps going into a loop when performing the flight controls checklist, hence i cannot complete the before taxi procedures.
during the flight controls checklist, it starts and he performs the stick maneuvers "up, down neutral, left, right and neutral" but then the copilot stops and nothing happens, if trying to choose checklist or any other thing he just repeats it in a loop, example: Flight control flight control or "before taxi procedures, before taxi procedures" neither pressing reset nor test helps.
same situation every time, known bug? or do i do something wrong... thanks in advance
best regards
Wulfkai wrote:
hi
best regards
If checklist after neutral position don't go forward, just go little left and little right again and then will go forward.
Wulfkai wrote:
hi
best regards
Thank you so much!
so  no co-pilot for the latest 320 yet?
Im using it every Day for 320 smile works fantastic
20 (edited by eatkins245 2019-05-28 22:44:44)
Just tried the copilot demo and the Jar A320. After launching the A320 there is no Copilot in the right seat. But copilot works. My question is when I buy the full version will the copilot show up in the right seat?
21 (edited by laohu314 2019-08-04 15:27:57)
Where can I find the download for version 030819? The latest version I have has a mac.xpl with a creation and modification date of 4/21/19, 8:52. Is that the most recent?
You should find it at "post#12" above …
23 (edited by laohu314 2019-08-04 19:10:55)
Thanks jcdp! The version numbering is totally confusing to me. In post #12 it says "version 030219 just published".
And then, in the version.txt in the downloaded files it says 300619
.xpl file may be old, but scripts was updated, sure.
Hum… well you are quite right …    smile
