Re: [actual for XP11] GHDeluxe v.4
Hi I'm using 11.41 version and 737 800 zibo. After activate on zibo tablet to GHD I'm Hearing Ground Services car but i cant see them. And i cant click to Control panel's on the ghd plugins window.
I bought a new computer, I no longer have the old one, when I try to activate with my serial number it tell me I am trying to use a single activation key one another computer, do I have to buy another activation key again, I hope not.
103 (edited by Peter092 2020-04-06 14:28:47)
I just downloaded is installed the GHD V4 on xplane.org, when I launch Xplane, GHD returns V4.010719 and on this forum I see a version 4.230618.
Sorry but in GHD V4, I don't understand which is the right and latest version.
Thanks in advance.
104 (edited by flightime56 2020-04-07 00:21:43)
Setting authorisation GHD v4 (11.50) creates xml/http text, BAD CTD then broken Vulkan API???  Trying to fix?
How do I add log.txt to post?
Thanks in advance.
Same problem for me. Can't see anything on 11.50
Same here, It did not display the latest version.
107 (edited by Noto1125 2020-04-15 12:13:50)
Thanks in advance.
Similar, first I updated via the recommend method and then tried a full installation, backing up reg key first. Still shows old version.
Also, does anyone know how to edit the Control Widget to be able to select the cones and chocks, without having to drive all up?
Any feedback on this from the Dev?
I have submitted a ticket, will see.
110
What is the correct version to use with 11.50 of Xplane 11
111
All you have in download links for all products of JAR
http://jardesign.org/forum/viewtopic.php?id=11820
Does this version work with both 11.50 and 11.41?
113
NO Please go to DOWNLOAD LINKS FOR ALL PRODUCTS ant there you can get version for 1.41.
114
Greetings,
I downloaded and copied the win.xpl file into my X-Plane 11.41 but have yet to get the X-Crafts ERJ175 .set to work. The 195 .set works fine, so what have I done wrong and what exactly is the file name for this set so that I can check whether there is any duplication or conflict?
Regards.
TG
115
hi there, after bying the jd320 ultimate i'm missing the plugins. jd320 (sasl), a320 components diasnostic plugin, jardesign fmgs plugin. jardesign 1d, 2d, en 3d soundengine. Anyone know where i can download these  plugins. i read that you have to get a cef map in xplane's plugin map but it wat not in my download from the xplane store. Anyone who can help me with this?
Thanks in advanced
peter
