Re: [actual for XP11] GHDeluxe v.4
Hi I'm using 11.41 version and 737 800 zibo. After activate on zibo tablet to GHD I'm Hearing Ground Services car but i cant see them. And i cant click to Control panel's on the ghd plugins window.
JARDesign Group Board → Downloads, Updates → [actual for XP11] GHDeluxe v.4
I bought a new computer, I no longer have the old one, when I try to activate with my serial number it tell me I am trying to use a single activation key one another computer, do I have to buy another activation key again, I hope not.
I just downloaded is installed the GHD V4 on xplane.org, when I launch Xplane, GHD returns V4.010719 and on this forum I see a version 4.230618.
Sorry but in GHD V4, I don't understand which is the right and latest version.
Thanks in advance.
Setting authorisation GHD v4 (11.50) creates xml/http text, BAD CTD then broken Vulkan API??? Trying to fix?
How do I add log.txt to post?
Thanks in advance.
Same problem for me. Can't see anything on 11.50
Same here, It did not display the latest version.
Thanks in advance.
Similar, first I updated via the recommend method and then tried a full installation, backing up reg key first. Still shows old version.
Also, does anyone know how to edit the Control Widget to be able to select the cones and chocks, without having to drive all up?
Any feedback on this from the Dev?
I have submitted a ticket, will see.
What is the correct version to use with 11.50 of Xplane 11
All you have in download links for all products of JAR
http://jardesign.org/forum/viewtopic.php?id=11820
Does this version work with both 11.50 and 11.41?
NO Please go to DOWNLOAD LINKS FOR ALL PRODUCTS ant there you can get version for 1.41.
Greetings,
I downloaded and copied the win.xpl file into my X-Plane 11.41 but have yet to get the X-Crafts ERJ175 .set to work. The 195 .set works fine, so what have I done wrong and what exactly is the file name for this set so that I can check whether there is any duplication or conflict?
Regards.
TG
hi there, after bying the jd320 ultimate i'm missing the plugins. jd320 (sasl), a320 components diasnostic plugin, jardesign fmgs plugin. jardesign 1d, 2d, en 3d soundengine. Anyone know where i can download these plugins. i read that you have to get a cef map in xplane's plugin map but it wat not in my download from the xplane store. Anyone who can help me with this?
Thanks in advanced
peter
