Makcimus wrote:Darko24 wrote:I download amd install as required, but have no sounds.
I installed like this:
- I downloaded from the first page of this section clean version 3.4r3 the A320.
- activated a new airplane.
- Then deleted the folder “sounds3D” which is located in the folder “plugins” in the root of the airplane.
- then copied to the "plugins" folder a new folder “sounds3D-1 ” from the BSS archive, without copying the “Custom avionics” folder.
- after running simulator all sounds work normal
Try this and good luck!
THX
I'll made fresh clean install JD320, registration and then change sound3d with BSS sounds and now version for 11.41 works fine.
For version for 11.50, I made the same width update v5 of BSS and with clean install version latest 320 for 11.50, registration and apply sound from update all work well.
My Fleet: JD320-V3.8R1 with copilot, JD330-V4.4B3 with copilot, ZIBO 737-800X,
