201
Re: JD320 Airliner ver 3.4 r3 WIN/MAC 64 bit (X-Plane 11.35-11.41)
Makcimus wrote:
Funox wrote:
When will there be an update for 11.50 because everytime I try to play on 11.50 it crashes? On 11.41 it's fine.
X-plane 11.50 is in beta, so compatibility is not guaranteed. When the version is released, then there will be an airplane update.
Okay, thank you for your fast answer.
202
"When the version is released, then there will be an airplane update."
Is that for certain ?
In the A330 area of the forum we have a place holder for 11.50 but not in the A320 forum sad
203
hi one question A330 update for 11.50 a320 not update?
204
Follow
205
Hello, the DCDU with the METAR Information of Depature/Arrival Airport is normally off.
When I click on Update it loads the METAR but it takes seconds to 1 Minute to load.
The loading Process freezes XPlane and disconnects XPilot.
I have installed the actual Gizmo Plugin.
206
Hello, good afternoon, I am writing to you because some important parts of the cabin are inoperative in version 3.5B2, do you know why? I expect an answer as soon as possible.
Thanks and best regards, Jacobo.
Pharmacie populaire www.viagrasansordonnancefr.com toxicose du medicament
207 (edited by Makcimus 2020-05-29 09:40:48)
Привет, всем!
На XP.org появилось обновление звуков BSS до версии 5. Скачиваем и пробуем wink
Hi everyone
On XP.org there was an update of BSS sounds to version 5. Downloads and try wink
System: Core i9 11900F ~ 5,2Ghz , 32Gb DDR4 3200MHz, NVidia RTX3070Ti 8Gb, W10Pro. 64 bits, SSD 512Gb, HDD 4Tb
Monitor: Samsung SyncMaster S27A650D (1920x1080)
joystick: TrustMaster T.Flight Xotas X
Sim.: X-plane 11.55r1
208
Makcimus wrote:
Привет, всем!
Hi everyone
I download amd install as required, but have no sounds.
209 (edited by Makcimus 2020-05-29 19:06:47)
I installed like this:
- I downloaded from the first page of this section clean version 3.4r3 the A320.
- activated a new airplane.
- Then deleted the folder “sounds3D” which is located in the folder “plugins” in the root of the airplane.
- then copied to the "plugins" folder a new folder “sounds3D-1 ” from the BSS archive, without copying the “Custom avionics” folder.
- after running simulator all sounds work normal
Try this and good luck!
210 (edited by Darko24 2020-05-30 09:30:33)
THX
I'll made fresh clean install JD320, registration and then change sound3d with BSS sounds and now version for 11.41 works fine.
For version for 11.50, I made the same width update v5 of BSS and with clean install version latest 320 for 11.50, registration and apply sound from update all work well.
211
The FCU knobs rotate automatically on AP and thus are triggering the BSS sounds .wav programmed to make the clicking sound when a knob is rotated. This obviously needs to be fixed. The FCU knobs should not be rotating on their own accord in without a pilot physically selecting them. Please advise!
Pat
212
Does anyone have activation key??
213 (edited by elik.koren 2020-06-18 15:30:54)
A320 crash x-plane.
In one word, cannot use your plane.
Log attached.
214
Hi, am having issue in replay mod with the a320. in the replay mode no spoilers is deployed (speed break) it's like some scene is missing while in replay mode. anyone else having this issues?
215
Hallo. I have a problem with this newest version. No activation window pop up on start.
My Log says:
Loading error report for Aircraft/a320 JARDesign/a320neo.acf
Unable to open weapon file 'crash.wpn'
What is wrong? The older version of the A-320 work fine.
216
I have bought the product and when I choose the plane, it asks for the password, I activate it and everything is fine, but it asks me to restart the plane. The problem is that with this plane, it won't let me use the xplane menu and I can't do anything, or choose another plane, or another flight, nothing comes out.
The rest of the aircraft work fine, fmc, gpu...
