Topic: JD320 Airliner ver 3.4 r3 WIN/MAC 64 bit (X-Plane 11.35-11.41)
So.. a320 for X-Plane 11 version 3.4 public release here.
This version get new/updated FMGS, like JD330
WHAT NEW:
r1:
+ X-Plane 11.35 compatible
+ brand new FMGS installed
+ HOLD at Fix point fixed
+ incorrect sys disp page fixed
+ acceleration on descend fixed
+ METAR info reading fixed
+ on-screen GPU button add
+ add MCDU MENU -> SETTINGS options
+ add SATCOM 3d model
+ FMGS module updated
r2:
+ framerate optimisation
(you may update a320neo.acf file and plate.txt only to switch r1->r2
r3:
+ new VATSIM xPilot compatible
JD320 Download link:
http://jardesign.org/a320/download/inst … 20XP11.zip
Updated CoPilot Download link:
http://jardesign.org/copilotdownload/JD-CPL-320.zip
Updated GHD plugin link:
http://jardesign.org/forum/viewtopic.php?id=4133
!!! Please set X-Plane Experimental flight model to Off/Disable
- Please not mix files with other version.
- make sure, that you use X-Plane 11.26-11.35
(make sure you don't use nonEnglish symbols in aircraft's installation path)
- start X-Plane 64 bit and open a320, activation window will pop up
- enter your serial key (Regcode), click NEXT and after a successful activation reopen the aircraft via X-Plane menu
(create it if need)
POSSIBLE / KNOWN BUGS:
- sound issue with BSS pack? Please push BSS support for Update!
Please care about information what you will post here and try to determinate reason if issues happen - sure, he interesting in aircraft test and troubles but want to avoid work with "pilot" issues.
Thank you!!!!
