Re: XP11.50 JD330 v.4.1
The white button doesn't seem to work
http://jardesign.org/forum/img/m/9704/t/p1e5a8jd0i1pn91ncp13jc9hqmuu3.jpg
Hey,
nice Update, i had flown this Aircraft for more than a Year. Now i had read at Treshhold that it comes with VR inplemetation
and Ok it look amazing in VR but some knobs won´t Work, does this beta include the VR optimization or not?
kind regards and stay Safe
ddezulier wrote:
no sound whatever model (main or fpsboost) is used)
MCDU/FMGS when in popup refuses to draw its own pages inside its own screen but displays it on ND, or PFD, or ECAM ...
Please contact skype j.a.romanov directly
That's probably a side effect after installation.
Cleaning X-Plane preferences, deactivate plugins, reload = Ok
Close
Reactivate plugins
reload = OK
I'll fly her tomorrow LHBP-ESSA on IVAO anniversary  WT.
And I'll report !
ddezulier alias diaboloxpfr on X-Plane.org forum
VID 566478
VAT 1400805
30
Yes, does not work here too ...
VID 566478
VAT 1400805
Guys livery is working ?
I recently upgraded to version 11.50 and I noticed a performance problem with the beta version of A330. I have a Mac and I use Metal for rendering. The SASL plugin consumes a lot of resources and FPS is decreasing dramatically. Here are a couple of screenshots.
Great work getting this update ready for XP11.50, thank you.
Recently purchased the JAR A330 and still getting used to flying it. Fantastic exterior modelling.
I have some questions
1. I see no 'heat blur' effect from APU? Is this modelled?
2. Their is a basic checklist on clipboard under pilots window..will it be replaced like the pop out 'normal procedure' checklist on the JAR A320?
thanks
dandix265 wrote:
Hello .
i downloaded last version. all good except for some button sound (battery button for example doesnt sound) and i can't find menu where i can open/close door and load passenger/fuel. For sound i don't have bss sound and im using sound3d
Thank for help
can see a screen of what im talking here
http://prntscr.com/rupmw9
Click on MCDU MENU on FMC. If your FMC is not on, click on the FMC screen for the pop-up
Clicking on the weather update button works, but I also get this window...
http://jardesign.org/forum/img/m/4717/t/p1e5cfcc1l1orr13949dqt4i20l5.jpg
36 (edited by jcdp 2020-04-08 09:34:37)
Open XPuipc plugin and enter the IP address of your computer in the XPUIPC.ini file.
demontraitor wrote:
dandix265 wrote:
Hello .
Thank for help
Thank you so much. i prefer "plugin menu" but its ok.
Thanks again
of course yes... sorry blonde moment lol
A "test" successful flight from ELLX > EGCC. It all went perfectly.
Thanks smile
40 (edited by demontraitor 2020-04-08 10:54:32)
I'm still on 11.41 (Windows 10)
Have noticed that when trying to exit X-Plane after a flight with the A330, X-Plane hangs just sitting there and doesn't shutdown... nothing untoward in the log file...
Weather Information at One Zero Four Zero Zulu. Wind, Two Seven Seven degrees at One knots. Visibility, Zero  kilometers. Sky Condition, Clear. Temperature, One Five . Dew point, Minus Five . QNH, One Zero Two Six
2:12:22.029 I/ATC: Airport flow changed at EGCM!
CurFlow: Runway 06 NewFlow: AUTOGEN: West
2:12:22.029 I/ATC: Changing EGCM CabState from 0 to 1
2:12:22.029 I/ATC: All departures are done at EGCM. Advancing...
2:12:22.029 I/ATC: Changing EGCM CabState from 1 to 2
2:12:22.029 I/ATC: All arrivals are done at EGCM. Advancing...
2:12:22.029 I/ATC: Changing EGCM CabState from 2 to 0
2:12:24.693 I/ATC: Airport flow changed at EGNF!
CurFlow: Runway 24 NewFlow: AUTOGEN: West
2:12:24.693 I/ATC: Changing EGNF CabState from 0 to 1
2:12:24.693 I/ATC: All departures are done at EGNF. Advancing...
2:12:24.693 I/ATC: Changing EGNF CabState from 1 to 2
2:12:24.693 I/ATC: All arrivals are done at EGNF. Advancing...
2:12:24.693 I/ATC: Changing EGNF CabState from 2 to 0
XL: 6917 : JARDesign plugin: G:\Games\Steam\steamapps\common\X-Plane 11\Resources\plugins\X-Life\Metar/ELLX.TXT file updated.
XL: 6917 : JARDesign plugin: G:\Games\Steam\steamapps\common\X-Plane 11\Resources\plugins\X-Life\Metar/EGCC.TXT file updated.
XL: 7089 : Shedule flight: A B738 EXS-946 LFLL
XL: 7089 : Shedule flight: A A320 EZY-1898 EDDB
2:19:32.900 I/SIM: Exiting the sim without confirmation
2:19:32.900 D/STM: Transitioning from state state_Normal to state_ShuttingDown
[AVS INFO]: Disabling...
[AIRPORTVS INFO]: Disabling...
FlyWithLua Info: Load exit file.
FlyWithLua Info: Exit file loaded.
FlyWithLua Info: FlyWithLua plugin disabled.
[MISSIONGENERATOR INFO]: Disabling...
[SKUNKCRAFTS UPDATER INFO]: Disabling...
[SKUNKCRAFTS UPDATER INFO]: [LUA]: "module"    SkunkCrafts Updater stopped
WebFMC: Plugin disabled
I have to force close X-Plane. I have no idea if this is related to the A330, but will investigate more... Anyone else getting this?
Normal flight today between LHBP and ESSA.
Still too fast in descent, from FL100 transition to approach.
VID 566478
VAT 1400805
Thanks so much for the prompt update. The only issue I have had is with the APU. Once started I can't initialise the APU Gen. The button stays showing a fault. However the systems behave as if the APU generator is working.
Running A330 B5 under XP11.41 on extending the gear for landing, the undercarriage doors did not close.
44
Or the u/c doors might display as open in replay.
45
Still no weather with Active sky
Did anyone else experience the FMCU screen being drawed on the bottom left corner? No matter what I do, can't get rid of it....
47 (edited by Boo 2020-04-09 12:42:54)
http://jardesign.org/forum/img/m/9999/t/p1e5ffbg5813di52lju514au1piv4.png
Plane doesn't follow path
48
With regard to my previous post with the FMCU screen being drawn on the bottom left corner. I can report, switching off X-Enviro removes the screen on the bottom left corner. Re-Enabling, and it's back.
49 (edited by Luke173 2020-04-09 13:46:17)
many thanks for the fast 11.5x version!
though I get very low framerate inside the cockpit, 10fps and lower, on the outside it's all fine. It's a behaviour I only see with other planes when they use librain.
It's the same for both types, 332 and 332 FPS boost.
(I have the bare installation of XP, with GroundHandling missing, but it makes no difference if it's there)
My set up is a MacMini 10.14.6 with an eGPU, log is attached. -> ah, how can I attach a log file? it seems to only let me add images.
Thanks! much aprechiated
Luke
50
Close
Reactivate plugins
reload = OK
And I'll report !
This solution for sound problem or for ND, or PFD, or ECAM
I also have no sound with BBS
