Topic: XP11.50 JD330 v.4.1
JD330 for X-Plane 11.50
What new:
v.4.0.4:
+ X-Plane 11.50 compatible with Vulcan/Metal
+ X-Plane 11.41 compatible
v.4.0.5:
+ TA/RA sound module fix
+ engines sound for boost version fix
v.4.0RC1:
+ TCA Quadrant support
v.4.0RC2:
+ flaps operation issue fixed
R1:
+ just release
R2:
+ /plugins/fmgs/win.xpl and mac.xpl files updated cause of widgets issue
v.4.1R1:
+ speed constraint issue fixed
+ ground spoilers operation improved
v.4.1R2:
+ "Real Weather" issue fixed
+ TCA Quadrant usage issue fixed
v.4.1R3:
+ hi altitude airport approach speed fixed
v.4.1R4:
+ turbulence yaw damper add
Download link:
http://jardesign.org/a330/download/inst … 0_4140.zip
For macOS Catalina users - please follow instruction:
Download link to updated Ground Handling plugin to be well-compatible with XP11.50
http://jardesign.org/forum/viewtopic.php?id=11824
- be sure, that you use X-Plane 11.41-11.50
- copy unziped "JD330XP11" folder to ..\X-Plane 11\Aircraft\ folder
(create it if need)
If you want to test how failures system work, you need use DatarefEditor plugin and enter "jd/bugs/" there. You will get small number of datarefs what may generate faults - APU Fire, as example, if you change value from 0 to 1.
Please care about information what you will post here and try to determinate reason if issues happen - sure, he interesting in aircraft test and troubles but want to avoid work with "pilot" issues.
Thank you!!!!
