Re: XP11.35 JD330 v.3.2 r4
bearhsiao wrote:
I just closed the Windows operating system and the Router firewall. The problem still exists.
I have the same problem, could post the complete solution here in the forum would be much easier.
why does the weather radar not work on the A330?
work well
79 (edited by portscan86 2019-09-02 03:51:38)
Yesterday I flew from Hong Kong to Munich. Since the weather radar was not. Enclosed the log file. Radar I have set to WX / Turb. In addition, yesterday I had the problem that the A330 suddenly flew only to grind and not the track in the FMC has followed. Then I had to manually adjust the heading
Log: http://xup.in/dl,14427408
In the A320 it works without problems.
80 (edited by NotAlpha 2019-09-02 20:51:36)
Getting this message "VA Plug in Error". What am I suppose to do? Log Attached.
I have been trying to make flights with the A330, but this is impractical, the AP turns off it starts to climb without me having set anything. It is very difficult to fly with this aircraft.
82 (edited by Urgences78 2019-09-04 01:36:15)
Hello, sorry if my problem has already been mentioned but I do not know where to look to see if there is already a solution.
I bought the 330 this morning and I just tested the ground procedures at LFBO. Tonight I wanted to fly KJFK/KLAX but when I entered my information on the FMC INIT page, I noticed that KJFK's GPS position was wrong with a latitude value of -73 ° instead of 73 °.
I saw that this problem existed on the 320 and that it seemed to be fixed but I did not find an identical mention for the 330.
Thanks in advance for your help, sorry for my english and again sorry if the problem had already been reported.
PS : I don't see any answer to know if WX Radar works with xEnviro?
83
Have you read the instructions for the plane?
How do you enter your information in init page?
In Init page write LFBO/KLAX and press right button on from to and you get direction. Request for flight plan not working on overseas destination, so you get only departure and arrival airport in your flight plan. You can use SimBrief to make flight plan, save to your flight plans and the in init page write LFBOKLAX and pres left button near your CORTE, and you get flight plan. You need aproksimatly 61 tons of fuel to this destination.
Dont forget to fulfill  the PERF page before start flight and use copilot for help.
In the and FIRST you MUST READ how to fly with A330. First you can use this link http://jardesign.org/forum/viewtopic.php?id=3059
At least this is not arcade game but simulation and must be real they came to be.
is there any version that works on Linux Mint 19?
86 (edited by Urgences78 2019-09-04 11:56:43)
Thank you for your answer but it does not answer my problem.
I said that the GPS position of the departure airport was lost after I got KJFK/KLAX on the INIT page. When I confirm this, the GPS position where we click on ALIGN IRS on the INIT page is wrong and so I have a DISCONTINUITY between the departure airport and the 1st WAYPOINT of the route.
I explained my problem to a friend who owns the A330 JAR and he too has encountered this problem.
OK I understand now. I'll try the same and get the same picture on screen. Even I try to load different version of KJFK airport I'll get the same result.  This is really problem, but when you enter departure runways and SID in your flight plan and clear discontinuity you can go to fly.
88 (edited by bearhsiao 2019-09-18 14:36:32)
bearhsiao wrote:
Dear Mr.Romanov
Meter information cannot be displayed, is it related to xEnviro?
I tried disabling xEnviro and using Active Sky XP+UWXP, but the problem still exists.
Chun-Fan. H
http://jardesign.org/forum/img/m/7843/t/p1dj3332301h7d1iat3fclrh1dgd3.png
I found the little problem,
In the X-plane log file I found the JAD330 display the
FMGS: 1089 : JARDesign plugin error: Unsupported protocol
FMGS: 1089 : CurlDownloadFile Error
I used a web browser to visit https://tgftp.nws.noaa.gov/data/observa … s/KCPR.TXT  which displays the following data:
2019/09/06 14:53
KCPR 061553Z 12006KT 10SM CLR 24/09 A3024 RMK AO2 SLP165 T02440094
But I opened the downloaded .txt file and found that the content is blank~
Attached with the relevant files for your reference.
Thank you.
Attachment icon b738_prefs.txt 414 b, 182 downloads since 2019-09-06
Attachment icon KSEA.TXT 116 b, 192 downloads since 2019-09-06
hi folks,
this plugin looks excellent. Is there a way to run it on Linux, too? I would be happy to help with beta testing (and maybe coding depending on the requirements) if there's interest.
All the best,
Uwe
Hi, works well in VR, just a couple of things.
1, gear up down not working in VR.
2, Flaps not working in VR
3, cant arm speed brakes in VR.
Just wonder if these can be fixed?
Would be nice if you can?
thanks
carl
wonderful aircraft.. really enjoy flying this in XP11.. now that we have particle effects in XP11.30+ , can we get APU exhaust heat blur just like we do in the zibo 737? Thanks again!
Vinod.
It does not work if you have x enviro.
93 (edited by vinod.kumar.747 2019-09-11 08:11:26)
I am using ultraWeatherXP.. I have disabled xEnviro for a long time.. (deleted from plugins folder).. so xEnviro does not even load when the sim loads.. I'm able to see all other A330 particle effects like engine heat blur, contrails from wing tips (which look beautiful by the way), etc.. but not seeing any APU exhaust.. was it modeled? has anyone seen this APU effect?
94 (edited by F1le 2019-09-12 10:29:13)
This dome light works?Looks like it does not work. Anybody knows something about that? Of course HDR is set and level of details is Maximum (HDR+SSAO)?
OK works fine... Did not turn on this CTL switch...
95
When did update FMC Options and start FMC three
96 (edited by F1le 2019-09-12 20:40:35)
1/ Guys do you have a bug when you set up FMC and flying and later you had to change the approach and runway due to ATC? Each time I change that it turns out that memorized ILS (RAD/NAV key) in this case is from the initial input (let's say RWY 25L while ATC gave me 25R and different STAR than initial input)
2/ Sometimes ATC gives me an instruction that on WAYPOINT let's say XYZ I had to be on 9000ft, while in flight plan it's on 16000ft. Well it's quite obvious ATC want to point me earlier to approach. Normally it needed to put into FMC /FL090 and push it to the point so the FMC will recalculate the rest, but it's impossible. Any clue?
JAR can you take a look at it?
97 (edited by ddezulier 2019-10-02 09:18:29)
Hello Guys, Using A330 under X-plane 11.36r2, with the last updated version of A330 read on plate.txt = 3.2r2 (despite the version of last update is 3.2r1 !)
Taking off using Flex temperature, lever on CLB when requested at the proper altitude, retracting flap using dots and Perf page (with all having being set in all its pages).
The plane accelerate well on runway, and climb well until FL100 -then stop climbing to increase speed, as it is programmed in perf page. Every thing seems ok.
But when altitude increases ATHR seems unable to maintain IAS, at the value indicated as "managed", and the plane seems to have difficulties to climb (200 to 400 fpm seems to be the maximum climbing rate).
Saitek Pro 52 is often calibrated to maintain its efficiency.
When pushing lever to MCT/Flex or TOGA, power is delivered (with high fuel flow, but all is OK) and plane climbs well.
https://www.skybrary.aero/index.php/A332
Any idea ?
Regards !
Daniel
ddezulier alias diaboloxpfr on X-Plane.org forum
VID 566478
VAT 1400805
Flaps up 0 from flaps 4 when after landing, the speed brake will not show animation by replay mode.
99 (edited by A330Aviator 2019-09-25 16:51:16)
Is it just me, or do the engines sound like they are at full power when they are not. I've only been on a A330-300 so idk but im pretty sure -200 engines dont sound like this
https://cdn.discordapp.com/attachments/ … -21-34.mp4
Oh and dont worry about the FPS message its because i was recording. Its the same anyhow
100 (edited by min095 2019-09-26 20:27:02)
Евгений, доброго времени суток! Возможно ли реализовать вот такую визуалку на PFD? Заранее благодарен
