Topic: XP11.35 JD330 v.3.2 r4
This is next public version of a330 for X-Plane 11.
What new:
r1:
+ compatible with XP 11.35
+ some systems migrate from SASL to VA (Visual Avionics)
+ APU system reworked
+ ECAM action system reworked
+ Rudder (normal law) algorithm improved
+ about 20 minor improvements
+ LDG MEMO not show fixed
+ Before takeoff checklist fixed
+ No firetest sound fixed
+ no MW, MC sound fixed
+ FMGS module updated
r2:
+ some minor improvements
r3:
+ new VATSIM xPilot compatible
r4:
+ new macOS Catalina compatible
Download link:
http://jardesign.org/a330/download/inst … 30XP11.zip
Download link to updated Ground Handling plugin to be well-compatible with XP11
http://jardesign.org/gndserv/download/GHDxp11.zip
In the case of wrong voice recognition setup crash on loading stage may happen. Please be ready to contact JAR via skype j.a.romanov to demonstrate how this going and make real fix for this by our crew.
  - be sure, that you use X-Plane 11.35
  - copy unziped "JD330XP11" folder to ..\X-Plane 10\Aircraft\ folder
(create it if need)
If you want to test how failures system work, you need use DatarefEditor plugin and enter "jd/bugs/" there. You will get small number of datarefs what may generate faults - APU Fire, as example, if you change value from 0 to 1.
Thank you!!!!
Re: XP11.35 JD330 v.3.2 r4
About macOS Catalins support:
Yes, JD330 work with it, but some procedures need to do. Please follow:
0.System preferences, security and privacy, accessibility, check X-Plane ON
In 50% cases - you need delete X-Plane from this list and next add it again.
Do this to be sure - delete and add it again!
http://jardesign.org/forum/img/m/22/t/p1dq1cbakc1b5oke41b1ph8d1fnl3.jpg
1.During loading aircraft, if you meet this messages:
http://jardesign.org/forum/img/m/22/t/p1domj49k513e71jm95ab1u381utm3.jpg
Click "CANCEL"
2.Next open your macOS Security & Privacy settings, General tab
http://jardesign.org/forum/img/m/22/t/p1domj5rif1arv1tfa3nnl49l6i6.jpg
and select "Allow Anyway"
3.Do points 1 and 2 for EVERY message like in p.1, until aircraft loading complete.
4.Reload aircraft using menu:
http://jardesign.org/forum/img/m/22/t/p1domjap5g16ssrh0p9f4l2g6j9.jpg
5.During loading aircraft, when you meet another messages:
http://jardesign.org/forum/img/m/22/t/p1domjc20kpou1v9f17eni941hb2c.jpg
Click "OPEN"
6.Do points 5 for EVERY message like in p.5, until aircraft loading complete.
7.Reload aircraft again. Messages should not happen more.
I really like the JD330.
I hope the plan can update the effect of glass raindrops that can more perfect smile
0:01:01.273 I/OVR: Reading VR conf file: Aircraft/JD330XP11/a330_vrconfig.txt
0:01:01.273 W/VRCONFIG: Could not find vr config file: Aircraft/JD330XP11/a330_vrconfig.txt
0:01:01.273 W/VRCONFIG: VR Config data file for Aircraft/JD330XP11/a330_vrconfig.txt is not valid!
0:01:01.273 W/MANIPS: Could not find vr config file: Aircraft/JD330XP11/a330_vrconfig.txt
0:01:01.273 W/MANIPS: VR Manips file for Aircraft/JD330XP11/a330_vrconfig.txt is not valid!
Problem with airplanes to use plugin Rendering Options v2. Hangs up at boot stage. On version 3.1r3 There is no such problem.
Tell me please, have the A330 weather radar implemented? and does it work with xЕnviro?
Yes. I would also like the rain animation to look like the A320 FF. I Hope J.A.Romanov Hear Us smile
Rainy weather when it rains Weather from xEnviro, On the windshield wipers do not wash drops.
dima_gurec! Please not use this board like a chat. No reason for this.
Радар работает с дефолтной X-Plane погодой. К сожалению, энвиро пока не выдало вменяемого API для показа их погоды на все платформы, равно как и не шарит свои данные в дефолтную систему симулятора.
Конфликты с плагинами решаются выключением плагинов. В конце концов пользователь решает что ему интересно больше - плагин или самолет.
Отрисовку капель как FF не планируется к реализации - красивая, но очень тяжеловесная. Может на Vulcan|Metal будет что то пошустрее - посмотрим.
What is your request, please? Or should we guess?
Good morning,
Does the current build support VR? Or is that something that still needs/will be addressed?
Josh
Добрый день.
У меня в логе есть ошибки dll
G:\X-Plane 11/Aircraft/JD330XP11/plugins/sound2d/win.xpl : Error Code = 1114 : Произошел сбой в программе инициализации библиотеки динамической компоновки (DLL).
G:\X-Plane 11/Aircraft/JD330XP11/plugins/sound3d/win.xpl : Error Code = 1114 : Произошел сбой в программе инициализации библиотеки динамической компоновки (DLL).
G:\X-Plane 11/Aircraft/JD330XP11/plugins/sys/win.xpl : Error Code = 1114 : Произошел сбой в программе инициализации библиотеки динамической компоновки (DLL).
Плюс в симе ошибка плагина VA.
Как можете мне помочь?
A.Romanov. Спасибо за ответ. Но все же если можно будет, может получится исправить проблему работы с самолетом с плагином рендеринг опшинс 2, ведь все остальные самолеты работают хорошо. Я нашел сбойный модуль который вызывает проблему, проблема в файлике Aircraft\JD330XP11 3.2 R1\plugins\sys\win.xpl
Имя сбойного приложения: X-Plane.exe, версия: 11.0.34.0, метка времени: 0x5cd1d721
Имя сбойного модуля: win.xpl, версия: 0.0.0.0, метка времени: 0x5d073ef5
Код исключения: 0xc0000005
Смещение ошибки: 0x00000000000d516d
Идентификатор сбойного процесса: 0x1ba8
Время запуска сбойного приложения: 0x01d545e821f933cf
Путь сбойного приложения: E:\Games\X-Plane 11\X-Plane.exe
Путь сбойного модуля: E:\Games\X-Plane 11\Aircraft\JD330XP11 3.2 R1\plugins\sys\win.xpl
Идентификатор отчета: effc607a-972d-4af0-b9c4-d8b2ab6e5d77
Полное имя сбойного пакета:
Код приложения, связанного со сбойным пакетом:
alev11379 wrote:
Добрый день.
If 1114 errors happen at your log "Error Code = 1114", like
..\X-Plane 11/Aircraft/JD330XP11/plugins/sound3d/win.xpl : Error Code = 1114 : A dynamic link library (DLL) initialization routine failed.
..\X-Plane 11/Aircraft/JD330XP11/plugins/sys/win.xpl : Error Code = 1114 : A dynamic link library (DLL) initialization routine failed.
That mean what too many plugins was loaded from your installed Custom Sceneries (all scenery plugins loaded Before aircraft plugin) and X-Plane not allow load any more plugins, include aircraft plugins. So, need to delete/deactivate plugins from some sceneries.
VHJLC wrote:
Good morning,
Josh
Someone report me what yes, as I remember, but ned just try.
Anyway - with actual VR resolution - it is not so much comfort. I use VR with light aircraft only.
skype j.a.romanov - будем пробовать smile
17 (edited by alev11379 2019-07-29 19:48:45)
Просто мне как потребителю, не понятно почему ваш продукт должен ограничивать меня в количестве сценариев или плагинов?
18 (edited by Luke173 2019-07-29 19:43:08)
I'm very glad to see the A332 progress!
Many things work very well by now, for example the managed or open descend. It used to dive way to hard in the past.
Some minor things:
- manual flight plan entry into the MCDU: the first waypoint is not accepted on the dashed line in between the departure ICAO and the arrival ICAO.
- MCDU Cruse page: the optimum flight level should be below the reccomended max flight level
- the plane tends to overshoot also at low angles
yet the plane is a dream to fly now, thanks!
Attachment icon Bildschirmfoto 2019-07-29 um 20.19.20.jpg 159.95 kb, 101 downloads since 2019-07-29
Waiting for: https://github.com/skiselkov/librain
It's not heavy as I know, thanks! smile
That's how it looks: https://www.youtube.com/watch?v=JLd6aEoczhg
21 (edited by Webrichard 2019-07-30 01:32:37)
Romanov please, I have a bug in MCDU. Every time the FL disappears. And when I put it manually, it erases the fuel balance values. Edited in google translator. Help! XP11.35 JD330 v.3.2 r1
Как то Вы интересно поворачиваете.. Это плагины Ваши не дают самолету загрузится. Загрузится ему не позволяют плагины, которые загрузились ранее, вместе со сценариями. Разработчики симулятора комментируют это так: I think the issue is that the static C run-time on Windows uses limited thread-local storage (TLS) slots. Попросту говоря, есть ограничения связанные с библиотеками самой винды. Так или иначе, это конфликт плагинов и тот, который загружается последним (а это плагины самолета, всегда) - имеет шансы на неудачную загрузку. Мы Вас, поверьте, ничем не ограничиваем - но если нужно решение - оно такое.
Кстати, иногда 1114 ошибку дает FF плагин CEF. Но тут опять же легко проверить.
May I look at log.txt just after this happen? Please attach if possible!
hi. nach dem ich ein update gemacht habe, habe ich keinen Sound mehr und vorne die Displays sind schwarz. also unbrauchbar
Habe lange getüftelt; so klappt's aber bei mir: alte Version 3.1r3 installieren. Vor jedem Flug Plugins: xlife, gizmo64, Saitekproflight und Zibocopilot deaktivieren (am einfachsten mit Xorganizer).
Scheinbar noch Recht verbugged das Teil.
Viele Grüße
