Re: XP11.35 JD330 v.3.2 r4
Thanks for review. Step Climb still not down for current FMGS version. We not develop so many this time, mostly - hold at fix point.
About VOR issue - sadly, not sure what understand all details. Need some screenshots may be for better understanding.
Hello!
I see, step climb is not yet implemented. So this is not an issue. And, as I mentioned, there is the work around to enter any new height in the INIT page before actually chaning the FL during cruise.
Regarding the VOR issue:
I tried to do some tests and attached an image of the problem. I found out, that this only happens to certain VORs. As an example I used the PJM VOR near TNCM. There you have the effect of the blue arrow indicator just switching the side of the Radial without closing in.
(its' a GIF animation for better understanding, i hope t works. You may have to click on it)
Then I tried some other VOR on bigger Airports (DUS, FFM and some more). There, everything works fine. The radial indicator moves slowly in and crosses upon reaching the radial the centerline of the VOR just fine.
I looked up the VOR stations on the map and the only differences I've found was, that these bigger VORs are actually VORTACS and the smller ones are "just" VOR/DMEs. Maybe there's a difference in the X-PLane logic?
I tested this again with a different Airbus (FlightFactor) and I did not encounter this behavior. It worked as intendend on every VOR.
I hope this helps, though I admit, this is only a minor flaw.
Thanks for your help. Cheers
