Re: XP11.35 JD330 v.3.2 r4
Thanks for review. Step Climb still not down for current FMGS version. We not develop so many this time, mostly - hold at fix point.
About VOR issue - sadly, not sure what understand all details. Need some screenshots may be for better understanding.
Hello!
I see, step climb is not yet implemented. So this is not an issue. And, as I mentioned, there is the work around to enter any new height in the INIT page before actually chaning the FL during cruise.
Regarding the VOR issue:
I tried to do some tests and attached an image of the problem. I found out, that this only happens to certain VORs. As an example I used the PJM VOR near TNCM. There you have the effect of the blue arrow indicator just switching the side of the Radial without closing in.
http://jardesign.org/forum/img/m/8782/t/p1dhobtcikq0k1p8i8ql172f19fj3.gif
(its' a GIF animation for better understanding, i hope t works. You may have to click on it)
Then I tried some other VOR on bigger Airports (DUS, FFM and some more). There, everything works fine. The radial indicator moves slowly in and crosses upon reaching the radial the centerline of the VOR just fine.
I looked up the VOR stations on the map and the only differences I've found was, that these bigger VORs are actually VORTACS and the smller ones are "just" VOR/DMEs. Maybe there's a difference in the X-PLane logic?
I tested this again with a different Airbus (FlightFactor) and I did not encounter this behavior. It worked as intendend on every VOR.
I hope this helps, though I admit, this is only a minor flaw.
Thanks for your help. Cheers
informatics.java wrote:
http://jardesign.org/forum/img/m/8951/t/p1dhmlrscv1e731c7ap9d19av17563.png
Rain window not working JD A330 v3.2R1. Please help me.
You cant try to update videocard drivers, but this is only thing what you can try. Else - just switch this option Off.
53 (edited by lanehammond16 2019-08-10 19:06:37)
Update with SOLUTION.
Mr. Romanov instructed me to copy my .../X-Plane/Resources/Plugins folder to a different location on my computer, (I just placed it on my desktop) and to delete the folder from the X-Plane, that way you have it as a backup on the desktop. After you delete the folder from X-Plane run the X-Plane Installer and run a update which will give you a "clean" Plugins folder. After I completed this I ran X-Plane to see if it fixed the problem and bingo, it fixed the problem. Now I have to add my plugins one by one and run X-Plane to find the plugin that doesn't work with the A330. Hope this helps anyone else who had the same problem I did.
And what was your problem?
This is your first forum post.
ich habe keinen Sound und kann das dome nicht aktivieren sowie die Checkliste nicht sehen
lösch mal den kompletten Flieger und alles nochmal neu hier runterladen und neu installieren.
57 (edited by thommy24dd 2019-08-15 16:44:12)
the Activation Window for the JD330 v3.2r1  does not appear, but the one for 320 did !
Please help!
58
Please help!
1.Redownload and reinstall aircraft (may be some file was broken)
2.If no luck - send a ticket to www.support.jardesign.org and attach log.txt file there just after you will load aircraft - I will check log and inform you what a reason may be.
59
2.If no luck - send a ticket to ... and attach log.txt file there just after you will load aircraft - I will check log and inform you what a reason may be.
I will try, thanks! smile
After Pressing Update for Metar A330 Crashed to Desktop.) Plane is unavailable
61
Since I installed this version, I cannot use the autopilot. I get this in my Log:
[SASL INFO] "ap"    AP diseng. (Pedals move reason)
According to log.txt you moved pedals … so it is normal to get AP disengaged …
If this crash is stable - please contact me skype j.a.romanov directly - we will check what happen.
64 (edited by bearhsiao 2019-08-25 00:44:28)
Dear Mr.Romanov
Meter information cannot be displayed, is it related to xEnviro?
I tried disabling xEnviro and using Active Sky XP+UWXP, but the problem still exists.
Chun-Fan. H
http://jardesign.org/forum/img/m/7843/t/p1dj3332301h7d1iat3fclrh1dgd3.png
METAR only works IMO on "standard default real conditions weather" from X-Plane.
I am using Active Sky. It works great with him.
67
bearhsiao wrote:
Dear Mr.Romanov
Chun-Fan. H
This metar readed real weather from NOAA servers and not depend of weather plugin. In some cases it not loaded. I can check it with you on your side, as personal issue.
68
Just curious how you’re calling the NOAA website? I’ve noticed that my sim locks for a good 10-15 seconds when I try and update the weather. It eventually comes back and shows the metar, but the lock is consistent and reproducible for me.
Check out your firewall settings. Maybe your OS has an issue with requests to the NOAA server.
70 (edited by georgegoosen 2019-08-28 05:36:49)
Not sure where im supposed to post this, but i bought JD A330 yesterday, and have been trying to do a startup 4-5 times. each time it crashes somewhere during the process.
Hard crashes XP back to windows.
X-Plane11.
How do i enable logging so that i can provide a log for review?
This is my current Log -> http://pasted.co/a66bc4ea
71
X-Plane11.
Look like you need redownload/reinstall your Ground Handling plugin. I see what what CTD happen in the moment of it usage.
72
bearhsiao wrote:
Dear Mr.Romanov
Chun-Fan. H
Thank you for your response. How can I start to solve this problem?
73
Thank you for your suggestion, i will try it.
74
I just closed the Windows operating system and the Router firewall. The problem still exists.
You may contact me skype j.a.romanov directly - we will check this issue on your side
