176
Re: XP11 JD330 v.3.1 r1, r2, r3
gigabenga wrote:
Very Great Support from jardesgin Nothing no Answer nothing. Never fly Jardesgin. Dear mr. Romanov I would like to think if there is a future for jardesign.
If you ever read installation file inside your ZIP pack, you can read something like this:
SUPPORT:
http://support.jardesign.org/
Please use this way.
177
Support is not on this forum …
Explain your problems on  : http://www.jardesign.org/ticket/kb/index.php
I have Question When V3.2 released.
What has a question to do with a support request? Can not you read or are you stupid?
178
I'm quite sure your parents missed something to teach you. (decency, patience and respect as well)
179
Do not know who is stupid …
Your wording is "great support from jardesign"
and my answer " Support is not on this forum …"
and that's right .
installed as per instructions and updated all plugin's including java and I still get an activation screen?
181 (edited by blopes 2019-06-30 22:56:00)
J.A.Romanov
When will we see the yaw damper fixed? I bought this aircraft in 2017 and still not fixed.
182
Hi, Mr. J.A.Romanov! How are you?
At this moment I only have a Ground Handling, but I want to buy a A330 and A320, but I would like to know if you will implement a individual FMC (pilot / first officer) ? I would like to suggest a tablet to have: payload and fuel loader, performance calculator (flex temp, v1, vr, v2 speeds), integration with ground handling and better pushback!
I'm a software developer, and I know that isn't so simple to do but, I think this will be a really good update for both planes (A320 and A330)!
I think should improve a performance difference when chose another engine, with thrust and fuel flow, tire pressure difference between the wheels, the weight of FOB always grow by thousand and hundreds.
At Airbus the fuel is displayed 14200kg instead 14256Kg!
At some routes the airplane lost the way, and I already saw users with this same problem!
I saw this "problems" when a flew at my friend X-Plane 11.35 and the last version of JarDesign airplanes!
And I would like to know how is a A340 development?
That is all, I would like to congratulate you by the outstanding user support, you are really a example by others developers!
Dear support,
I am running a triple=monitor setup. (3x27 inch, 1440p), no surround, running them separately.
Is it the case that JD a330 does not support it at all?
I am on version 3.1r3
The main monitor stays black (with the MCDU screen in the corner) while the side ones are ok.
Can you please advise?
p.s. all the other aircrafts I have work great.
184
blopes wrote:
J.A.Romanov
Please use actual beta for 11.35 - it have MCDU MENU option to fix abnormal turbulence of the weather.
185
Hello! Sure, all this calculation already exist at MCDU without tablet. Thank you for other ideas. JD340 is on 3D modelling stage now. Sadly, cant guess a release date.
186
yarplaz wrote:
Dear support,
This is not support, but on www.support.jardesign.org
About this issue - sadly, this aircraft was not tested at 3-monitor mode. Just cant say any.
187
Good evening,
Are there any plans to get the A330 working in VR?
At the moment I load it up and all the screens are blank (but it still looks awesome
188
Hello!
Is the A330 still being worked on? And what?
