Hi, Mr. J.A.Romanov! How are you?
At this moment I only have a Ground Handling, but I want to buy a A330 and A320, but I would like to know if you will implement a individual FMC (pilot / first officer) ? I would like to suggest a tablet to have: payload and fuel loader, performance calculator (flex temp, v1, vr, v2 speeds), integration with ground handling and better pushback!
I'm a software developer, and I know that isn't so simple to do but, I think this will be a really good update for both planes (A320 and A330)!
I think should improve a performance difference when chose another engine, with thrust and fuel flow, tire pressure difference between the wheels, the weight of FOB always grow by thousand and hundreds.
At Airbus the fuel is displayed 14200kg instead 14256Kg!
At some routes the airplane lost the way, and I already saw users with this same problem!
I saw this "problems" when a flew at my friend X-Plane 11.35 and the last version of JarDesign airplanes!
And I would like to know how is a A340 development?
That is all, I would like to congratulate you by the outstanding user support, you are really a example by others developers!
