176
Re: JD320 v.3.4 public beta
yes, we already know about issue with BSS soundpack
Confirmed... Got it too... I think I got problems with the autopilot behaviour, but need to test it a little bit more.
177 (edited by F1le 2019-07-26 10:36:20)
And sometimes I have no idea why I got a bug, that this screen is cleaning out by itself, and F-Plan removes all speeds and all altitudes.
I need to change the plane in this moment as I was not able to fly away from LEMH due to unknown reasons?
178
FMGS: 629 : PluginPath=E:\X-Plane 11\Aircraft\Extra Aircraft\320_JARDesign\plugins\fmgs\
FMGS: 629 : AircraftPath=E:\X-Plane 11\Aircraft\Extra Aircraft\320_JARDesign\
FMGS: 631 : ICAO-format plan export to Dataref: KVPS SID CEW J2 DEFUN J2 OJHAP J2 SZW DCT HEVVN STAR KPIE
FMGS: 638 : JARDesign FMGS  plugin ver.FMGS-280619 detect crash.
FMGS: 638 : Memory dump saved to fmgs.dmp file
FMGS: 638 : Please send this log.txt file and fmgs.dmp file (from X-Plane folder) to support@jardesign.org !
179
Is this aircraft ready for 11.35 final ?
X-Life Deluxe
GHD
FMCAR
JD320
180
Hi, what was changed in the latest 3.4 v5 beta? Thank you
181
Just put "320_JARDesign" into E:\X-Plane 11\Aircraft\ if you are having an issue with your set-up
182
Hey,
I just bought the plane and I am pretty happy with it but since I use this beta version, the plane isn't following the flight plan. It's just flying straight. Is it a known issue and is there a fix?
183
Binary11 wrote:
Hey,
1. Faster way - skype j.a.romanov for direct help
2. Alternate way - www.support.jardesign.org with log.txt file saved just after you trying fly this version.
184
domined39aniello wrote:
Blaser wrote:
Bought this product today and I do not know if there is an activation issue or what is going wrong. The engines keep spooling from 5% to 150% uncontrollably without me moving the throttles and without them moving in VC, I have disabled my Saitek panels just in case. Not sure what is going on. I am running XP11.35b5. Any help is appreciated
Try beta version download A320jar 3.4b4
This is your answer to everything.
The beta, It doesn’t work.
185
is this happened after XP replay?
186 (edited by trooperMNG 2019-08-02 11:32:44)
3.4b5, sim freezes for 15 seconds when updating metar. I know it's a fictional feature but I'd like to have a working CPDLC metar in the future. The bug has been there for ages. Same thing for the speed brake indication on eicas and lots of other things... are they being worked on? The changelog is non existent, what were the improvements? Or is it merely an X-Plane 11.35 update?
Also, taxiing has worsened a lot, it's overly sensitive in the latest beta. I don't know if my flight had too many strict turns but LNAV and VNAV logic seems to be worse too (but I don't know if those features where changed)
187
As the beta-test period is over, we post a release version here http://jardesign.org/forum/viewtopic.php?id=11625
I want to say Thank You for all your reports, comments, efforts!!!
