Topic: JD320 v.3.4 public beta
So.. a320 for X-Plane 11 version 3.4 public beta here.
This version get new/updated FMGS, like JD330
beta 1:
+ brand new FMGS installed
beta 2:
+ incorrect sys disp page fixed
+ acceleration on descend fixed
beta 3:
+ METAR info reading fixed
+ on-screen GPU button add
beta 4:
+ X-Plane 11.35 compatible
+ add MCDU MENU -> SETTINGS options
+ add SATCOM 3d model
beta 5:
+ FMGS module updated
Download link:
http://jardesign.org/a320/download/inst … 1_345b.zip
Updated CoPilot Download link:
http://jardesign.org/copilotdownload/JD … 240619.zip
!!! Please set X-Plane Experimental flight model to Off/Disable
  - Please not mix files with other version.
  - make sure, that you use X-Plane 11.26-11.31
    (make sure you don't use nonEnglish symbols in aircraft's installation path)
  - start X-Plane 64 bit and open a320, activation window will pop up
  - enter your serial key (Regcode), click NEXT and after a successful activation reopen the aircraft via X-Plane menu
(create it if need)
Please note what this time we have beta of X-Plane 11 and beta of a320 ("beta" - product for testing and may not work well, hare errors and so on). If you need release, need stable version, please wait.
POSSIBLE / KNOWN BUGS:
- sound issue with BSS pack?
Re: JD320 v.3.4 public beta
Some useful notes for this version:
- Check Off "Experimental flight model" at X-Plane General Tab
http://jardesign.org/forum/img/m/22/t/p1d3t6n4tj1a2q907bo213k71a0u3.jpg
- Use GPU button to connect Ground Power
http://jardesign.org/forum/img/m/22/t/p1d3t6ock21i9i1elu1e1v17pe4dc5.jpg
- Setup hotkeys to call MCDU and MAP onscreen widget
http://jardesign.org/forum/img/m/22/t/p1d3t6prj812an17k512b21bohh717.jpg
- Use MCDU MENU to manage your handling / fuel / tow /settings / screenside toolbar
http://jardesign.org/forum/img/m/22/t/p1d3t6rdul18g5nci1tvv1q0118q6a.jpg
- After entering FROM/TO at Init A page you will get ability to generate flightplan or load presaved from FlightPlan folder
http://jardesign.org/forum/img/m/22/t/p1d3t6thcmnkbaon7pf1v5t1t7cd.jpg
http://jardesign.org/forum/img/m/22/t/p1d3t77mdf3rfs5v6b01t9o1fidg.jpg
- to save your flightplan you may use MCDU -> DATA -> Arr Right -> Pilot Routes
http://jardesign.org/forum/img/m/22/t/p1d3t78as3di810l1f6l18f21jeij.jpg
reserved
reserved
Sir my best regards
I have a problem with paid sound all the time I hear such clicking there is some solution
I just update the JD320 v.3.4 beta and impossible to make him follow the flight plan the plane runs around constantly.
A solution to the problem.
cordially
Luciano
7 (edited by kicaj 2019-02-17 13:24:08)
The flight plan works perfectly in the previous version it was different, only then is the problem with paid sounds
I have got that BSS Sound Problem as well.
I have the same problem with BBS sounds
yes, we already know about issue with BSS soundpack
11 (edited by kicaj 2019-02-17 14:22:22)
Good job, now he's on tour, there is a chance that the cab lighting works like the A330 BRT
As all versions before :
Why are the light knobs are not same direction, some are scroll up for right/up and others are down for right/up
Please make the controls consistent in usage
X-Life Deluxe
GHD
FMCAR
JD320
Amazing aircraft and very pleased with my purchase, just one thing I would like you guys to fix it besides the HDG sound related to BSS... as you can see in my picture... when flying night flights the PFD and the ND look brighter than the two ECAM displays and I couldn't decrease the brightness in them to equal to the ECAMs so they all look the same... just to have more control over the displays' brightness... thank you so much for looking into it... best regards and keep up the incredible work you're doing in all of your addons...
Martin
We put to beta-test new FMGS work now. Sure, we continue work on cockpit/indication details.
15 (edited by euroking2018 2019-02-18 06:51:23)
X-Plane 11.32 r1 crashes when you push one button  in the cockpit.
Greetings Martin
Greetings Martin
Thanks for report! If you have it stable, please reinstall aircraft (not mix with old files) and try. If no luck - please contact me skype j.a.romanov - we will check on your side
Look like this strings make HDG sound at /plugins/BSS/cockpit/sound.cfg:
# FCU push/pull rotation ################################
type=3d
play=once_when_drf_change
filename=rotatefcu.wav
play_drf=sim/custom/xap/fcu/alt100x
play_drf=sim/cockpit2/autopilot/heading_dial_deg_mag_pilot
x_position=0
y_position=2.14
z_position=-14.14
vol_int=1
vol_ext=0
until new version of BSS will come you may modify it to:
#type=3d
#play=once_when_drf_change
#filename=rotatefcu.wav
#play_drf=sim/custom/xap/fcu/alt100x
#play_drf=sim/cockpit2/autopilot/heading_dial_deg_mag_pilot
#x_position=0
#y_position=2.14
#z_position=-14.14
#vol_int=1
#vol_ext=0
Thank you for the last version V3.4B3. It's run very good with the Copilot, a very nice plugin.
mermoz
windows 10 Pro
Greetings Martin
It was up to x europe 2 scenery.
She was registered incorrectly.
Greetings Martin.
thanks helped
I have a question whether it is possible to do the tablet as it is in the A320ff?
Hi Team!
I've checked SABE-SACO in two opportunities and I think TOD is not calculated correctly because on APPR Phase I have 4000 ft on FIX over charts indications.
I've to try GO AROUND procedure because speed and altitude is not correct.
It was on DES mode, not OP DES mode.
Thanks in advance!
ariel.walker wrote:
Hi Team!
Thanks in advance!
Firstly, need check vertical profile in details using command to show AM and select Vert.Profile
Hello Srs. Problem with the BSS sound package. Does anyone know how to fix the problem?
Wait for A320v3.4 to come out of beta and for BSS to update their product.
