Re: JD320 v.3.4 public beta
DCDU still freezing X-Plane for a good 10 seconds before loading information. Latest X-Plane and A320 beta
JARDesign Group Board → Beta-versions (Download & Discussions) → JD320 v.3.4 public beta
Using JD320-V3.4B4, I saw that the QNH in Mb on both P1 and P2 PFD's jumps in increments, for instance it will show 1013, then 1015, 1017, etc, but not 1014, 1016 etc.
Thanks,
Fabio
JD320 3.34B4: ILS on RAD/NAV MCDU page missing last digit (109.95 shows as 109.9; same on the A330).
SPEED BRK shows on EICAS after takeoff when spoilers disarmed.
Thanks,
Fabio
Also, missing T/O and LDG INHIBIT on EICAS
I'm on JD330 V3.0R4 and XP 11.34r1. Each time I'm landing my armed ground spoilers are inactivated and the yellow speedbrake message is flashing. This happens when 1000 is announced. Quite annoying as I cannot arm the spoilers again. I manage to land but....
Any suggestions or have I found a bug in the beta?
Jan
Its very unlikely that you found a bug in the JD320 V3.4beta using the JD330 V3.0R4
Suggestion: Get the current JD330 beta (3.2) and post in the JD330 3.2 beta topic:
http://jardesign.org/forum/viewtopic.php?id=11578
when i use A320JAR i lost -20 fps and i stay around 30 fps, the with 330 i have 50/60 fps
Bought this product today and I do not know if there is an activation issue or what is going wrong. The engines keep spooling from 5% to 150% uncontrollably without me moving the throttles and without them moving in VC, I have disabled my Saitek panels just in case. Not sure what is going on. I am running XP11.35b5. Any help is appreciated
Try beta version download A320jar 3.4b4
This is a bug. Can you instruct me what need to do to get the same on my side, please?
yes so , to have this problem, I modified a fix putting a height constraint and deleting another point and then I deleted a discontinuity. I don't know exactly how he did it but it doesn't happen often
B5 is very stable. Thank you.
Why do the trim wheels jerk back and forth constantly?
Will you ever fix the HDR—still can't set it on the ground before take off?
Brad
i cant do the flare beacuse when i pull the stick the airplane take positive noose up to 10 degres so i can only go around.
with 330 i can do the flare very well as real . i use saitek pro flight yoke
J.A.Romanov wrote:This is a bug. Can you instruct me what need to do to get the same on my side, please?
Hmm.. Not so simple, but I need to get it on my side to debug it. If you can contact me skype j.a.romanov - that will be useful for this issue fix. If you can - please!
Giuliano pennetta wrote:J.A.Romanov wrote:This is a bug. Can you instruct me what need to do to get the same on my side, please?
done it
One bug thats been irking me for a while and continued into this version.
I go into replay to examine my takeoff/landing, and then when i'm done I leave replay to continue my flight. Upon leaving replay, the plane always seems to immediately lose control and I suffer dual engine failures at the same time. It's been the only thing keeping my A320 grounded for a long time, so any help would be awesome.
Known bug. before back to actual simulation deactivate A/TH. After that activate it for new...
Why range can be set max to 160 not 320?
X-Plane weather radar map have limited range.
F1le wrote:Why range can be set max to 160 not 320?
Hi Eugeny, isn't it possible to let the map wide to 320 and restrict the weather view on a 160-radius? Just asking, I don't know if it's feasible. Is map range also related to the choice of not be able to select multiple display options (CSTR, WPT, VOR.D, NDB, ARPT)? That would be also useful
i dont know how this happend, but Speedbrakes settings has become out of sync between
control and the computer systems
speed brakes armed:
during flight i got no "speed brake" message in upper ecam
during approch the blue splrs "arm" does not dissapear
speed brake disarmed:
during flight i got "speed brake" message in upper ecam, right part
I dont know when during flight this happend
Been having an issue with the plane where when entering an arrival how it should be entered, some red text appears warning of apparent missing waypoints and the arrival doesn't enter correctly, can anyone else confirm the issue? Seems to happen when DME Arcs are involved, does this support DME Arcs at the moment? If not that explains
Kieran.
EDIT: Some screen shots showing step by step what I mean. Arrival is LEMG ILS31Z via VU2DCJ which has a DME arc. The section that fails is between two waypoints that should be joined by a DME Arc bu instead there is just a discontinuity and you have to get rid of that resulting in a straight line instead.
Some (2 as i remember) kind of legs cant be read with correct way. This is a reason for message. We will fix this in future, but as for now - need use another STAR or add points manually. Sad about this.
NAV/LOGO light only 2 steps instead of 3
