Topic: v.3.2 beta public tests
This is next public version of a330 for X-Plane 11. Please take part in this beta-tests if you really want be beta-tester. If you want fly-ready product - please just wait. Main goal of this beta - test new "Visual Avionics" development platform.
What new:
beta 1:
+ some systems migrate from SASL to VA (Visual Avionics)
+ APU system reworked
+ ECAM action system reworked
+ Rudder (normal law) algorithm improved
+ about 20 minor improvements
beta 2:
+ LDG MEMO not show fixed
+ Before takeoff checklist fixed
+ No firetest sound fixed
+ no MW, MC sound fixed
beta 3:
+ Crash on load (on some Windows OS) fixed
beta 4:
+ compatible with XP 11.35
beta 5:
+ FMGS module updated
Download link:
http://jardesign.org/a330/download/inst … 1_325b.zip
Download link to updated CoPilot version:
http://jardesign.org/copilotdownload/JD … 200619.zip
You may install aircraft at separate folder and use both - old and new version.
Please avoid publish message like "Crash on loading" or like this tithout any details. This will really not helpful and not need on beta test stage. Please understand this.
In the case of wrong voice recognition setup crash on loading stage may happen. Please be ready to contact JAR via skype j.a.romanov to demonstrate how this going and make real fix for this by our crew.
Please install Ground Handling plugin to be well-compatible with XP11
Download link: http://jardesign.org/gndserv/download/GHD.zip
- be sure, that you use X-Plane 11.34 (not work with beta 1,2 versions of 11.35)
- copy unziped "JD330XP11" folder to ..\X-Plane 10\Aircraft\ folder
- please visit download more fresh version of Ground Handling plugin. It work with JARDesign 330 without registration (for free). Please note what “Deluxe” version of this plugin (may work with other aircrafts) is payware.
- enter your serial key (use exist serial from "JD330 for X-Plane 11"), click NEXT and after a successful activation reopen aircraft via X-Plane menu
a330 use NavData from
../X-PLANE 11/Custom Data/GNS430/navdata/ folder
../X-PLANE 11/Aircraft/330_JARDesign/_navdata/
and put new cycle to ..X-PLANE 10/Custom Data/navdata/ folder
If you want to test how failures system work, you need use DatarefEditor plugin and enter "jd/bugs/" there. You will get small number of datarefs what may generate faults - APU Fire, as example, if you change value from 0 to 1.
Please note what this time we have beta of JD330 ("beta" - product for testing and may not work well, hare errors and so on). If you need release, need stable version, please wait.
- you may post you opinion about this version, post what you like/unlike
- please post your log.txt if Crash happen.
Please care about information what you will post here and try to determinate reason if issues happen - sure, he interesting in aircraft test and troubles but want to avoid work with "pilot" issues.
Thank you!!!!
This is FREE update for users who own "JD330 for X-Plane 11" product.
