Topic: CoPilot for JD330 v.141020
This is CoPilot plugin for JD330.
features:
+ animated 3d CoPilot model (female, "Linda")
+ can recognize and execute command
+ can speak
+ can read checklists
+ can operate with Events (flight parameters detection)
+ can execute SOP (Normal Procedures, Limited)
+ scripts based (possible to edit/change Procedures/Text/etc)
versions:
070219:
+ minor bug in scripts fixed
200619:
+ compatible with JD330 v.3.2 http://jardesign.org/forum/viewtopic.php?id=11620
060420:
+ compatible with JD330 v.4
141020:
+ compatible with JD330 v.4.1
about using with JARDesign CoPilot plugin:
You can download and install it
http://jardesign.org/copilotdownload/JD-CPL-330.zip
Setup and using manual already included. This plugin is a separate product by JARDesign, work with JD330 for free. Voice recognition function execute by your computer OS (Win 10 or MAC OS). CoPilot plugin just use it. So, voice recognition ability and quality depend of your OS settings and hardware. Speech quality also depend of your installed text-to-speech voices. This plugin will not work with non-English version of your OS. You should setup and check your English voice recognition on Windows 10 or Mac BEFORE this plugin installation.
