Topic: CoPilot for JD330 v.141020
This is CoPilot plugin for JD330.
http://jardesign.org/forum/img/m/22/t/p1crc775edmnr1q7l1bd1c1k1i8j3.jpg
features:
+ animated 3d CoPilot model (female, "Linda")
+ can recognize and execute command
+ can speak
+ can read checklists
+ can operate with Events (flight parameters detection)
+ scripts based (possible to edit/change Procedures/Text/etc)
versions:
070219:
+ minor bug in scripts fixed
200619:
+ compatible with JD330 v.3.2 http://jardesign.org/forum/viewtopic.php?id=11620
060420:
+ compatible with JD330 v.4
141020:
+ compatible with JD330 v.4.1
about using with JARDesign CoPilot plugin:
You can download and install it
Setup and using manual already included. This plugin is a separate product by JARDesign, work with JD330 for free. Voice recognition function execute by your computer OS (Win 10 or MAC OS). CoPilot plugin just use it. So, voice recognition ability and quality depend of your OS settings and hardware. Speech quality also depend of your installed text-to-speech voices. This plugin will not work with non-English version of your OS. You should setup and check your English voice recognition on Windows 10 or Mac BEFORE this plugin installation.
Re: CoPilot for JD330 v.141020
reserved
Copilot landing Events commands "Landings light on" repeat continuously - this is some loop, they don't stop executing.
Copilot landing Events commands "Landings light on" repeat continuously - this is some loop, they don't stop executing.  ME To
I've finally got Linda behaving well - except she won't stop going on about those Landing Lights!!
OK I try to stopping Copilot "Landings light on" repeat continuously,
I'll find some mistake in command file. If you want to stop this repeating you can change txt file in JAR330XP11\plugins\copilot_main\custom\events\Descent\Landing lights.txt
with
#EVENT
if:sim/custom/xap/fly_phase==4
and:sim/cockpit2/gauges/indicators/altitude_ft_pilot<10000
and:sim/custom/xap/extlight/landl_sw!=1
#RESET
reset:sim/custom/xap/fly_phase!=4
#EXECUTE
pos:landlight
drf:sim/custom/xap/extlight/land_sw=1
say:Landing lights on!
pos:rest02
It's work for me fine.
I think there is a problem with script VARS.
I try to create scripts based on VAR values and it seems it doesn't care about it all.
But looking at xplane log , I see such kind of messages:
JD COPILOT Plugin: ReadFileListFromFolder=C:\X-Plane 11\Aircraft\Extra Aircraft\JD330XP11r3\plugins\copilot_main\custom/events/Approach/
JD COPILOT Plugin: Error in script - cant find dataref: APPCLEXEC
JD COPILOT Plugin: ReadFileListFromFolder=C:\X-Plane 11\Aircraft\Extra Aircraft\JD330XP11r3\plugins\copilot_main\custom/events/Checklist/
JD COPILOT Plugin: Error in script - cant find dataref: LANDCLEXEC
JD COPILOT Plugin: ReadFileListFromFolder=C:\X-Plane 11\Aircraft\Extra Aircraft\JD330XP11r3\plugins\copilot_main\custom/events/Cruise/
JD COPILOT Plugin: Error in script - cant find dataref: 1
JD COPILOT Plugin: Error in script - cant find dataref: CHECKPHASE
JD COPILOT Plugin: Error in script - cant find dataref: 2
JD COPILOT Plugin: Error in script - cant find dataref: 3
JD COPILOT Plugin: Error in script - cant find dataref: 0
JD COPILOT Plugin: ReadFileListFromFolder=C:\X-Plane 11\Aircraft\Extra Aircraft\JD330XP11r3\plugins\copilot_main\custom/events/Misc/
JD COPILOT Plugin: Error in script - cant find dataref: GLASSMANUALCONTROL
CHECKPHASE are my VAR but others are yours and I wonder why it complains about unkown dataref whereas it's not dataref but VAR declared in script.
Is it normal?
Alain
8 (edited by alain.bo 2019-04-08 19:11:20)
The cockpit preparation procedure is not correct about battery voltage checking.
Linda cannot check voltage if batteries are not first set ON.
And she should check both battery 1 and 2.
And if voltage is below 25V, she should ask for GPU.
So my proposal is:
##################### Batt #######################
pos:lookovhd
if:sim/custom/xap/elec/bat1_on==0
pos:bat1
drf:sim/custom/xap/elec/bat1_on=1
endif:
if:sim/custom/xap/elec/bat2_on==0
pos:bat2
drf:sim/custom/xap/elec/bat2_on=1
endif:
if:sim/custom/xap/elec/batind_sw!=2
pos:batmode
drf:sim/custom/xap/elec/batind_sw=2
posfast:batmode2
endif:
if:sim/custom/xap/elec/bat_volt<25
if:sim/custom/xap/elec/gpu_av==0
saywait:Battery voltage is too low, please ask for GPU
endif
pos:lookovhd
waitdrf:sim/custom/xap/elec/gpu_av>0
pos:ext-a
drf:sim/custom/xap/elec/gpu_onA=1
saywait:External power, is on! Waiting for battery charging
pos:lookovhd
waitdrf:sim/custom/xap/elec/bat_volt>25
else:
saywait:Battery one voltage check above twenty five!
endif:
if:sim/custom/xap/elec/batind_sw!=1
pos:batmode
drf:sim/custom/xap/elec/batind_sw=1
posfast:batmode1
endif:
endif:
pos:lookovhd
pos:ext-a
pos:lookovhd
else:
saywait:Battery two voltage check above twenty five!
endif:
drf:sim/custom/xap/elec/batind_sw=0
posfast:batmode0
if:sim/custom/xap/elec/bat3_on==0
pos:bat3
drf:sim/custom/xap/elec/bat3_on=1
endif:
saywait:Battery one, two and A P U, auto!
pos:lookovhd
if:sim/custom/xap/elec/gpu_av==1
pos:ext-a
pos:ext-b
drf:sim/custom/xap/elec/gpu_onB=1
saywait:External power, on!
endif:
pos:lookovhd
if:sim/graphics/animation/draw_light_level==1
and:sim/custom/xap/light/dome_on==0
pos:domelight
drf:sim/custom/xap/light/dome_on=1
endif:
#################### APU fire test ###################
http://jardesign.org/forum/img/m/1591/t/p1ag065c1c1b6i1mdf7dgs75ovq3.gif
So my proposal is:
pos:lookovhd
pos:bat1
endif:
pos:bat2
endif:
pos:batmode
posfast:batmode2
endif:
endif
pos:lookovhd
pos:ext-a
pos:lookovhd
else:
endif:
pos:batmode
posfast:batmode1
endif:
endif:
pos:lookovhd
pos:ext-a
pos:lookovhd
else:
endif:
posfast:batmode0
pos:bat3
endif:
pos:lookovhd
pos:ext-a
pos:ext-b
endif:
pos:lookovhd
pos:domelight
endif:
Why having removed take-off procedure??
Alain
Gentlemen,
Linda gets stuck switching the landing lights on before landing.
Is it a know bug?
Any suggestion?
sKYMATIX wrote:
Gentlemen,
Is it a know bug?
Any suggestion?
See post 6
Downloaded and put the 2 files under the plugins folder. Speech recognition works fine.However, no files appear at all under the co pilot folder.
Also get an acf file error message.
can't really say anything without a log.txt but sounds like your install is faulty. Try to install again and follow the instructions religiously
Thanks.Will do
Works fine now after reinstall.Thankyou.
17 (edited by dudleybrooke 2019-06-24 15:13:08)
The copilot speaks through my speakers even though all X-Plane sounds are through my headphones, in fact, all system sounds are too.  she doesn't respond to the microphone either.  Is there a setting for this?
Make sure you configure your sound input/output before you start XP
19 (edited by dudleybrooke 2019-06-25 12:28:42)
I do, as I said, every other sound comes over the headphones. XP itself, the A330, other plugins(Better Pushback for instance ), Windows itself.  It's just the co-pilot.
You will find here https://forums.x-plane.org/index.php?/f … ot-plugin/ a slightly customized last available version of the Copilot plugin for JD330 v3.2b4.
I also propose you a XChecklist to help you sequence procedures and checklists from parking to parking.
Kind regards,
Alain
We just update version to be compatible with JD330 v.3.2
features:
+ can speak
versions:
070219:
200619:
Hi Mr. Romanov,
first of all thank you very much for your awsome work. I do have ALL plugins of JD. By the way I was informed by a pilot that the APU start is prohibited to be so early (during the preliminary cockpit preparation). Normally the APU start takes place during the "before start procedure". Im not a programmer but this matter of fact should be considered in your copilot plugin.
Is there a way to re-programm it?
Thank you in advance.
I would appreciate every comment made to this subject!
with kind regards
Bernd Schwarz
23 (edited by glen958 2020-07-11 23:05:10)
http://jardesign.org/forum/img/m/10590/t/p1ed01vlk6huhmpm1ium1fdb9f13.pngHow do i get rid of this on side of the screen when i use co pilot?
Go to "your disc":\X-Plane 11\Aircraft\JD330XP1150\plugins\copilot_main\custom\ and find settings.txt. then with text editor replace last line developer=1 to developer=0
thanks for your help did the trick.
