Topic: JD320 v.3.4 public beta
So.. a320 for X-Plane 11 version 3.4 public beta here.
This version get new/updated FMGS, like JD330
beta 1:
+ brand new FMGS installed
beta 2:
+ incorrect sys disp page fixed
+ acceleration on descend fixed
beta 3:
+ METAR info reading fixed
+ on-screen GPU button add
beta 4:
+ X-Plane 11.35 compatible
+ add MCDU MENU -> SETTINGS options
+ add SATCOM 3d model
beta 5:
+ FMGS module updated
Download link:
http://jardesign.org/a320/download/inst … 1_345b.zip
Updated CoPilot Download link:
http://jardesign.org/copilotdownload/JD … 240619.zip
!!! Please set X-Plane Experimental flight model to Off/Disable
- Please not mix files with other version.
- make sure, that you use X-Plane 11.26-11.31
(make sure you don't use nonEnglish symbols in aircraft's installation path)
- start X-Plane 64 bit and open a320, activation window will pop up
- enter your serial key (Regcode), click NEXT and after a successful activation reopen the aircraft via X-Plane menu
(create it if need)
Please note what this time we have beta of X-Plane 11 and beta of a320 ("beta" - product for testing and may not work well, hare errors and so on). If you need release, need stable version, please wait.
POSSIBLE / KNOWN BUGS:
- sound issue with BSS pack?
