I made a modification to the ADIRS procedure in the Cockpit Preparation:
It now waits for the ADIRS to go "Off battery" before turning the next one on. I also changed the sequence so that IR2 is turn on second, even though it is located on the far right and IR3 (in the middle) is turned on last. Lastly, I added the SYS and DATA knobs to be turned to the correct position and the ENT button to be pressed as per procedure.
@WindSocks, it would be great to have position (pos:) values for the two knobs and the button
I also want to express my huge appreciation for what you guys have achieved!
###################### ADIRS ####################
pos:lookovhd
pos:look adirs
if:sim/custom/xap/adirs/mode_sel_1==0
pos:adirs1
drf:sim/custom/xap/adirs/mode_sel_1=1
posfast:adirs1-1
endif:
if:sim/custom/xap/adirs/mode_sel_3==0
waitdrf:sim/custom/xap/adirs/on_bat=0
pos:adirs3
drf:sim/custom/xap/adirs/mode_sel_3=1
posfast:adirs3-1
endif:
if:sim/custom/xap/adirs/mode_sel_2==0
pos:adirs2
drf:sim/custom/xap/adirs/mode_sel_2=1
posfast:adirs2-1
endif:
if:sim/custom/xap/adirs/sys_sel!=1
drf:sim/custom/xap/adirs/sys_sel=1
endif:
pause:0.5
if:sim/custom/xap/adirs/data_sel!5
drf:sim/custom/xap/adirs/data_sel=5
endif:
pause:0.5
drf:sim/custom/xap/adirs/knob_ent=1
saywait:All ADIRS, NAV!
