Topic: X-Life ver 4 for X-Plane 11
Hello! This time X-Life plugin was reworked again. We use X-Plane fresh API now and make this plugin VR-compatible. About 2300 strings of c++ code added.
Download link to Actual build
What New:
v.4_050718 (first test build of v.4)
+ new ATC panel design
(movable, auto-hideable, resizable with mousewheel)
+ add VR-support for ATC-panel
+ add "Set Baro readback"
+ add "Set Squawk readback"
+ many CTDs fixed
+ framerate optimisation
+ pdf manual included
v.4_070718 (updated build of v.4)
+ flightplan import/export buttons for JD320/330 fixed
v.4_090718 (updated build of v.4)
+ landing performance for AI aircraft(s) updated
v.4_210718 (updated build of v.4)
+ long Callsign is possible now
+ "cant close" ATC Panel issue fixed
+ takeoff without clearance issue fixed
+ any Departure Airport may be entered at FPLN page
v.4_090219 (updated build of v.4)
+ METAR issue fixed
v.4_120319 (updated build of v.4)
+ microfreezes issue fixed / improved
v.4_010519 (updated build of v.4)
+ Flightplan export to default X1000 FMC improved.
+ Add pause before takeoff for traffic aircraft(s).
v.4_250719 (updated build of v.4, need reinstall full plugin)
+ ATC panel "auto-hide" off setting add
+ More than 30 compatible airports add
v.4_140819 (updated build of v.4)
+ Nvidia threaded optimisation compatible
+ ATC panel unexpected hide fixed
v.4_211019 (updated build of v.4)
+ macOS Catalina compatible
Installation:
Please unzip pack and follow .PDF manual.
If you prefer use HD “Bluebell XL” traffic AI library, please download 3 files from
Airport Editor manual by Philip Walchester posted here
http://jardesign.org/forum/viewtopic.php?id=3261
Flight Manual (german&english language) with example flight using B757
Attached to this topic (thanks for Horst-Helmut Krause)
FMCar update
All remain the same
