151 (edited by julien.hanel 2018-05-20 09:40:57)
Re: X-Life ver 2.2 R1, R2, R3 for X-Plane 10/11
Hello, I have a problem with KSNA airport, only SWA aircrafts stop at the end of runway 2L or 20R in take off procedure. ASA,UAL, AAL, FFT and GA aircrafts take off normally. No problem on other airports.
julien Pierre
152 (edited by daviddemi 2018-06-07 17:35:31)
Ho bisogno di aiuto per favore. Ho xlife deluxe da mesi e sempre tutto ok. Da oggi non si attiva flight plan Come posso risolvere problema? grazie
153
I find your application really beautiful and practical. It is simple to use. I have a question. Would you be able to do the same thing with helicopters. Takeoff and landing on heliports? It would be really good because I fly helicopters and I feel alone in x-plane.
Thank you in advance for your answer.
Best regards.
Stéphane
154
Lugano airport (LSZA) from Aerosoft and X-Life delux, two CRJ2 complete blocked runway and traffic!
RWY is 4429 feet/1350 m. This is a little bit to short for CRJ2!
How this deadlock can bi solved?
155 (edited by TKurzweg 2018-06-18 20:29:47)
XP11.21 (no beta) without AlpilotX HD Mesh, without extra Orto4XP tiles crashed after a few minutes on departure airport!
Without X-Life (Deluxe Version) everything works fine. Even when I activate X-Life for a flight it crashed without warnings!
Update:
XP 11.21 crashed also with a fresh installed X-Life Deluxe Version!!! Can't use X-Life with XP 11.21 anymore. Crashed at departure airports, in-flight or at landing. No fun for me.
BluebellXL: No updates, old airlines (Air Berlin, FlyNiki...), old liveries (I have create some own new colors like Eurowings and Sundair) and so on! Sundair A320 fly from EDDK, EDDT and EDVK (never show in X-Life).
This time I have de-installed X-Life Deluxe and use 124th ATC...no more traffic at the airports and in the air, BUT IT WORKS!
156
Hey friend I have a problem, is that I appear airlines around the world except the local country
157
==== CHANGING LANGUAGE TO: Português. ====
Fetching plugins for C:\X-Plane 11/Resources/plugins
Loaded: C:\X-Plane 11/Resources/plugins/PluginAdmin/64/win.xpl (xpsdk.examples.pluginadmin).
X-Life plugin by JARDesign Ver.2.2 r3 040418
XL: 0 : UUID=0f6b0dd1-c80e-413a-b091-63a30b897b7b
--=={This application has crashed because of the plugin: xlife/win.xpl}==--
158
Hi jar can you tell me how to get orbx Barton to work with xlife or can you get in touch with orbx to  get there products verified please as they have a lot of good airfields comeing for xplane thanks
159
Just wondering will there be any new update soon for X-Life? Or can any info be given on whats coming ahead in the next version? Been a long time since the last update
160
Crashed after 5 hours flight just before landing BIKF.
161
I'm running X-Life R3 in X-Plane 10.25b1 and I've seen on a couple of occasions aircraft coming in to land and then veering left or right and diving into the ground. Planes taking off have also veered to left or right and then dived into the ground. It doesn't happen to all take offs and landings.
Never noticed it before, strange.
162
Hello X-Life Developer
Since today i got huge frame drops when i start using x-life deluxe. Till yesterday it worked fantastic, but since today, when i check the taskmanager my cpu and gpu ussage is normaly around 50 to 80 percent in use and when i start x-life deluxe traffic my cpu and gpu ussage drops to around 10 to 20 percent in use and the frames in x-plane are half, from 50 to around 22.
Something changed because till now it was running very good. I tried a new install of x-life but the same thing happend.
Sorry for my bad english, but i hope you understand it.
Thanks for checking
Best Tobi
163
Hi X-Life Developer
I found my problem, i turned on tthreaded optimization and this was the reason for the frame hit. Yep.
Best Tobi
164
After using X-Life Deluxe for a couple of months now, I noticed that when you're flying between airfields, continental or inter continental, you hardly see any aircraft.
They tend to stick within a X kilometres distance of a airfield.
Is there something to be done about this ?
(It's quit boring when you're the only one over the atlantic ocean)
165 (edited by laohu314 2018-09-10 14:57:37)
I am still getting a CTD at AYPY and I have no clue why. No errors in airport editor but the log and crash report point at X-Life. And now I also cannot upload files, only images??
166
Version 2.2r3
X-Plane crashed when asking X-Life ATC for a runway change for take-off...
XL: 768 : ---+++--- Pilot: MANCHESTER Delivery, DTB169, Stand 22, B738, with information Echo, QNH1025, request clearance (S:-1)
XL: 768 : inRW=23R
XL: 768 : inSidPoint=SONEX
XL: 768 : ---+++--- ATC: DTB169, MANCHESTER Delivery, Wrong ATIS Information (S:3)
XL: 775 : Autogen flight: A320 FEI
XL: 775 : X-Life check atis info:Departure: EGCC info Foxtrot. RW in use (TO):RW23R RW23L (LDG):RW23R RW23L Trans.Lvl: 5000 ft. // Arrival: EPWA info Foxtrot. RW in use (TO):RW29 RW33 (LDG):RW29 RW33 Trans.Lvl: 6500 ft.
XL: 780 : Autogen flight: BE20 N145LG
XL: 781 : ---+++--- Pilot: MANCHESTER Delivery, DTB169, Stand 22, B738, with information Foxtrot, QNH1025, request clearance (S:-1)
XL: 781 : inRW=23R
XL: 781 : inSidPoint=SONEX
XL: 781 : ---+++--- ATC: Initial Altitude 7000 feet, Squawk 2714 (S:4)
XL: 781 : ---+++--- ATC: DTB169, MANCHESTER Delivery, Cleared to CHOPIN, Runway 23R, via SONE1R departure, (S:4)
XL: 785 : Autogen flight: B733 NAX
167
CTD while asking X-Life to request FM Car to stand at EDDM...
"G:\Games\Steam\steamapps\common\X-Plane 11\Resources\plugins\X-Life\fmpath.txt
Find FMCar route file at G:\Games\Steam\steamapps\common\X-Plane 11\Resources\plugins\X-Life\fmpath.txt"
168
I have a problem with EIDW airport from Aerosoft. Below you find a link to a short video showing the issue. This plane completely blocks the runway so ATC doesn't allow any aircraft to take off or land. It occurs in both ver v2 and v4. This is very annoying especially when you had a long flight.
https://youtu.be/tOaEs2RMpmc
169 (edited by cmckjodi 2018-10-31 11:35:09)
The problem is that Aerlingus plane was trying to take off or land from a runway that was too short and what happens in that case the plane just stops and spins around. The only way to fix that is to use the airport editor and edit gates so only planes smaller than that one in class occupy the gates. That has been a known issue for a long time and I wish that problem could be fixed in another way or perhaps could JAR explain that issue as well. Will there be any new update? It's been a very long time since JAR posted any information.
170 (edited by laohu314 2018-10-31 03:17:19)
Thanks, that’s good to know. I had seen the same thing. Will corrrect xlf file and post somewhere
171
Thanks. I hope that this project has not been abandoned.
172
I'm pretty sure that's what that issue might be in regards to class size but not positive. If 16/34 runway is too short at EIDW for class D E or F then just try up to C and see if that makes a difference. The length of runway 16/34 at EIDW is 6,800ft/ 2073 meters. That is the shorter of both runways. 10/28 is 8,652ft/2,637 meters much longer.
173
I made the EIDW.xlf and watched traffic for a while without issue. Will upload at the .org because I cant upload here for some reason. Maybe it's MacOS
174
Big Thanks. Could you put a link to the file here.
175 (edited by laohu314 2018-11-01 16:01:49)
The xlf file for EIDW (https://store.x-plane.org/Airport-Dublin-V2_p_676.html) is here:
https://forums.x-plane.org/index.php?/f … 9-eidwxlf/
http://jardesign.org/forum/img/m/1944/t/p1cr800c6ksvt1fhtkki1jol6e53.png
