Topic: X-Life ver 2.2 R1, R2, R3 for X-Plane 10/11
Hello! This time X-Life plugin was reworked
Permanent link to actual version
http://www.jardesign.org/x-life/download/xlife_v2.zip
What New:
R1: (.xpl files attached here)
+ decrease of memory usage
+ increase a transit traffic dencity
+ add "Change CRZ FL request"
+ some bug and CTD was fixed
R2:
+ some CTDs fixed
+ framerate optimisation
R3:
+ add .xlf (new compatible airports) update notification
+ not-moved traffic for some airports fixed
+ takeoff without ATC clearance fixed
Installation:
If you use ver.2.X, you need update .xpl files only (attached below)
If you use ver.1.X, you need delete old and install new FULL plugin from ZIP, please not mix any
1. Be sure what you use OSX 10.9-10.12 or Windows 7-8-10 and X-Plane 64 bit 10.42+ or X-Plane 11 64 bit.
2. Be sure what you have at least one of static library installed -
OpenSceneryX. If not, you can install it for free opensceneryx.com
3. Copy “X-Life” folder to your ../X-PLANE 10/Resources/plugins/ folder
4. If you prefer use HD “Bluebell XL” traffic AI library, please download 3 files from
http://jardesign.org/downloads/BBXL/BBXL-1.zip
http://jardesign.org/downloads/BBXL/BBXL-2.zip
http://jardesign.org/downloads/BBXL/BBXL-3.zip
Next unZIP and put “Bluebell XL” folder to ../X-PLANE 10/Custom Data/ folder
and install folders “PackA”, “PackB”, “PackG”, “PackJ”, “PackP” to
../X-PLANE 10/Custom Data/Bluebell XL/ folder
X-Life use NavData (old) cycle by Aerosoft from own /navdata/ subfolder
or from ../X-PLANE/Custom Data/GNS430/navdata/ folder if exist
and put new cycle to ../X-PLANE/Custom Data/GNS430/navdata/ folder
Airport Editor manual by Philip Walchester posted here
http://jardesign.org/forum/viewtopic.php?id=3261
FMCar update
Please use this files to update FMCar and make it compatible with new .xlf files format
http://jardesign.org/forum/viewtopic.ph … 877#p17877
All remain the same
- please post you opinion about this version, post what you like/unlike
- post your log.txt + x-life.dmp if Crash happen and you are on Windows.
