Topic: XP11 JD330 v.3 r1,r2,r3,r4,r5
Version of a330 for X-Plane 11.
Main improvement - new FMGS, based on C++ (instead of SASL & basic X-Plane FMS)
r1 new features:
+ compatible with GHDeluxe v.040118
+ new MCDU MENU functions (you can operate with Ground Handling, Doors, Loading, Tow)
+ operate settings via MCDU MENU
+ separate Ground Handling operation (MCDU MENU -> Handling, next - select neeeded cars and click Drive Up)
+ MCDU movable widget (click on 3D MCDU or use Command jd/fmgs/CommandShowMcdu)
+ ND non-movable widget (click on ND)
+ Save coRoute flightplan using MCDU DATA -> Click right Arrow -> Pilots ROUTES, enter name and click SAVE
+ takeoff with heading preset
+ ND && MCDU indication and functions reworked
+ follow Speed Constraints
+ add instant flightplan generator
r2 improvements:
+ distance calculation fixed
+ fuel calculation fixed
+ 3th part plugins conflict ("no sound" issue fixed)
+ CTD after speed enter at CRZ PERF page fixed
+ some kinds of CTD fixed
+ taxilights issue fixed
r3 improvements:
+ improve SID/STAR drawing
r4 improvements:
+ Transatlantic CO-Routes reading fixed
+ some navdata Waypoints reading fixed
+ orange squares on rain window fixed
+ after Hold Leg crash fixed
+ lateral deviation from path line fixed
r5 improvements:
+ VATSIM/IVAO ND traffic indication fixed
+ some kind of CTD fixed
!!! no X-Plane plugins/330/ menu exist more, please set command jd/fmgs/CommandShowMcdu for some keyboard key and use MCDU MENU to operate ground handling.
HOW TO INSTALL / UPDATE:
Download link v3r5: http://jardesign.org/a330/download/inst … 30XP11.zip
Please install new version of Ground Handling to be well-compatible with XP11
Download link: http://jardesign.org/gndserv/download/GHD.zip
- be sure, that you use X-Plane 11.01-11.11
- copy unziped "JD330XP11" folder to ..\X-Plane 10\Aircraft\ folder
- please visit download more fresh version of Ground Handling plugin. It work with JARDesign 330 without registration (for free). Please note what “Deluxe” version of this plugin (may work with other aircrafts) is payware.
- enter your serial key (use exist serial from "JD330 for X-Plane 11"), click NEXT and after a successful activation reopen aircraft via X-Plane menu
a330 use NavData from
../X-PLANE 11/Custom Data/GNS430/navdata/ folder
../X-PLANE 11/Aircraft/330_JARDesign/_navdata/
and put new cycle to ..X-PLANE 10/Custom Data/navdata/ folder
- you may post you opinion about this version, post what you like/unlike
- please post your log.txt + x-life.dmp if Crash happen and you are on Windows.
Thank you!!!!
This is FREE update for users who own "JD330 for X-Plane 11" product.
