Topic: XP11 JD330 v.3 r1,r2,r3,r4,r5
Version of a330 for X-Plane 11.
Main improvement - new FMGS, based on C++ (instead of SASL & basic X-Plane FMS)
r1 new features:
+ compatible with GHDeluxe v.040118
+ new MCDU MENU functions (you can operate with Ground Handling, Doors, Loading, Tow)
+ operate settings via MCDU MENU
+ separate Ground Handling operation (MCDU MENU -> Handling, next - select neeeded cars and click Drive Up)
+ MCDU movable widget (click on 3D MCDU or use Command jd/fmgs/CommandShowMcdu)
+ ND non-movable widget (click on ND)
+ Save coRoute flightplan using MCDU DATA -> Click right Arrow -> Pilots ROUTES, enter name and click SAVE
+ takeoff with heading preset
+ ND && MCDU indication and functions reworked
+ follow Speed Constraints
+ add instant flightplan generator
r2 improvements:
+ distance calculation fixed
+ fuel calculation fixed
+ 3th part plugins conflict ("no sound" issue fixed)
+ CTD after speed enter at CRZ PERF page fixed
+ some kinds of CTD fixed
+ taxilights issue fixed
r3 improvements:
+ improve SID/STAR drawing
r4 improvements:
+ Transatlantic CO-Routes reading fixed
+ some navdata Waypoints reading fixed
+ orange squares on rain window fixed
+ after Hold Leg crash fixed
+ lateral deviation from path line fixed
r5 improvements:
+ VATSIM/IVAO ND traffic indication fixed
+ some kind of CTD fixed
!!! no X-Plane plugins/330/ menu exist more, please set command jd/fmgs/CommandShowMcdu for some keyboard key and use MCDU MENU to operate ground handling.
HOW TO INSTALL / UPDATE:
Download link v3r5: http://jardesign.org/a330/download/inst … 30XP11.zip
  - be sure, that you use X-Plane 11.01-11.11
  - copy unziped "JD330XP11" folder to ..\X-Plane 10\Aircraft\ folder
a330 use NavData from
- please post your log.txt + x-life.dmp if Crash happen and you are on Windows.
Thank you!!!!
Beta-tests thread link http://jardesign.org/forum/viewtopic.php?id=3753
liveries link www.simliveries.com
4 (edited by Scania_V8_Rat 2018-03-02 21:04:54)
Thank you for the announcement of an A340, you saved my day smile
As you constantly improve FMGS, will it be possible to change the STAR or better its desired RWY afterwards while executing the STAR? Because e.g. EDDF (Frankfurt/Main) charts advise pilots to first choose the STAR and then the RWY, because 07R and 07L are cleared independently and quite often you have a RWY change.
EDIT: to avoid double posting, I include it into this post: there are three folders instead of the normal two in the root/main folder called JD330_v3.
_MACOSX (okay, right one two enable Mac support), JD330_v3 (date of last change is 24. Feb 2018) and the newer JD330XP11 (02. Mar).
Please upload a newer version where the JD330_v3-folder which doubles the size to about 1 gigabyte is removed, because AFAIK it's unneccesarry and accidentally in here. See screenshot
http://jardesign.org/forum/img/m/5747/t/p1c7k8g4h19b1pen1vcv9ut6q03.png
So, after a few helpful tips from Mr. Romanov himself, for witch I thank him, I found out this aircraft doesn't go well with xEnviro, meaning, interior and external engine sounds won't be heard (except for pilot, flight attendent voices and clicking sounds) and "Sound3D" disapears from the plugins menu.
If I turn off xEnviro before loading XP, everything is heard properly and "Sound3D" is enabled
Anyone, running xEnviro, has the same issues?
6 (edited by m5001 2018-03-03 03:44:41)
I downloaded the JD330_v3 file now, I did not find the _NavData folder.
EDIT:
Oops, in beta 5 it also did not have the folder.
I so understand NavData now here JD330_v3\plugins\fmgs\navdata\???
Yes, already with previous beta versions .
EDIT:
A LOT of users usually delete _NavData folder with default navdata for some reason and contact support why aircraft not work. So we decide just move default navdata more deep inside.
https://forums.x-plane.org/index.php?/f … ton-twice/
When I select a STAR in the MCDU my XP crashes. does it happen to anyone else? here's the log:
FMGS: 217 : !tmpPluginPath=G:\SteamLibrary\steamapps\common\X-Plane 11\Aircraft\330_JARDesign_v3\plugins\fmgs\
FMGS: 217 : !outString=G:\SteamLibrary\steamapps\common\X-Plane 11\Aircraft\330_JARDesign_v3\
FMGS: 228 : Generated FPLN: LPFR SID BAROK UZ4 NAKOS UZ4 ESP B18 GANSU B18 NARTA UN975 GALPA UN975 RULET B18 RAKUN B18 SNT STAR LPMA
FMGS: 228 : !tmpPluginPath=G:\SteamLibrary\steamapps\common\X-Plane 11\Aircraft\330_JARDesign_v3\plugins\fmgs\
FMGS: 228 : !outString=G:\SteamLibrary\steamapps\common\X-Plane 11\Aircraft\330_JARDesign_v3\
FMGS: 276 : ICAO-format plan export to Dataref: LPFR SID BAROK UZ4 NAKOS UZ4 ESP B18 GANSU B18 NARTA UN975 GALPA UN975 RULET B18 RAKUN B18 SNT STAR LPMA
FMGS: 664 : Add points: 1
FMGS: 667 : add Leg: BARO6U,VA,0,283.0,2,430,0,0,0,0,0,0
FMGS: 667 : add Leg: BARO6U,VI,0, ,0.0,211.0,0,0,0,0,0,0,0,0
FMGS: 667 : add Leg: BARO6U,TF,BAROK,35.966667,-10.023333,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
FMGS: 667 : Add points: 6
FMGS: 669 : add Leg: BARO6U,VA,0,283.0,2,430,0,0,0,0,0,0
FMGS: 669 : add Leg: BARO6U,VI,0, ,0.0,211.0,0,0,0,0,0,0,0,0
FMGS: 669 : add Leg: BARO6U,TF,BAROK,35.966667,-10.023333,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
FMGS: 669 : Add points: 6
FMGS: 673 : ICAO-format plan export to Dataref: LPFR SID BAROK UZ4 NAKOS UZ4 ESP B18 GANSU B18 NARTA UN975 GALPA UN975 RULET B18 RAKUN B18 SNT STAR LPMA
FMGS: 720 : add Leg: D23-A,IF,FD211,32.851850,-16.644397,FUN,31.2,7.0,2,3000,0,0,0,0,2,0
FMGS: 720 : add Leg: D23-A,CF,FUN,32.747167,-16.705444,0,FUN,0.0,0.0,211.0,7.0,2,1430,0,0,0,0,0,0
FMGS: 720 : add Leg: D23-A,CF,MD211,32.693125,-16.736611,0,FUN,211.0,3.6,211.0,3.6,1,940,0,0,0,0,3,0
FMGS: 720 : add Leg: D23-A,CA,0,211.0,2,940,0,0,0,0,0,0
FMGS: 720 : add Leg: D23-A,CF,FUSUL,32.601389,-16.661944,0,FUN,170.8,9.0,138.0,4.0,1,3000,0,0,0,0,0,0
FMGS: 720 : add Leg: D23-A,HM,FUSUL,32.601389,-16.661944,1, ,0.0,0.0,351.0,04.3,0,0,0,0,0,0,0,0,0
FMGS: 720 : MessageRed: Missed Leg: D23-A,HM,FUSUL,32.601389,-16.661944,1, ,0.0,0.0,351.0,04.3,0,0,0,0,0,0,0,0,0
FMGS: 729 : add Leg: SNT4A,FD,SNT,33.090417,-16.350639,0,SNT,0.0,9.0,262.0,9.0,0,0,0,0,0,0,0,0
FMGS: 729 : add Leg: SNT4A,CF,ABUSU,32.867011,-16.635542,0,FUN,31.2,8.0,211.0,13.0,0,0,0,0,0,0,0,0
FMGS: 729 : add Leg: ABUSU,HF,ABUSU,32.867011,-16.635542,2, ,0.0,0.0,211.0,04,2,3000,0,0,0,0,1,0,0
FMGS: 729 : MessageRed: Missed Leg: ABUSU,HF,ABUSU,32.867011,-16.635542,2, ,0.0,0.0,211.0,04,2,3000,0,0,0,0,1,0,0
FMGS: 729 : add Leg: ABUSU,CF,FD211,32.851850,-16.644397,0,FUN,31.2,7.0,211.0,1.0,2,3000,0,0,0,0,0,0
FMGS: 729 : JARDesign FMGS  plugin ver.V3R1-010318 detect crash.
FMGS: 729 : Memory dump saved to fmgs.dmp file
FMGS: 729 : Please send this log.txt file and fmgs.dmp file (from X-Plane folder) to support@jardesign.org !
@S3rg1o
Could you add log.txt and fmgs.txt files , please ?
@S3rg1o
I can't find any fmgs.txt file only fmgs.dmp.. is it what you need?
EDIT:
Hi Mr.Romanov,
Thank you for this, very well done.
Just had a perfect 3 hr flight with v3 r1 (XP11.11r2), thanks for all the improvements Mr Romanov.
16 (edited by MrGeeBee 2018-03-03 20:16:40)
Flying now from EHAM - KJFK. Some notes: It feels a bit sluggish when taxiing, have to add a lot of thrust before it moves. And also still would wish for support for Scroll Wheel, it's terrible to work all the knobs, switches with LB + Drag.
Otherwise great work!
when i try to enter a flight plan in x-life after takeoff SIM is crash.
S3rg1o wrote:
@S3rg1o
Yes, sorry for extension error
19 (edited by ComRPM 2018-03-04 11:00:20)
Yesterday  2 hours flight without any problems.  With a 113 knots of lateral wind the plane maintained the flight path!
One suggestion. Its would be a lot of work to add the possibility of show the mcdu in an android device? Like AirFMC?
Thanks a lot.
R2 what we work on will fix:
- flightplan distance calculation issue
- fuel calculation issue
- "lost sound" issue cause of 3th part plugins conflicts
- crash fixes based on your dump files reported here/su[port/email/skype
Loaded A330v3r1 into XP 11.11 opened it up in XP, then loaded the BSS sounds and a BA livery, no problems. Not tried a flight yet.
I'm running XP 11.11 and XP 11.20vr6 on the same computer, running 11.20vr6 as a try out. I'm not using VR just a single screen
When I tried to load the A330v3r1 into 11.20vr6 XP crashed. Tried several time with the same result, I even tried copying the set up version from XP 11.11, which worked, and it still crashed.
I will set up a support ticket and attach a Log.txt, not sure how to do it on this forum.
WOW!! that's great news, thank you!
when do think you release it ?
Hi Eugeny
I made a few flights witout any trouble .
Thanks for this nice version of your A330 .
As now approaches are more and more RNAV approaches would it be possible to have on ND (upper right corner) distance to the next waypoint (or RNAV point) with 3 digits (xx.x) instead of 2 .
We can't fly RNAV approach currently because we can't know when exactly starting final glide ...
As an exemple RW24 RNAV approach  (see attached chart) on LFPO Airport final glide starts at 8.4 Nm from RW .
How can we see 8.4  we have only 9 (too early) or 8 (too late) .
Even on small X-Plane aircrafts this possibility exists ...
Could you please implement this in a future (near?) update ?
I like to see in the next update that the engine heat shimmer is atached to the engines.
There is a gap if you look from the sides
thx!
Just want to say thanks for this great update!
On my way from essa to vidp right now, and so far no problems!
Intel i9-9900KS 5.0ghz, 32GB DDR4 4200mhz RAM, nVidia RTX-2080Ti 11GB VRAM, Samsung M.2 Drives, Windows 10 Pro 64bit, X-Plane 11
