251
MrGeeBee wrote:
dudleybrooke wrote:
Crash when entering flightplan.
Additionally, I couldn't get the flightplan to load as a company route.
Your FLP:
KSFO SID SYRAH Q128 JSICA DCT ILC DCT KD45S DCT KK39A DCT FSM DCT MEM DCT HUTCC DCT KNSAW DCT RUSSA STAR KATL
Your FP in SkyVector:
KSFO SYRAH JSICA ILC KD45S KK39A FSM MEM HUTCC KNSAW RUSSA KATL
And in your Log:
FMGS: 553 : ICAO-format plan export to Dataref: KSFO SID NTELL DCT CABAB DCT KICHI DCT KATTS DCT KITTN DCT ROCCY DCT HASSL DCT TAHIB DCT DIXAN DCT MIRME DCT PNH DCT CRUSR DCT IRW DCT TUL DCT PLIED DCT LUKKY DCT ARG DCT ZESAM DCT KIMEL DCT SOPIE DCT BNA DCT LGC STAR KATL
FMGS: 596 : add Leg: I10,IF,CTEEE,33.620017,-84.651053,IOMO,275.0,11.8,2,4000,0,0,0,0,0,0
FMGS: 596 : add Leg: I10,CF,ZMANN,33.620169,-84.550981,0,IOMO,275.0,6.8,95.0,5.0,1,2700,0,0,0,0,2,0
FMGS: 596 : add Leg: I10,CF,RW10,33.620272,-84.447878,0,IOMO,275.0,1.7,95.0,5.2,1,1055,0,0,0,0,3,0
FMGS: 596 : add Leg: I10,CA,0,95.0,2,1400,0,0,0,0,0,0
FMGS: 596 : add Leg: I10,CF,SCARR,33.378639,-84.435069,2,ATL,185.0,15.0,185.0,15.0,2,3000,0,0,0,0,0,0
FMGS: 596 : add Leg: I10,HM,SCARR,33.378639,-84.435069,2, ,0.0,0.0,5.0,04.3,0,0,0,0,0,0,0,0,0
FMGS: 596 : MessageRed: Missed Leg: I10,HM,SCARR,33.378639,-84.435069,2, ,0.0,0.0,5.0,04.3,0,0,0,0,0,0,0,0,0
The first plan was produced by SimBrief and the second was produced by Goodway and injected directly.
252
dudleybrooke wrote:
Your FLP:
And in your Log:
Yes, but it's not even the same route so I can't see the connection.
The second route is even very strange:
http://jardesign.org/forum/img/m/4411/t/p1c6q0j5smt7b3d01iln1fimuea3.png
253
Peter092 wrote:
The A330 is a very nice plane that gives me satisfaction.
But two problems:
1 / impossible to remove the discontinuity located after the airport of departure. Obligation of an SID.
NB: In the V2, it was possible and interesting to make "takeoff-landing loops"
2 / IMPORTANT : the A330 cannot follow the LNAV and VNAV parameters of the MCDU. As a result, the A330 loses AUTO-PILOT, speed, altitude, etc.
Here is a 7 minute video to show you the problems. Here : https://drive.google.com/file/d/107aXLK … sp=sharing
Flight LFSB (Basel-Mulhouse) - LFPO
RWY 33
SID: LUME6N
AIRAC: 1801 - January 2018.
Thank you for your attention. Best regards.
Peter (in French)
Hi Peter092
I have just done same flight LFSB/LFPO with same SID ...Without any trouble ...
I noticed in your video that you did not finish your flight plan (it still exists a discontinuity) (may be for getting a not too long video) ... but in that case you cannot adjust the fuel prediction . To know what fuel quantity is needed you have to finilize the flight plan , then fill the PERF page (1 and 2) . This fix center of gravity ...and so on ...
I suggest you make a try with these conditions .
MrGeeBee wrote:
Beta 5:
1. (Minor glitch) You have to exit and restart X-Plane to get rid of the Rainshield after first activation. Reloading the aircraft is not good enough. (No big deal though.)
2. When in TOGA and then pulling back throttle to climb, the AP goes wild and sets the ATHR to TOGALK, even above the AF. Only way way is to disengage the ATHR, match the TOGA speed manually and reacttivate ATHR again.
3. At TOD sometimes, tuning in your ILS altitude, and the aircraft starts to decent at 8000 FPM. (Only happens sometimes, so I'm not sure how to reproduce yet, working on it.)
4. Also glitch with refueling, when calling only the Gasoline Truck from GHD no refuel window appear. If calling all things it appears.
(Video still processing on YT... https://youtu.be/9TMKOefAKCQ?list=PLEMT … Gkqy-rEc-j )
I'll saw the same things on your posts from points 1 to 3, but with gasoline truck I have no problem.
I'll try the make plan generated with new tools-instant flightplan, but plan have the same problems like X-life plan maker with open air space over Europe ( Austria, Slovenia,...)
Otherwise I like to fly with this plane and JAR keep up the great work!
255
The point was not the routing, but the fact that the supplied route produces an error in the MCDU when I try to load it.  The vagaries of the route aren't really relevant, I could have gone via Tahiti for all it mattered.
256
Sure if all points were connected, but they are not and therefore an MCDU error, and in this case a CTD. CTD shouldn't happen, but the plan is still faulty.
257
Hi Mr.Romanov,
I deleted all files (as explained on page 1 of this topic) of the version 3 Beta 1 airplane.
I installed the airplane (Beta5), opened Steam and started the "game" with the default airplane 747, I changed to JAR A330, opened the activation window where I put my serial number, then exit the "game", I returned with the JAR330 and those warning of GroundHandling that I had mentioned in another post did not appear anymore.
Thanks for the update
258 (edited by frizzleboy 2018-02-20 20:57:31)
http://jardesign.org/forum/img/m/6313/t/p1c6qg3a9r1f006b31l91hiu8f23.jpg
Good evening. On final i have a warning about overspeed, but my Vapp was 180kts , not more. I received this warning every time I was on final to rwy.
259
Well, VApp is a float, so it could be 180.9 and maybe rounded up to 181 and hence a warning.
260
Peter092 wrote:
But two problems:
RWY 33
SID: LUME6N
Peter (in French)
Hi Peter092
jcdp  I really appreciate your patience and relax !  When I read all error messages and complaints in the last time I lose patience very quickly. Even in this case, after the obvious large number of errors that were made, it is obvious  that the take-off must gone badly. I also made a short video about the same flight and - oh my... - everything went as usual. But even if you offer videos for training  (that means a lot of effort) in the end hardly anyone is interested. It is easier to ask than working yourself up the matter ....     https://youtu.be/APoMBzdwoSM
261
I'm still received CTD on entering CRZ/TEMP.
Steps:
1. GPU = ON
2. Batteries = ON
3. GPU B Avail = ON
4. FMGS - Init
5. FMGS - Plan = LKPR/UMMS, R1, NON (without plan generation)
6. FMGS - Flight Number = CSA615
7. FMGS - Align IRS
8. FMGS - CRZ/TEMP = 410/-48 ===> CTD
A330 V3B5, XP11.11
262
At tod the aircraft increases the acceleration of the engines when we started the managed descent.
This did not happen in beta 4.
263 (edited by jcdp 2018-02-21 07:56:33)
Steps:
1. GPU = ON
2. Batteries = ON
3. GPU B Avail = ON
4. FMGS - Init
7. FMGS - Align IRS
A330 V3B5, XP11.11
Before FL410 was not accepted ...I do not know if it is now .
I had CTD if I tried to enter FL AND temp ...
When entering only FL (such as 390 for instance ) it works ... writing level and temp .
Steps:
1. GPU = ON
2. Batteries = ON
3. GPU B Avail = ON
4. FMGS - Init
7. FMGS - Align IRS
A330 V3B5, XP11.11
I get "Data Missing", but that's because there is no FP. I tried the same as yours, and when completed a FP it worked fine. Entering FL should be addressed, either it's accepting a FL from start or it should be on last stage after entering a FP.
265
Good flight from EGCC to LFPG with 330v3b5 in XP 11.20b3. Aircraft did everything it should have done, managed the approach and kept pretty much on profile until I took over, then got told my next landing will be better. Plane 10, me 0.
I did notice the aircraft was swinging about a little following the magenta line of the plan, but not a real problem.
Would it be possible that when you turn off the frames warning in the MCDU it stays off, instead of having to keep turning it off every time you fire up the A330.
266
again and sorry to show you perhaps a new problem: sometimes the spoliers do not work.
In this video, I do a flight training "take-off loops" LFPO RWY20 - LFPO ILS06.
You may find that the spoiler lever operates in manual and landing but the spoilers do not come out.
Other theft, they work.
Here is the video : https://drive.google.com/file/d/141BjhN … sp=sharing
NB:
Starting runningFlight engines LFPO-LFPO
Starting runningX-plane engines 11.10
Windows 10
Plugins, Skymax Pro only.
Peter (in French)
267 (edited by ilankrt 2018-02-21 14:43:15)
NB:
Was this a realtime video or it was recorded afterwards?  I am used to record my landings afterwards knowing that speedbrakes in  open position are not seen on this records... To see if speedbrakes deployed I stop the simulation looking after their position...
268
Peter092 wrote:
But two problems:
RWY 33
SID: LUME6N
Peter (in French)
Hi Peter092
Please do not lose patience.
Jcdp had a very good idea: "I suggest you make a try with these conditions."
So, I made the flight again: same parameters but by checking well the paln of flight and the absence of disontinuity.
Without discontinuity: SAME RESULT !!! The proof in video :https://drive.google.com/file/d/1QwTHLX … sp=sharing
And, I do not lose patience, the proof I take my time to show you what does not seem to work and without remarks and without negative criticism.
Peter (in French)
269
NB:
Video in real time, that's why the plane does not go straight on the track.
When we do a replay, the screens do not give the flight information.
270
Peter (in French)
Hi peter092
Well I have no more suggestion.
You look very unlucky ...
When you get such an issue it could be usefull for JAR to attach the log.txt and fmgs.txt files with your message .
Yes. Should NOT. I trying to get this kind of crash on my side but sadly - without luck.
272
Steps:
1. GPU = ON
2. Batteries = ON
3. GPU B Avail = ON
4. FMGS - Init
7. FMGS - Align IRS
A330 V3B5, XP11.11
is this is stable crash and you get it if do the same again?
273
Steps:
1. GPU = ON
2. Batteries = ON
3. GPU B Avail = ON
4. FMGS - Init
7. FMGS - Align IRS
A330 V3B5, XP11.11
Ok, I get it and fix. Thanks for info!
274
NB:
Windows 10
Peter (in French)
It may not work in replay mode, but check this during flight, please.
275 (edited by Peter092 2018-02-22 06:58:28)
Stay calm and relax ilankrt. You lose patience very quickly because your demo video is wrong.
1 / in the flight plan given by the MCDU from A330 to Waypoint BM the recommended speed is = 250 Kts (see below).
At BM, I'm accelerating to 190 kts because I follow the flight plan of the MCDU of the A330 of Jar Design (look pictures).
http://i.imgur.com/5ay2A32.jpg
http://i.imgur.com/fu2fYp6.jpg
http://i.imgur.com/J2jndr3.jpg
2 / in your video the driver at waypoint BM is at 150kts stabilized (150 kts is below V2 + 10).  it is sure that it will not happen  !!! (see capture) And, the video does not respect the flight plan or maybe the flight plan has been changed ... But it is not in the video! Easy (look capture)
http://i.imgur.com/GOEhNzo.jpg
Stay calm ilankrt and check your sources.
