276
denismeuret wrote:
If you need help, please add the log.txt ...
Text LOG added. Thank you
I found two things :
1) when you installed something in the "custom scenery" you have not deleted the scenery_pack.ini file from your "custom scenery" ...it will be automatically rebilt in the correct order when restarting X-Plane .this way the zOrtho ...will be placed at the end of the list (as expected...lower priority) and not at the beginning .
2) X-plane has not found navdata in the custom data/GNS430 folder  .Apparently data are missing
Please verify and update if necessary .
Thank you so much. Appreciate the guidance. will correct as you instructed.
277
What's the difference between the JD320 Airliner ver 3.2 r1 and the JD320 Airliner ver 3.2 r2. I'm confused.
278
r2 has an updated 3D Sound plugin
279
Please update the cockpit Resolution. If the Ultimate comes out, the a320 needs a much netter Resolution.
Cheers
280
does anybody know something about next release (Date, changes)?
Or is no update planned?
I usually fly the B737 from Zibo.
I purchased this morning your 320.
Why is this aircraft so very slow!
Suddenly my xp11 fps is half as what I normally have.
This is not good :-(
282
Did you check what is required harware for flying JAR A320 ?
If ACF is slow that comes from low fps, for getting normal speed minimum of 30fps is required ...
A solution, reduce the graphic settings may be.
Yes, almost all other study level aircraft is FPS hungry. Airbus is especially slow in all flight simulator. I would also recommend to adjust your Flight models per frame setting, I usually have it set to 4 for this kind of aircraft.
284
Hey guys,
can somebody tell me, how I have to set the  6 slider in joystick settings, to get the most realistic flight model? I am talking about the sensity and stability slider in XP joystick settings.
A320C@r wrote:
Hey guys,
For high realism you should have all three Stability slider set to 0. The Sensitivity is more how fine tuned your yoke/stick is, so full Sensitivity gives a very high detailed sensitivity, but this does not affect the realism, more depending on how sensitiv your controller is.
286
@MrJeeBee. Ok I am asking explicit for a320 from Jar.
I have the Flight Hotas X joystick.
Every 3 slider for stability to 0. And for sensity as I like. Did I understand correct?
I want to set an own settings Profile for this Bird.
287
Well, I would say for almost any aircraft Stability = 0 is highest realism.
288
Ok Thank you @MrGeeBee
289 (edited by ilankrt 2018-02-15 22:27:36)
It is really a pity that the further development of the A320 has come to a standstill.
The big announced "Ultra" competition turns out to be a little mouse, at least when you follow the internal discussions / complaints and endless beta corrections. It looks like the FF colleagues have taken over completely since the first limited sale version has not changed significantly.
I warned at the beginning of the exaggerated expectations and was excluded from the high society. Now my reminders were even surpassed ...
I really wish a new A320 version like the extraordinary success of the A330.
290
We continue to work, but at this stage the best solution for us is to keep the hangar closed so as to create our baby in a calm environment. Thanks to all 320 pilots who sincerely love our aircraft
https://d.radikal.ru/d27/1802/30/1988c1834b00.jpg
291
please i want serial number for active jar 320
when i get serial number?
292
In X-Plane.store after you paid for the purchase of JAR A320 $59.95 you'll get surely a serial number
293
Hello.
Any Chance to get an Information, if the 320 will get a native VR Support in the near future? Flying in VR with Oculus touch is absolutly awesome.
So.. Any chance?
294
Great news!!
295
Greetings to whomever can help me with an activation issue with the JarDesign a320.
I purchased the JarDesign A320 for Xplane 10 (latest version 10.51) and downloaded the installer for the X-plane 11.1 compatability update and received an "error activating aircraft" message along the red text at the bottom left hand side reading "error a320 sasl plugin not activated-check aircraft installation-check when aircraft purchase was-contact jard.org if activation menu does not appear". Well, the activation menu appears but when I copy and past my REGcode and click next, it simply reads "error activating". I tried installing the file a couple times and restarting the sim to trouble shoot and I cannot seem to find a solution. If anyone has any information in regards to my problem I would greatly appreciate the help, thank you!
296
Hi Sir A320 10.51 not compatible X-plane11
297
After entering a flightplan into the MCDU and attempted to save the route using the MCDU option, X-Plane crashed to the desktop.
The log shows "--=={This application has crashed because of the plugin: JARDesign FMGS plugin}==--"
I restarted x-plane and tried to load the assumed saved flight plan and it crashed again.
I confirm the file was saved _LEBL2EGLL_LEBLEGLL.txt
I am using the Mac version.
298 (edited by laohu314 2018-03-11 21:22:21)
Please upload the complete log.txt and the OSX crash report (find it in the Console App)
299
I bought this plane a few minutes ago, I have not installed it yet.
I intend to change my computer from here for some time, I do not want to risk losing any of the planes(330 and 320).
Sorry for the question, I know many have asked, but will the JAR320 update be soon? maybe a few months?
300
I downloaded A320 3.2 r1 and uninstalled A320 3.2 r2; I have a problem as I launch A320 3.2 r1 tells me that I have installed A320 r2, tells me that an update is available ... any ideas?
