denismeuret wrote:jcdp wrote:If you need help, please add the log.txt ...
Text LOG added. Thank you
I found two things :
1) when you installed something in the "custom scenery" you have not deleted the scenery_pack.ini file from your "custom scenery" ...it will be automatically rebilt in the correct order when restarting X-Plane .this way the zOrtho ...will be placed at the end of the list (as expected...lower priority) and not at the beginning .
2) X-plane has not found navdata in the custom data/GNS430 folder .Apparently data are missing
Please verify and update if necessary .Regards
Thank you so much. Appreciate the guidance. will correct as you instructed.
