Topic: JD320 Airliner ver 3.2 r1,r2 WIN/MAC 64 bit (X-Plane 11)
http://jardesign.org/forum/img/m/22/t/p1bckck0mj1qcgg3n1ge4vd26er3.png
Download link: http://jardesign.org/a320/download/inst … 20XP11.zip
  - be sure, that you use X-Plane 11.00-11.01
  - please visit www.simliveries.com to get 130+ free liveries
UPDATE YOU NAV DATA WITH FRESH CYCLE (if need)
- “JARDesign a320/330 Native format”
and put new cycle to ../X-PLANE 11/Custom Data/GNS430/navdata/ folder (create this folder if need)
You may switch default/custom installed navdata via MCDU.
Default cycle (Aerosoft, old) always included to _navdata folder.
What new in this version:
+ improve stability
(more than changes in code, mostly for flightplan part)
r2
+ win.xpl sound plugin engine update at Sound3d folder
Thank you!!!!
Description in "what new" is very short, but about more than 20 functions was reworked to improve stability and avoid SASL errors, based on users reports.
Very nice, development continues :-)
Yes, we will test and report :-)
thanks, i will follow info at this topic
Thanks Sir
Hallo JAR at last the expected step forward. Thanks !!  I am going today to make a test flight.
Warning for JAR aircraft user: Do not instal the offered "Terrain Radar". It might be nice for other aircraft models, but it cause heavy errors to JAR models. Deleting this plugin from plugin folder is not the end of the story because more files (.init) are left in X-Plane folder. I was working hard to find out that this was the cause of A320 ILS to stop working from one day to another....
Note: this is a good example for user claiming about disfunction and bugs, where in fact the problems are external ones.
Just first test flight EINN-LFRB with 3.2r1 and Xlife 2.0rc1
Perfect flight, all OK
Thank you Eugeny
Still an issue with the pressure setting knob. If I turn it to the right it decreases the pressure setting and to the left it increases, it should be the other way around. Another issue here is that the pressure setting selected using the knob sometimes doesn't match up to the setting on the PFD (example: QNH1008 selected with the knob but the PFD gives me a reading of QNH1007). One other thing is that the cockpit seems to be too dark.
Agree with above but would also like to say thank you for the update.
Still curious to know why the Jar ground services cause the sim to freeze for like 10 seconds when starting the sim??
Thx again guys :-)
Hello, bravo for work,
I have a problem with the new verssion V3.2.1
spolers armed, does not come out after landing
have a good day
First flight, 3 little bugs:
1) http://jardesign.org/forum/img/m/552/t/p1bl60ei9j17jn1boo1tp2bcsmp33.jpg
2) http://jardesign.org/forum/img/m/552/t/p1bl60eof81t4q1n7s7ss1isr1sb45.jpg
3) http://jardesign.org/forum/img/m/552/t/p1bl60f0vb8tp10gsmhh1ud01e7k9.jpg
http://jardesign.org/forum/img/m/552/t/p1bl60f7p71g8h16p71oab1819rh7b.jpg
best regards
Could you elaborate, which files needs to be deleted ?
Thanks for the update chaps!
14 (edited by ilankrt 2017-07-16 22:20:07)
TEST FLIGHT A320 3.2r1:
1. QNH knob regulation in fals direction
2. 10.000 ft,  lights check announcement don't work
3. Reflection of sunshine on glass cockpit continue disturbing field of vision(see image below)
although the sun is in front of the aircraft!!
More critical:
4. Aircraft swinging during climb (after aircraft movement to OFF, situation getting better)
5. Reaching TOC,  A/THR reduces power to idle then back to MACH speed
6. After TOD, descending at 34kt tailwind I had to play all the time with the speedbrakes to hold speed
7. On approach with 5kt (!) head wind, aircraft begins to swing like in a hurricane !!
8. Speed brakes didn't deploy after landing !
Version 3.1r2 seems to be much more stable
X-Life (last version) seems to work well but I get too often a Go-Around ATC order..
and is the start of climb symbol still being used for top of climb on the flight plan?
TOC symbol is showing correctly on ND
Flight plane - don't remember....
17 (edited by Greyman 2017-07-17 18:44:58)
As far as i can see, the update is exactly the same as the previous versions in that it displays the wrong symbol for Top of Climb on the ND.  The image below shows the symbol that should be used, not the one that is currently being used in the JAR simulation, which looks like it should depict the start of a climb
https://www.google.co.uk/search?biw=123 … XkA_V6LRM:
Granted, it is only a minor point, but it shouldn't really take much doing to get it right.
Edit:  Just for confirmation, the table on FCOM 4.02.20 P 17 is worth a read
Just did a quick test flight from Gatwick to Edinburgh.
Everything fine apart from losing the pointy hand thing over the control switches half way through the flight.  Had to click around the switches to hit the right spot.
Speed brakes deployed ok on landing.
19 (edited by dimkzr 2017-07-21 14:41:40)
May I suggest changing trim settings in "Load" window to match the format it expects from you in MCDU?
http://i.imgur.com/fDZL5Qk.png
Are there any plans to smooth out the jagged shadows on this plane?
21 (edited by dimkzr 2017-07-22 23:59:29)
1. The plane still unstable on approach/landing - swaying in all directions, controls feels extremely sensitive when taxiing. Not sure if this is JAR problem, or general X-Plane issue, because I have same behavior with FlyJSim 727. Zibo 737 and FF757 are more stable.
2. The plane still accelerates into space and crashing sim after exiting from the replay mode.
Hi Eugeny
Thanks for this update .
Made three flights : LFPG-EHAM
                             LFPO-LFKJ
                             LFPG-EGGL
without any trouble ... Works fine.
Well , sometimes QNH are different such as 1018  and 1017 ...on screens.
Last week I had an interesting correspondence with FSLabs. Among other issues and on the background of the announced FF A320 model I asked them what about about a win win cooperation between them and JAR Design. They wrote: "We are a small team and going into X-Plane is not feasible for us at the moment. If Eugeny is looking to join us, feel free to drop him a note to ask him to send us an email about it."
JAR, to your knowledge....
24 (edited by ilankrt 2017-07-19 14:13:00)
Test flight A320 v. 3.2r1
trying to land at LOWI (LOC active) with head wind 24kt and aircraft was not under control any more,
swaying wild and flying up and down.....
Same flight but under better wind conditions (2kt headwind) without forenamed occurrences ...
VIAs are inserted even if select "NO VIA": And VIA name is wrong, there is no via named "PAD",
only "PAD1" or "PAD2".
If VIA PAD is removed manually, flight plan is ok.
http://jardesign.org/forum/img/m/552/t/p1bldkppj015uoafd1jiu13nkaji3.jpg
http://jardesign.org/forum/img/m/552/t/p1bldkppj01i1l13ef100s196ls184.jpg
http://jardesign.org/forum/img/m/552/t/p1bldkppj0j3q15c3auq1p091nq5.jpg
http://jardesign.org/forum/img/m/552/t/p1bldkppj1rh6sm61cjo1cmmlml6.jpg
http://jardesign.org/forum/img/m/552/t/p1bldkppj11bbv9hg11iosn910817.jpg
http://jardesign.org/forum/img/m/552/t/p1bldkppj1173tmuk182hqvi1mau8.jpg
http://jardesign.org/forum/img/m/552/t/p1bldkppj11qp1v171ujq7hq1e8k9.jpg
