51 (edited by jcdp 2018-02-07 10:19:26)
Re: X-Life ver 2.1 R1
dirmer3 wrote:
I'm having trouble with xlife giving me wrong/no SIDS/STARS. It says something like, "via departure" when departing. It does give me a STAR on TOD, but it's always the same STAR regardless of where I'm coming from. I have up to date 1802 navdata. Any ideas?
STAR only dépends on the landing runway not where you are coming from ...
So everything is normal.
X-plane 11.20Vr2
I can start X-life deluxe 2.1 R 1, but it´s eating my RAM ( 8 Giga inside ) and my CPU power since the beta version.
Gigabyte P43- ES 3 G motherboard; Intel E 8400 dual core CPU 3,5 GHz; Nvidia GTX 750 ti
53
Hi, I just bought x life deluxe, and like it very much, my only issue is when I arrive, I can´t see any airplane taxiing to the runway, no plane landing and no plane departuring.
No movement in the arrive airport, in the departure everything si excelent.
You may want to upgrade your RAM to 16g or 32b which even better. X-Plane and some plugins use a lot of computer resources I have 4.0g CPU and 32RAM and I do fine running X-Life. But I agree that it's a bit unfair to have to have a "super powered" machine run X-Plane and your plugins. I'm not sure how much resources X-Life uses, but some say a lot.
What is your arrival airport?
No EDDS. For some reason X-life doesn't recognize EDDS.
CYYZ
58
CYYZ
That airport should be recognized as it is "verified" Do you get traffic there as a departure airport? Do you get traffic at other arrival airports? Did you file a flight plan with the X-Life ATC? You will only get traffic at the arrival airport if you file a flight plan.
59
EDDS is not a "verified" airport meaning it is not included in the X-Life Airports Folder. You may add an .apt file from a custom scenery that you use for EDDS to the Airports Folder but it must contain taxi routes that x-life will be able to read. There is plenty of info on how to do this this in this forum.
cmckjodi wrote:
batito wrote:
CYYZ
Thank you for the information, the answer is NO, because I fly not only in Jar´s planes.
Is this is going to change for those who fly with another airplanes like FF or IXEG? I mean, that x life generate AI trafic in every airport (supported) even when don´t make a flight plan?  Thanks again.
61
batito wrote:
cmckjodi wrote:
batito wrote:
CYYZ
I don't use any JAR aircraft. But unless you file a flight plan a flight plan with ATC you won't see traffic at the arrival airport from my experience.
Excelent, thank you
for now is ok, but I hope in the future change to work with out a f plan.
Excelent, thank you
You are welcome sir yes that would be a nice feature if you just want to fly without one and have traffic at your arrival airport. Kind regards
64
I have installed EDDS from Aerosoft and there is info that the airport is fully compatible with the X-Life plugin by JARDesign
You still need to have the EDDS.dat apt file in the X-Life Airports folder. Do you have it in there?
Unfortunately not. I thought if I buy a scenery compatible with the X-Life plugin, everything should works fine.
67
As you know , now, that an inverified Airport doest not work with X-Life when X-Plane is launched , may be you could ask Aerosoft why a said compatible Airport from them is not recognised ....
X-plane 11.20Vr2
68 (edited by cmckjodi 2018-02-18 12:56:33)
Just go into your EDDS custom scenery folder open the earth nav data folder copy the .apt text file to another location such as your desktop then rename it from apt to EDDS then open the text file in a text editor like notepad and rename the line at the top to read            EDDS EDDS.dat and save the file. Now place this file into the X-Life Airports folder where all the others reside. When you start X-Life it will say the airport is not verified but you should see traffic, but only if the taxiroutes are properly set up for X-Life. There are instructions on this forum that explains how to do this. If you need more help let me know. cmckjodi
http://jardesign.org/forum/viewforum.php?id=33 or search here for edds and copy paste it in xlife- airports. That works, have the same airport.
Hi, how can I get x-life work with ff320. Cause QNH problems?!
Make a search in A320 discussions. I remember that someone gave us a solution...
X-Plane 11.10r3 | iMac27 OSX High Sierra 10.13.1,  4 GHz Intel Core i7 32 GB memory AMD radeon R9 M395X 4096 MB | Saitek equipment | Plugins: GndHandling , RWC , SMP , SoundM, X-Life , TerrainRadar, BetterPushback, AutoGate  |   iPad 12.9, iPad Air 9.7  | Airliner: JAR A320neo/A330, FF A350XWB, FF B767, SSG B747-8 inter, http://ilankrt1.blogspot.co.il
72
crashed again bcs of out of memory 20-30 sec after ATC route clearence from BIKF to EGKK. On a System with 16GB RAM. It's payware and it dosn't what im paid for!
73
Hi by setting transponder On
Geforce GTX 1060 6Go - Saitek Proflight yoke and rudders - XP11.11r2
A320neoJDv3.2r1 & BSS PW1000 v4.0 sound pack - A330JDv3.0a & BBS PW1000v2.02 sound pack
GHdeluxe FMcar2.6r1  X-Lifedeluxe2.1r1  X-ATCchatter v1.5.3   EFASS NG   XPRealisticPro   xEnviro1.07
