101 (edited by Scania_V8_Rat 2018-02-09 19:01:44)
Not a real beta bug, it was there in v2, too, so it definetely needs to be put right!
The sun visor for the left window has only one clickable point to pull it forward or to stow it back, but the one on the right hand side has two...
I would prefer two, because that's logic!
See the attached pictures.
http://jardesign.org/forum/img/m/5747/t/p1c5tuv4oegphn4e10t02d9do73.png
http://jardesign.org/forum/img/m/5747/t/p1c5tuv4ofmr82rp1rt81e1dc534.png
102 (edited by Scania_V8_Rat 2018-02-09 19:31:16)
Ahh, found sth...
Weight request would be a cool feature on 2nd INIT page. The first INIT page only features a REQUEST command for the Origin...
SEC F-PLN will hopefully implemented too smile Thank you Eugeny, by the way, because you are the only dev who I know who informs his customers in such a great way...
Flight Factor should take you as a role model!
Hello JAR really good update definitely better than what it was before. I have experience a couple of CTDs none of which that haven't reported.  However I noticed that the engine spool down time after shutdown it's too quickly and abrupt I don't know if it's a v3 bug related thought I should just mention it. Thanks will keep testing.
FMC constraints are great. On T/O I found full T/O pwr is never reached, regardless of TOGA setting, or flex temp entered.
Some things aren't a 100% accurate in FMC...
Made a flight from Frankfurt EDDF to Berlin Tegel EDDT without problems.. Only few things were not like they're supposed to be.
E.g. the Missed Appr. path. Interesting, isn't it? big_smile
http://jardesign.org/forum/img/m/5747/t/p1c5u8kqq5juc15fg5p58qq13ga3.png
Fuel calculation (Fuel Truck from GDH plugin constantly said I had not enough fuel. Calculated on simbrief and 9t left as I reached Tegel...
Constraints are good in my opinion!
Another wrong thing: SULUS9F is a RWY 25C or 25L SID. However, I could choose it as a 07C SID? (Seems like the error is on my side) Even if not, this is (just guessing) a Navigraph related issue.
AP has problems reconnecting. I accidentally switched FD off and - as you would expect - all APs disconnected. But as I reconnected them (switched FD back on of course), AP wouldn't find its track. Just kept on moving in one heading, nothing but SPEED in PFD.
Was able to get it working by entering manual heading (pulling) and then pushing to get it to AUTO....
I have a problem with the checklist. Before setting Block Fuel in FMC, the "FUEL QUNTITY" option on checklist is already ticked, but when I enter the correct block fuel into the FMC, this item changes to unticked, which prevents the completion of the checklist. Please find the attached screenshot. I've never had this problem with the previous version.
107
Seems like approach to EDNY is broken.
Charts:
http://jardesign.org/forum/img/m/552/t/p1c5vmhtet19fkkmp1ff11o6i5mt5.jpg
Plane:
http://jardesign.org/forum/img/m/552/t/p1c5vmhtet15de1oci1s631c251t2h4.jpg
http://jardesign.org/forum/img/m/552/t/p1c5vmhtet1v9s1j9t1j0rp4b6gr3.jpg
Hmm.. still no sound at all for me. Theres no Sound3d showing up in the plugins menu as well. Anybody got an idea?
In the previous version (V2.2R3) I could just enter VOR and ILS frequencies and the associated CRS info by using the radio panel below the FMC. In version V3.0B2 the data entered on the radio panel does not seem to have any effect, and I have to enter the data on the RAD/NAV page of the FMC. Is that intentionally implemented that way?
Dennis
110
Any chance the new FMGS will be compatible with iPad use? I try to stay away from using the mouse as much as possible. AirFMC now says that the A330 is not compatible (since changing to the beta version).
111
Bugs:
On ND, the distance on top right needs to be a decimal (like 2.3 NM)
On arrival, no transition nor Initial Approach Fix selection possible (it was working on A330 v2)
I am not able to set an ALTN airport in FMGS. Maybe I didn't catch something...
TA ONLY not displayed anymore on the ND during take-off phase (as it was in v2)
Suggestion:
Possibility to save automatically settings changed in FMGS (like FPS MESSAGE to OFF)
Thank you for your hard work!
Hmmm... Just wanted to make some Touch n go trainings @EDDS (Stuttgart). Due to an ALT Constraint, my FL was constantly FL100, but I wanted to get up to FL140 (because ALT Constr. was for the APPR transition which I had to enter manually).
So, I went to INIT page and changed FL100 to FL120. This crashed the plugin. LOG and fmgs.dump included.
Happy landings
113
beta 3 just posted
+ bug fixed
114 (edited by ilankrt 2018-02-10 18:56:03)
big_smile
I read v. 3-2 ?!
Can you correct it to v.3-3 please////
115
Hello everyone,
very lovely updates. I can now finally practise some landings because I don't get SASL error on go-around/touch-and-go. I seem to be however missing all RNAV approaches in the FMGC. Someone else noticed something like this?
Would it be possible to be able switch off the red frame rate counter permanently in the next update.
117 (edited by ilankrt 2018-02-10 20:22:25)
EBBR - EGCC. CTD  (ATC)
118 (edited by m5001 2018-02-10 21:19:14)
Installed Ground Handling in:
C:\Program Files (x86)\Steam\steamapps\common\X-Plane 11\Aircraft\JD330_v3\plugins\GndHandling  (This place was the same as I had in the other beta and had no warnings)
And a lot of lines appear with this warnings:
CUSTOM DATAREF (int): jd/diagnost/ghd
[SASL INFO] loading    falses
[SASL ERROR] can't load component    falses
119
У меня проблема с клик зонами. Причем какая-то плавающая. то вообще не могу ни одну кнопку нажать то приходится пиксельхантингом заниматься. Что это может быть? Какие баг репорты закинуть? Может видео записать?
120
skype j.a.romanov
121
wrong installation. should be at
C:\Program Files (x86)\Steam\steamapps\common\X-Plane 11\Resources\plugins\GndHandling
122
need do this every flight
Test A330 Beta 3.0 on  NO ISSUES!!!! TOP PERFECT FLIGHT
Modelnaam:    iMac
  Modelaanduiding:    iMac18,3
  Processornaam:    Intel Core i7
  Processorsnelheid:    4,2 GHz
  Aantal processors:    1
  Totale aantal cores:    4
  L2-cache (per core):    256 KB
  L3-cache:    8 MB
  Geheugen:    40 GB
With most regular plugins, AN,FM,GHD,BP,TR,SMP4.6,XL,LS,LUA,XR2.0,
Point of attention ar the announcement of the flight ATT ( no resons)
124 (edited by McWillem 2018-02-11 09:00:35)
Please make save preferences mcdu menu after changes settings!!!
125
In the FMC > SETTINGS page, would it be possible to save our settings automatically after any change, in order we do not have to set them on each flight?
Thank you!
