Some things aren't a 100% accurate in FMC...
Made a flight from Frankfurt EDDF to Berlin Tegel EDDT without problems.. Only few things were not like they're supposed to be.
E.g. the Missed Appr. path. Interesting, isn't it?
Fuel calculation (Fuel Truck from GDH plugin constantly said I had not enough fuel. Calculated on simbrief and 9t left as I reached Tegel...
Constraints are good in my opinion!
Another wrong thing: SULUS9F is a RWY 25C or 25L SID. However, I could choose it as a 07C SID? (Seems like the error is on my side) Even if not, this is (just guessing) a Navigraph related issue.
AP has problems reconnecting. I accidentally switched FD off and - as you would expect - all APs disconnected. But as I reconnected them (switched FD back on of course), AP wouldn't find its track. Just kept on moving in one heading, nothing but SPEED in PFD.
Was able to get it working by entering manual heading (pulling) and then pushing to get it to AUTO....
