I'm currently trying the new version on a flight from KIAD to LFPG. All in all, it works quite good.
However, the FD seems to have difficulties with crosswind. The plane slightly misses the current waypoint, short before, it starts turning towards it, and after that, it turns in the other direction again to follow the track to the next waypoint.
Here are two screenshots. One shows the ND at the moment the plane turns in the other direction again after passing the waypoint LIMRI. Before, it turned to the left. The second one shows of the flight path.
http://jardesign.org/forum/img/m/4445/t/p1c5eilmkvtik1mgp1rrgqmo12at9.jpg
http://jardesign.org/forum/img/m/4445/t/p1c5eilml0bjp1kn11g2l63i1dk7a.png
And anther issue, that I have with the 2.2 R3 as well: The dividing wall inside the cabin are completely black during night flights. At daylight, the are illuminated correctly.
http://jardesign.org/forum/img/m/4445/t/p1c5eitum6pfd1e69106gs5h161o4.png
Hello ilankrt, if you mean profile data is my computer setup, it's pretty much  the same as yours.
In answer to jo12341, I did try that but nothing happened. Thanks for the tip, I will give it another go.
I didn't mention the crash I had was when trying to load a downloaded flightplan into X-Life. When I let X-Life make the plan it loaded OK.
It may well have been me not being used to the new MCDU setup. Having said that the new MCDU is great, can it be put into the A320.
First of all, a big thanks for this update. Well done JarDesign.
Then some issues:
Trying to add this route
SBGR/09L UKBE1C UKBEV UZ26 KEXIT UZ46 CORVO UZ8 EGONI UL304 JOSES A315 ZIN
DCT ZQA DCT OMN J45 CRG  KATL/08L
Works fine until UL304 to JOSES, then it all crashes.
30 (edited by SinusJayCee 2018-02-03 22:05:55)
Finally got a CTD short before intercepting the ILS. Find the log and memory dump attached.
Acei wrote:
dudleybrooke wrote:
I was hoping controls would be unified with the A320, so that the mousewheel could be used for rotary switches.
+1
+1
zpampal wrote:
Downloaded, installed. Used my existing key. And this is what I get.
Yes I had the same thing. I reloaded the aircraft through the Developer menu and that ws my result as well. I quit XPlane 11 then restarted. Loaded the aircraft through the menu and worked fine. I hope you have found this out by now  smile
vishido wrote:
Hi Roman, I can't takeoff with the airplane. My xplane crashed on LIRF taxiway and now during MCDU configuration putting FL and T in INIT PAGE with the airplane at stand 306 EGLL.
Running Xplane 11.10 on Windows10.
Only enter FL : 380 for instance , this will give    FL380/-56  (example) without crash .
1. Когда самолет занимает эшелон, происходит снижение оборотов двигателя, а затем сразу же разгон, независимо от маршрута, сначала тяга снижается, затем разгоняется.
2. Мышинная зона для солнцезащитной пленки у командира очень мала, трудно ее потом убрать.
3. Переодически самолет пролетает маршрутные точки и начинает кружиться.
4. На ручке спойлеров, если приблизить, виден какой-то графический баг.
5. Временами не работает кропка "+" на количестве топлива в загрузчике.
1. When the aircraft occupies a train, there is a decrease in engine speed, and then immediately acceleration, regardless of the route, first the thrust decreases, then accelerates.
2. The mouse zone for the sun-protective film of the commander is very small, it is difficult to remove it later.
3. Periodically, the aircraft flies through the waypoints and starts spinning.
4. On the handle of spoilers, if you zoom in, you see some graphic bug.
5. At times the "+" crop does not work on the amount of fuel in the loader.
Just flew a quick hop from KOKC to KIAH. I found a few little quarks but overall the plane performed very smoothly. I ran through all phases of flight and even finished using an auto-approach landing perfectly. The MCDU and autopilot system tracked well. Issues I found were overhead panel buttons don't make a 'click' on/off sound for me when pushed. They just light up. I had one crash yesterday using Perfect Pushback at the gate. Ill try again later and include a .dmp and log if it happens again but overall I am very impressed!!
36 (edited by jcdp 2018-02-03 23:39:53)
When entering a coroute and with init page correctly filled I cannot see any altitude on flight plan waypoints .
So, only open climb is available, what do I do wrong ?
of course no TC nor TOD appear.
On an other hand I cannot get fuel prédictions ...and fill the Aircraft accurately
I was doing the MCDU entries and when i click to enter the flightlevel and the temp x plane crashes
Been able to fly some finally, there are serious issue with programming the MCDU routes. It constantly crashes on, what it looks like, longer routes. But overall it's a great update still! Thanks again JarDesign.
Some wishes:
Mouse wheel knobs please.
Only enter FL ... such as 380 for instance . And you shall have both (FL/Temp)
flightsimarts wrote:
After starting the APU or connecting the GPU my ND and my mcdu  wont light up. I checked the brightness and everything i could think of but cant get it working. Also i cannot  set a command  for jd/fmgs/CommandShowMcdu as recommended as i dont have this Option in my Settings. In the Log file I found out that there is an error Code 1114 while loading the fmgs/win.xpl file
skype j.a.romanov me please about Code 1114
41 (edited by vishido 2018-02-04 10:10:43)
The bug is this: the orange squares are 5/3 and you can think that you need insert 38000/-58... if you do that it crash but if you insert only:
- 38000
- 380
- 380/-58
everything is ok!
At least you can insert whatever you want except 5+3 digits!
Thanks for your suggestion!
not sure how to open the menu on the MCDU without the aircraft powered up
need to assign command to open MCDU widget on the screen and operate with Handling
(read first post about command)
Well,
As it is slightly different from V2 ...I was in trouble ...
Anyway I found how to manage ...
So, false problem ...sorry
по 3 - надо бы примерчик
по 4 - хорошо бы скриншотик
по 5 - если при этом работают движки или ВСУ (но есть трик - поставить на паузу сим - плюс будет работать)
45
To calculate vertical and speed profile FMGS should know block fuel and ZFW. Sure Init B page should be complete
I want to get this on my side. Can I ask you describe all details - what plan you try to enter, in what moment you get crash and so on. This is early beta-tests - issues may/should happen - need info to fix them, no more. Please.
Some wishes:
Get your files. Will check in debugger.
48
Anyone else completly lacking sounds (expect of fo/cabin crew) when using 330 together with xlife and x-atc chatter?
49
Hello guys,
First of all, congratulations on this beta!
Really nice:
3D moveable FMGS !!! :-)
Suggestion:
Possibility to save automatically settings changed in FMGS (like FPS MESSAGE to OFF)
Missing:
On ND, the distance on top right needs to be a decimal (like 2.3 NM)
Bugs:
VLS > VAPP, which looks strange (check enclosed screenshot)
When selecting GPS approach in LFBD via ROYAN8L STAR, transitions (like ETPAR) are missing.
However, it's possible to get them with previous A330 version.
I was not able to set an ALTN airport in FMGS. Maybe I didn't catch something...
I experienced a crash sim on a flight from LFMN to LFKJ. It happened once stabilizing at 3000 ft during the STAR, prior to fly the ILS02Z.
The log file is enclosed.
Thanks again!
50
I am getting that Pink windscreen with transparent squares effect. From memory i had this in previous versions but i cant remember what needed to be done to rectify it.
