Topic: X-Life ver 2.1 R1
Some details for new feature v2.1:
- every time when you start traffic (I mean Deluxe version), your x-life plugin will send a request to the internet and "ask" to renew schedule info for your selected Arrival and Departure airports.
- this request executed on our server side and after this, actual schedule data come to our server from real-life data schedule provider.
- next - this data (sorted from actual ZULU time) come from our server to plugin
- so, your X-Life plugin have real schedule for actual ZULU time inside now
- next step - your X-Life plugin use real scheduler with this way:
> if aircraft library (Bluebell) have needed (exist in schedule) Aircraft/Livery for next flight number we will see it in traffic (for next generated slot) with actual Aircraft/Livery/ArrivalAirport/FlightNumber
> if aircraft library not have Aircraft/Livery for real flight, plugin will try to generate flight with Aircraft/Livery what exist for this airport in real schedule
> if no lack (like we mean most of GA flights) - autogeneration will use.
So, in most of big airports we will get a flights with real Aircraft/Livery/Arrival-Departure/FlightNumber flights and this is some improvement i think.
Permanent link to actual version
http://www.jardesign.org/x-life/download/xlife2.1r1.zip
Installation:
If you use ver.2.X, you need update .xpl files only (attached)
If you use ver.1.X, you need delete old and install new FULL plugin from ZIP, please not mix any
Airport Editor manual by Philip Walchester posted here
http://jardesign.org/forum/viewtopic.php?id=3261
FMCar update
All remain the same
Important! Thanks a lot to all users who help JARDesign Crew in beta-tests of v.2.1
