126
Devirex wrote:
Yesterday i made a flight from LEMD (Madrid) to LPFR (Faro / Portugal) and two times i was handed over to "New Zealand Center" for quite a while. After Takeoff near TOC from Madrid Appproach  to New Zealand Center and after some miles to Madrid Center. After leaving Spain again back to New Zealand Center and then to Lisabon Center.
I had similar issue. Leaving LIBD (Bari Palese[IT]) to LIRF (Rome Fiumicino[IT]) in airspace the approach asked me to contact "Auckland Oceanic Center" for half of the flight. That happens while i flight around the LIBD zone, while passing LIBR or the Adriatic sea, the ATC would contact Brindisi Center, as has to be.
Normally the coverage area has to be LIBB which cover the Italy S-E area according those sites.
http://digilander.libero.it/antoniogolf … b/freq.htm
and
http://www.vatita.net/drupal/airspace/fir-brindisi
127 (edited by S3rg1o 2017-08-04 00:36:44)
Need help!
Everytime I try to start airport editor, it crashes on X-Plane 11, forcing it to quit to desktop.
I'm tryin to edit LPFR, already have both .dat and .txt files on X-Life/Airports folder.
Sending resulting log and dmp files
128
not work for me hmm
"flight plane" not open
tried to install again the plugin
tried disable GIZMO plugin
tried delet plugin folder and "update" it back
and try again and still not work
X-Life plugin by JARDesign Ver.2.0 r4 250717
for some reason ATC keeps sending me away from the airport when about to land idk whats going on?
130 (edited by Flashpoint311 2017-08-06 14:16:06)
Have a problem...
I downloaded and installed all the required files, but XP11 hangs on start when it says "will initialize plugins"
from the log file it looks like "couldn't connect to server" is the problem...
I am running win7
XP11 Steam version. maybe XLife isn't compatible with Steam?
If I take Xlife out of plugins folder, XP runs just fine. But I'd like to see some more traffic! If you could help me I'd appreciate it!
I have a Saitek multi panel and seems like all functions work except the ap light blinks constantly and the altitude cannot be adjusted from the unit but is still adjustable with the mouse does anyone have a similar problem ! Thanks
132 (edited by laohu314 2017-08-06 22:58:40)
I am having an issue with the Airport Editor:
I am trying to make an .xlf file for DD KMIA (DD Miami City XP). I have a .dat file with all the appropriate ATC Routes and Ramp Starts. However, in Airport Editor, the Ramp Starts are slightly misplaced and mis-oriented. I am loath to adapt them all again so would highly appreciate it if anyone can figure out what is amiss. apt.dat and KMIA.dat files are attached.
Many thanks!
133
Please inform me about flightpplanner what you WANT use to generate x-life plan, but CANT.
134
I installed the DVD version of xp11 and downloaded x-life again and the bluebell aircraft.  When I click " traffic on/off, nothing happens.  When I click it again : xp crashes .  What is wrong ?
135
I have noticed airplanes start stacking up in holding areas after 15-20 minutes of take offs and landings.  After a flight from LTFC to LTAC I watch the operation of LTAC for about 20 minutes.  The lead airplane in the various holding areas are all waiting for E195.  Flight E195 had taken off 10 minutes earlier.  See attached screen shots.  What keeps the planes in the holding area after the plane they are waiting for has left?
The last screen shot has the holding airplane without landing gear extended.
LTAC is an XLF file I constructed.  I am waiting to find out how to get rid of the RED question marks on the helicopter pads before summiting this file.
Thank for your help.
Ron West
136
Today flight : LPPT to LSZH
As departing Gate 122 with ground cab I was aligned on taxiway to start on both engines
-one AI plane came and cross me withtout stopping behind me ( to wait until I leave my position) and ATC told me  "hold position, runway position 17-35 busy" but I was still at apros (see photo)
137
In X-Life free version, the departure info tells me to takeoff from one runway but the Ai planes are departing and arriving from the opposite runways. This happened at KSEA and KEWR. Please investigate. Thanks
138
Flight LSZH to LOWW
Once I was parked at gate F31  at LOWW (I was the first) , AI don't notice I was here and so we were two planes parked at the same place sad
see photos
http://jardesign.org/forum/img/m/1125/t/p1bngi307010ad1nk8k0cl821mi93.jpg
Moreover I find that it is not enought traffic for a big airport like LOWW
Only 3 DEP and 3 ARR at the same time......
I hope upcoming updates will be more traffic
regards
139
Today flight LOWW to LFMN,
Xplane 10.51, Jar 2.7
Following flightplan by simleveries :
OSPE5B OSPEN DCT ABRUK DCT SETAL DCT DETSA/N0458F350 DCT LEVSI DCT VOG DCT ENOBA DCT ASBOP DCT BORDI BORD6R
I always have bug when inserting it  in the xlife flightplan because DCT waypoints
thanks for your help
regards
Alexandre
When leaving gate at LOWW airport with tugmaster, again AI xlife came and "don't see me".
It's like I were not here sad(
No waiting for this plane
See photo
http://jardesign.org/forum/img/m/1125/t/p1bnivijfvvb81m4o2qu12bl18mj3.jpg
Does someone have problems whit X-life and Rotate MD-80?, I have many x plane crashes whit that plane but other planes works great(FF767 etc).
142
azur29 wrote:
i have the X-life 2 R4 installed on Xplane11, and i have recently installing the  Bluebell pack.
When i start x-life, many Bluebell's over plane appears on my airport but there don't match with
the gate plane type.
For example, i saw a A320 tacking-of for  200 meters with a Cesna motor sound.
If i uninstall Bluebell pack, everything comes correct again.
May i forgot something ?
Another question maybe related to.  Xlife Traffic is working while no plane are activate in Xplane 11 trafficcAI menu.
How X-plane AI traffic have to be setting ?
Sorry for my bad english.
May be you just try to use X-Life in non-verify airport?
When you use X-Life, default traffic should be turned Off.
Yes, i'm using Xlife with a non-verify airport (LFRQ) .
after investigation, the problem occurs when i used aircraft editor first.
everything work ok today without using aircraft editor first.
Thanks for your answer.
hmm...sir...could you make for us the possibility to force size X aircrafts arrivals and departures for  X gate to test our creation.?
Many thanks
143
Issues with traffic not appearing on arrival at KMIA and sometimes at other airports although display shows the traffic at lower left screen. Must be a bug please fix thank you!
144
Still fairly new to this, but I was wondering if anyone could tell me how to turn up the ATC volume in X-Life Deluxe?
I can hardly hear it
145
Paul,
While in X-Life, click on the third square from the top of the menu column located on the right side of your screen.  See attached screen shot.  Another menu will open.  The bottom two items are the volume controls.
Ron West
146
Today flight from LSZH to LTAI
Flightplan from Siembrief
DEGE2W DEGES Z2 UMVEG DCT INSEL DCT VEKEN DCT DOL DCT NEMEK DCT VRANA DCT PETAK UM22 DOBAR DCT BITLA UN137 SKP UW58 ETRUD UN130 PIVOS UG802 IMR UT489 KAVAK UW95 CRD UL854 KOZLU KOZL1D
Import from the text files in ATC flightplan
LSZH SID DEGES Z2 UMVEG DCT INSEL DCT VEKEN DCT DOL DCT NEMEK DCT VRANA DCT PETAK UM22 DOBAR DCT BITLA UN137 SKP UW58 ETRUD UN130 PIVOS UG802 IMR UT489 KAVAK UW95 CRD UL854 KOZLU STAR LTAI
but errors, Xlige does'nt recognise it sad
Please what is possible to do ?
Thats very disturbing that most of flightplans with DCT points does'nt function with Xlife
Thanks for your help
Alexandre
you should be able to just leave the "DCT" out and have nothing but a space between adjacent waypoints, so try that and see if you have any more success.
148 (edited by k922365 2017-08-20 14:26:47)
Starting X-Life FPS will drop
http://jardesign.org/forum/img/m/1346/t/p1bo00gra51vop1d4etvmfnq9sa4.png
http://jardesign.org/forum/img/m/1346/t/p1bo00gra51qde8ao5fl13vg23k3.png
I have exactly same problem don't know what is wrong.
150
Thanks for the reply.
I tried it, but unfortunately don't have more success sad(
I hope this will be update one day.
Thanks a lot for your help
ALexandre
