cmckjodi wrote:
Just completed a test flight KIAD-KBOS on the A320 (latest version). Perfect flight as far as XL is concerned. The first time in a long while that DCT to Waypoint is working again. Previously, any WP DCT WP sequence in a flight plan was not working since switching to XP11. Also, ATC and FM car was working fine even though KIAD is not a verified airport but ATC routes exist. A small issue is that on Go Around the detour is enormous. When asking for vectors after GA at KBOS, ATC asked me to return to JFK and climb to FL250, ignoring the official procedure! So I invented my own GA route (according to ATC procedure) and went back to FL40. There is a small issue also in the flight planning of the A320 as well (IF does not get inserted into the ILS terminal approach) which I am going to describe in the A320 sub-forum.
How were you able to create a flight plan from an unverified airport? This is what I'm asking JAR thanks
Do you have to use one of his planes like the JAR a320? Was hoping you could use any plane
77 (edited by lange-71 2017-07-24 21:58:46)
Hello, i can`t click on the flightplan button, no green, no function
all other button ok
2.0 r3
78 (edited by cmckjodi 2017-07-24 22:41:58)
JAR here's a picture of what my problem is. If I try to generate a flight plan from UNVERIFIED airport KDCA the message says Dep airport not X-Life compatible. So therefore no flight plan can be generated. Is there any solution to this? I think you should be able to generate a flight plan to and from any airport. Thanks
79 (edited by Vlodek9 2017-07-25 03:46:01)
fafafoooey wrote:
Just purchased X-Life Deluxe and I'm having trouble with this flight plan. Generated route from SimBrief for KLAX-KSFO.
I'm entering KLAX SID STOKD SERFR STAR KSFO.
When I hit 'Send PLAN to ATC' I get "Flight Plan Error:" only. It does not tell me what the error is. Running latest AIRAC cycle on everything (1708).
Any ideas?
Traffic seems to be working, but I can not figure out this flight plan error. If I hit "Generate Flight Plan" it gives me some convoluted, unrealistic plan.
Having similar issue need help.
Just upgraded to the 2.0.R2 (can't find the R3).
Usually use Simbrief to create my flight plan. Had no issues on previous version of XLife.
Here is a plan from SimBreif
KLAX/25R LAXX9 MZB KSAN/27
I use to be able to enter the plan into Xlife letter per letter, number per number and it worked great.  DCT was not necessary.
But on the new version of XLife, I keep getting "SID error or check your NAV version and make sure it is the same on FMS, Life, ect."
I did, everything including XLife is running 1708
Tried several other flight plans generated from SimBrief and Skyvector. Included DCT, mirrored "SID" "STAR" instead of the sid name/star name. Nothing seems to work.
Tried on CRJ200, and IXEG 737.
As fafafooey stated, one can generate a flight plan in XLife but it is convoluted and it doesn't explain why a manual plan is not being excepted.
Running all of this on a Mac.  XPlane 10.5 (last 10 ver).
Again, no problems like this on previous version.
Out of ideas what else to try.
Eugeny,
I am using the newly released Xlife version 2R3 in X-Plane 10.51.  I visit several airports today and they all had the same
radio frequencies in the Airport Editor Radio tab.  I tried to change several of the radio frequencies but the Airport Editor would
not permanently save the changes.
Watauga wrote:
Eugeny,
I have informed Eugeny in post 63 of this topic for this frequency problem :
- same frequencies in each different airport
- wrong Center frequencies i.e. 157.25 or 180.80Mhz !!!
Pictures of frequency problem :
2 airports non-verified Xlife LFBD and LFBH
2 airports Xlife ready LFBO and UUDD
Thank
83
Yep. X-Life not use GA procedures from charts on this stage, but generate some own instead.
cmckjodi wrote:
JAR what mean is if I try to enter a flight plan from an UNVERIFIED airport example KDCA to any other airport, a flight plan will not be generated. So we need to be able to generate flight plans to ANY airports. Does that make sense? Thanks again
Yes, undestand what you mean.
all other button ok
2.0 r3
please contact www.support.jardesign.org with log
enrigolan79 wrote:
Watauga wrote:
Eugeny,
Understand. Problem was - FREQ was saved well from Airport Editor, but when X-Life open .xlf file, FREQs override with some default. This build (R4) should fix this. Sure, we will renew some published .xlf files later.
Any ideas
I didn't understand a word... but if you use SimBrief then click on SAVE and then on GENERATE OFP. Then scrolling down you sill see a list of route plan downloads. Download JAR A320 file (.txt) and put it into the Flightplan folder located in X-Life folder. Then creating with X-Life a Flight Plan click on Import Plan from .txt file and send it to ATC and to MCDU (ACF)...
You should see some video tutorials that will avoid writing long stories...
https://youtu.be/RaKz01gXrSA
JAR wrote:
enrigolan79 wrote:
Watauga wrote:
Eugeny,
Just tried xlife 2.0r4 ---> same frequency problem than 2.0r3
It would be a good thing if xlife could pick-up xplane default frequency without any manuel change by airport editor radio tab
thank a lot
Hi i think u fix my fps problem or mostly of it i think, it drop from 50 to 35 but then it set stable between 27-30. I also disable hyper threading from bios.
Any ideas
No, no, you are not understanding what I mean.  All works with the .txt file.  But, when I manually TYPE in the very same flight plan (letter per letter), it does NOT work.  Here are some pictures.  And yes at the end its KSLC, the C is cut off on pic view but it is there.
Attachment icon Screen Shot 2017-07-25 at 9.36.52 AM.png 245.79 kb, 138 downloads since 2017-07-25
thank a lot
So, as we just test, we can change FREQ and save it, and this changes will be reading after reopen this scenery. Is not it?
yes Eugeny,
"we can change FREQ and save it, and this changes will be reading after reopen this scenery" yes
but big problem with the new saved *.xlf file
make xplane11 crash !!!
returned back to 2.0r3 !!
sorry
Henri
enrigolan79 wrote:
yes Eugeny,
sorry
Henri
Anyone more, please report about CTD when save .xlf please for 2.0r4 !!!
94 (edited by cmckjodi 2017-07-26 11:40:12)
CTD with latest version R4 when I requested a different runway for takeoff X-Plane 11 CTD two times.
95 (edited by laohu314 2017-07-25 22:40:01)
enrigolan79 wrote:
yes Eugeny,
sorry
Henri
Just completed update of ZBAA.xlf in r4 and had no problem. Where do we best share the new .xlf files?
EDIT: just found out it was still r3! Trying r4 now
EDIT2: Just saved ZBAA.xlf from r4 no problem but had CTD when trying to switch airport to ZUUU
I love the Question marks pointing to errors to be corrected. One thing would help a lot and that is for the software to focus on a question mark randomly (similar to how WED does it) because I am having trouble finding the last few and spend a lot of time searching for them (appreciating the message that there are still errors to be corrected!).
96
www.simliveries.com is better way to share .xlf
If need to verify it and post to server for all users, need send it as ticket to www.support.jardesign.org
What mean "when trying to switch airport to ZUUU"? switch what? switch how?
Airport editor manual by Philip Walchester posted here http://jardesign.org/forum/viewtopic.php?id=3261
enrigolan79 wrote:
yes Eugeny,
sorry
Henri
Hello Eugeny
I will reproduce this problem and will inform you as soon as possible
Thank
Henri
Problem fixed there was a scenery issue with KBOS so I changed .dat file. All good
I am new to the x life program and was wondering how do I update x life 2.0 to new versions can someone walk me through the steps one by one thanks !
